Member # 3563
No rear brakes
I have a '76 Blazer with 3/4 ton axles and my rear drums aren't working properly. They work fine when I use the ebake but they are lacking when I use the pedal. The problem is severe when I'm towing and my Front brakes will lock up if I need to brake hard. Just normally I get some bad brake steer.
My theory is the truck is still running a 1/2 ton master cylinder and it's not pushing enough fluid to the rear. Before I swap in a new master I was wondering if the proportioning valve needs to be changed when doing a .5 to .75 swap or will the new master fix it? Thanks Travis
Amatuer driver on open course, try this at home. |
Member # 2095
I would think your proportioning would be OK as long as you have'nt converted to rear disks.
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's '02 Z71 |
Member # 13268
Your proportioning valve and master cylinder should be fine. I would look at rear brake lines to make sure there is no blockage or that the rubber line isn't swelling when you step on the brake. Also, make sure your wheel cylinders aren't leaking.
16543, 16593, 16676, 16736, 16858, 16940, 16987, 17091, 17157, 17298 I did...did you? |
#6 (permalink) | |
Member # 3563
Really you think the master will be fine? I would assume the 14b brake stuff would dwarf the 12b stuff the master was designed to fill. I'll check the lines but I haven't noticed any leaks. From the pedal feel it just seems like there's not enough fluid getting to those huge brakes. I'll go over the lines before I swap masters. Thanks Travis
#7 (permalink) | |
Member # 13268
Member # 3563
Hmm good points, I bought the truck in its current condition. I need to go over the lines and make sure everything's flowing well. The pedal feels pretty bad but too be honest I've never driven or owned a Chevy that the pedal felt good to me. I need to do some checking before I start swapping parts.
Thanks Travis
Member # 13268
Yeah, Chevys are typically a little soft, but it should be reasonably firm. Have you bled the system?
Member # 15404
If you feel like you loose your rear brakes all together when you hit them hard its your porportioning valve triping. Older Cheveys are natorious for having those things go bad.
But if that is not correct I am guessing air in the lines or the automatic adjustment slack adjusters stoped adjusting. Those things get rusty and crudy and stop adjusting the rear brakes. The brake shoes should be just touching the ware surface on the drum when not pushing on the pedal for them to work properly. I think all of the older cheveys I have owned have had this problem. EDIT 2 of witch were 1/2 tons with 14bolts swaped in. You don't have to change the master cylinder when swaping rear ends.
Life begins where the pavement ends! Last edited by rcurrier44; 03-20-2003 at 11:46 AM. |
Member # 7461
With the 1/2 ton valve and master cylinder the brakes on my 14 bolt tend to be touchy and lockup if used carelessley.
Idle hands are the devil's playground. Squirrels are the devil's oven mitts. |
#12 (permalink) | |
Member # 13268
They should be tight enough that it takes a little effort to turn the tire and it should make no more that one revolution. I adjust mine so that it almost stops turning when I let go, and that is with a 39.5 Swamper. It should be tighter with larger tires because of the greater rolling mass. The way you adjust them will work, but industry standard is that they be a little tighter.
#15 (permalink) |
Member # 3563
Well I tried to smog the truck today and the truck wouldn't stop the rollers. It has no rear brakes at. If I pull a prop valve out of the boneyard does it have to be trom a 3/4 ton 4x4 or can I just grab a chevy truck prop valve? If that doesn't work I'm considering converting to rear disks. Thanks
Travis
