95 Chevy 4wd quit working... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2003, 11:44 PM   #1 (permalink)
LilWes278's Avatar
Member # 16733
Send a message via AIM to LilWes278 Send a message via Yahoo to LilWes278
I've got a 1995 Chevy K1500. I used the 4wd back in deer season, then didn't use it for about 2-3 months. I went to use it the other day, and nothing worked. Not even the lights on the t-case shifter panel. Did I blow a fuse somewhere? Anybody have this problem before? -Wes
LilWes278 is offline   Reply With Quote Quick reply to this message
Old 02-18-2003, 06:49 PM   #2 (permalink)
Member # 9191
The soleniod on the front axle probably quit working. First shift the t-case into 4wd and make sure the front driveshaft turns. If it does go to the front axle and look for the soleniod to engage the axle disconnect follow the wiring to the connector unplug it. It is a 2 wire connector. Use a test light to check for power and ground at the wiring harness side. If you have power and ground the axle disconnect soleniod is bad.
overkill48 is offline   Reply With Quote Quick reply to this message
Old 02-18-2003, 08:11 PM   #3 (permalink)
Member # 10037
Im not positive, but i belive it would be locked in by vacumm. It is at the prime age for the vacum lines to be rotted and broke. If it isnt the vacum lines, might check (first) to see if the vacumm pump is working. Mine is located right under the battery box.
zip_tie_katterhenry is offline   Reply With Quote Quick reply to this message
Old 02-19-2003, 12:09 AM   #4 (permalink)
LilWes278's Avatar
Member # 16733
The solenoid would make sense as far as the 4wd not working, but I don't see how it would cause the display light on the t-case shift indicator to go out... Maybe I better start checking fuses first, then work my way down from there.
Also, I don't think these trucks are vacuum locked. If my memory serves me correctly, aren't they electrical/thermal actuated hubs?
Whatever it is, this is a prime example of why I'm selling my '95, and I'm gonna start driving my '75... simple, reliable, and easy as hell to work on (plus I wanna motorcycle now ).
Old 02-19-2003, 05:40 AM   #5 (permalink)
Member # 9191
The fullsize trucks are not vacuum actuated. The light will not come on until the soleniod engages the front axle. This is a very common problem on the chevy trucks.
Old 02-20-2003, 09:59 PM   #6 (permalink)
LilWes278's Avatar
Member # 16733
I'm not talking about the little orange part that indicates the front axle is locked. I mean the entire floor indicator will not light up. You know when you turn on your headlights, and the t-case console lights up? Not in my truck.
Old 12-26-2004, 11:49 PM   #7 (permalink)
Member # 17646
Its the solenoid.If it doesnt lock in the console light wont come on.When the fluid leaks out of the solenoid it cannot heat up to expand into gas,therefore not pushing the solenoid to engage.
Go Big, Go Hard, or Go Home
Jetwrench is offline   Reply With Quote Quick reply to this message
Old 12-27-2004, 04:11 PM   #8 (permalink)
Member # 38212
Get a posi-lock to replace that solenoid,works almost as good as hubs. That is what I used when mine went. All mechanical and easy to install. I still prefer hubs though.
1967K10 is offline   Reply With Quote Quick reply to this message
Old 12-27-2004, 05:35 PM   #9 (permalink)
COXIE's Avatar
Member # 34774
Send a message via Yahoo to COXIE
4wd
GM has a T.S.B. that list a "fast engage accuator and updated harness for these trucks.........I'll look it up for ytommorow at work and give you th part no's
Rick
Trail Rig
YJ Wrangler, 350 Chev on 'pane, SM465, twin stick 205, welded 60 front hung on Waggys, welded 14-bolt rear linked and coilovers, 38" beadlocked TSL's
Tow Rig
1999 Ford F350 4x4 Crew Cab
Powerstroke Diesel 6spd
COXIE is offline   Reply With Quote Quick reply to this message
Old 12-27-2004, 05:40 PM   #10 (permalink)
Member # 26699
I had problems with mine before I went SAS. Anyway until I did that I looked at fuses replaced them, replaced solenoid, and when it all came down to it it was none of that crap, the solenoid wires ran up to the wire loom buy the starter and I guess the exhaust got hot enough one day and melted the damn wires that run the solenoid they would short out on the frame and when I would try to engage 4x4 it would pop the fuse and then the lights would go out. I just cut the junk wire and replaced with new 12 gauge wire. It worked fine after that. Now I got lock outs and dont have to worry anymore about some damn wire. Just my .02
'78 383/465/205 4.56s
tonyjsmithjr01 is offline   Reply With Quote Quick reply to this message
Old 12-28-2004, 06:20 AM   #11 (permalink)
COXIE's Avatar
Member # 34774
GM 4wd t.s.b.
Okay found it! bulletin # 76-43-01A
actuator p/n 26060073
harness p/n 12376316
parts are available at local GM dealer
hope this helps
Rick
Trail Rig
Tow Rig
Old 12-31-2004, 12:58 AM   #12 (permalink)
LilWes278's Avatar
Member # 16733
Man, I forgot all about this thread! I've already had about 4 different trucks since I posted this. The '95 got traded in on my wife's Yukon (I let the dealer worry about it).
