400 turbo to a 205 transfer case. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2012, 07:56 PM   #1 (permalink)
Member # 234568
I have a 400 turbo with a short shaft, I also have a 205 transfer case with the 8 bolt pattern I cant find an adaptor. Is there a way to mate them up.
wesley24 is offline   Reply With Quote Quick reply to this message
Old 12-30-2012, 08:03 PM   #2 (permalink)
77k5's Avatar
Member # 35786
"Short shaft" doesn't mean anything, there are a bunch of different TH400 output shafts. How far does the shaft stick out from the end of the case? If you don't know that, what transfer case was on it?
How many splines on the input on your 205 or what transmission was it attached to?
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
970-945-7777
77k5 is offline   Reply With Quote Quick reply to this message
Old 12-30-2012, 08:33 PM   #3 (permalink)
Member # 234568
it was a 2wd trans and the case was to a 4 speed
Old 12-30-2012, 08:40 PM   #4 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
You still need to measure how much tailshaft sticks out of the case (with the tail cone removed).
The transfer case will have the wrong input (it's 10 spline, you need a short 32 spline input).
You'll have to keep searching for the 400/205 adapter, they're rare but not impossible to find. Look in the For Sale section here.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
happy..happy..happy....
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 12-30-2012, 08:52 PM   #5 (permalink)
Mr Cornbread's Avatar
Member # 182156
As long as it is the "short tail" with the solid bolt on yoke, it will be a direct fit for the "figure 8" adapter. All you need then is the mentioned 32spl female tcase.
Go BIG or go home!!!
Mr Cornbread is offline   Reply With Quote Quick reply to this message
Old 12-30-2012, 08:55 PM   #6 (permalink)
Member # 182156
Toyota_King387 did have one. I was looking for one for my Lomax and ended up finding the round 6 fit it. I think he was asking $160 shipped iirc
Old 12-30-2012, 08:55 PM   #7 (permalink)
Member # 195097
Theres a figure 8 style adapter on ebay for $250. A little steep because advance adapters only wants $220. They also will have the input shaft that you need.
flashdog is offline   Reply With Quote Quick reply to this message
Old 12-31-2012, 04:43 PM   #8 (permalink)
Buckshot33's Avatar
Member # 31228
I understand there are two inputs for gm 205's. one long 32 spl and one short 32 spl. can you go either way, long th400 output to short 32 spl input and vice versa? I'm in the same boat. I have a 205 with the short input and a th400 with a short output. they don't reach. which do I need to look into changing strength/durability wise? or does it even matter?
*edit* (there are other inputs, but two that work for th400's..)
'68 scout 800, TPI 383/700r4 D44's '66 K20 383/400/205 60/14
'62 nova 406/th350. 11.40's @ 118
Buckshot33 is offline   Reply With Quote Quick reply to this message
Old 12-31-2012, 04:53 PM   #9 (permalink)
Member # 147836
I got an a 400/205 adapter sitting here
blown xj is offline   Reply With Quote Quick reply to this message
Old 12-31-2012, 05:49 PM   #10 (permalink)
Buckshot33's Avatar
Member # 31228
From what I can tell, all the 400/205 adapters are the same depth. a 400/203 adapter is about half the depth. The th400's I have came off of a 203 so I would either have to run a long output on the trans or a long output on the tcase to get them to mate. Question is which one? or either one works?
Old 12-31-2012, 06:31 PM   #11 (permalink)
Member # 234568
what bolt pattern brown xj
Old 12-31-2012, 06:33 PM   #12 (permalink)
Member # 234568
sorry blown xj
Old 01-01-2013, 11:56 AM   #13 (permalink)
Member # 147836
400 to long input 205.. got it from a 91 Chevy one ton..
Old 01-02-2013, 04:12 AM   #14 (permalink)
justscoutin's Avatar
Member # 32053
that wont work with a figure 8 case, not to mention, its a 4l80 one that has a different register size.
88 chevy crewcab 6bt nv4500
72 scout 4bt on tons
justscoutin is offline   Reply With Quote Quick reply to this message
Old 01-02-2013, 10:23 AM   #15 (permalink)
Member # 234568
my trans has a 4 inch shaft and its a 32 spline, I have to transfer cases, ones out of a 4 speed with the 10 spline, and the other is out of a ford it has the 32 spline input for the trans.
Old 01-02-2013, 10:44 AM   #16 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
The Ford case is 31 spline.
Using the 10 spline tcase, you need a short 32 spline input (with bearing) and a figure 8 (400/205) adapter from a pre '85 truck. Machine the tcase input hole to fit the larger bearing. Done.
John
Old 01-02-2013, 10:47 AM   #17 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
Btw, if you'll SEARCH, somewhere buried in this forum there's a 205 tech thread with all your answers.
John
