4.3/700r4 issues - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2003, 05:30 PM   #1 (permalink)
Member # 11302
4.3/700r4 issues
I just picked up an 89 Jimmy. It drove fine when I pulled it off the lot. I let it sit at home for a few days, then when I went to drive it again, it started stalling when coming to a stop. Now, whenever I try to put it into drive, the engine just dies and the truck lurches forward. Any ideas as to what this could be? I've been told TV, and/or the MAP sensor.
Figured I'd throw it out to the guru's and get some decent info.
ehko is offline   Reply With Quote
Old 03-04-2003, 05:32 AM   #2 (permalink)
b454rat's Avatar
Member # 16536
sounds like the torque converter isn't unlocking....
b454rat is offline   Reply With Quote
Old 03-05-2003, 09:49 AM   #3 (permalink)
JoeMama's Avatar
Member # 17336
Check and make sure all the electrics are connected at the trans, and verify that the TV cable is adjusted correctly. Also check your timing. I just built a 4.3 recently, and it was doing something like what you describle... turns out it didn't like having the timing at anything other than 0*. Who would have known?
If you don't feel comfortable with the TV adjustment, take it to a trans shop. That adjustment can FAWK your trans real fast if its off by too much.
Good luck.
-Dan
[i][b]CK5 truck of the month, Nov '03[/i][/b]
[url=http://64.53.225.17/images/truck/]MY WEBSITE[/url]
350EFI/400/203/205/D60/D70/4.10s/LOCKED/42" TSLs/CAGED
JoeMama is offline   Reply With Quote
