GM axle questions... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-07-2003, 02:58 PM   #1 (permalink)
Member # 19437
Can anybody tell me if GM has any "desirable" axles out there with a drivers side drop? I'm currently running 12 bolts front and rear in my 88 YJ with a 350/NP203 combo. I'm picking up a 14 FF for my rear and changing up my tranny with a 700R4/NP231, so I'll need a drivers side drop axle. Also models of t-cases does GM make. ie: 205, 203.231,???
Thanx in Advance
MOJOMAN is offline   Reply With Quote
Old 05-07-2003, 03:08 PM   #2 (permalink)
Member # 14707
chevy didn't make driver's side drop. you'll have to go w/ a ford piece.
'87k5 swapped in blown 2.8, th350, 208, 12" suspension lift, custom 5" body lift, ARB locked 10 bolts f/r w/ 2.73's, 49" irocks... never rub = I'M HARDCORE!!! goes anywhere, never been stuck. still rockin despite the hate...you're all just jealous
reeser is offline   Reply With Quote
Old 05-07-2003, 03:34 PM   #3 (permalink)
Member # 19437
thanx buddy
I'll have to tryout another driveline option.
Old 05-07-2003, 09:49 PM   #4 (permalink)
Member # 19206
Send a message via AIM to browncow
NO DONT DO A FORD PIECE. BTW why do you need a drivers side drop? IF you go with an axle that has a drivers side ring gear, go with a mopar product, they are much better than ford and you will not shame the GM with the blue oval piece.
[URL=http://community.webshots.com/user/81onetonsub]81 One Ton Suburban.[/URL]
Sawzall = Fun!
browncow is offline   Reply With Quote
Old 05-07-2003, 10:03 PM   #5 (permalink)
Banned
Member # 11585
who cares what style it is? Dana makes the axle. Get a Ford STYLE Dana44. And you DON'T have 12 bolt in front. Try counting again (they don't exist). Innocent mistake.
Two Dogs F..king is offline   Reply With Quote
Old 05-08-2003, 05:20 AM   #6 (permalink)
Member # 19437
Here is my scenario: 88YJ with a 350/350 TT and an NP203 t-case.(passenger side drop). My axles are GM 12 bolt yes 12 bolt(full width). This set up came from a 78 Blazer. My t-case hangs down way to low and I like the 700R4 because of the low first gear and the overdrive. As for the NP231(GM), I know it has the drivers side drop, which is why I'm looking for that kind of axle. Ultimately I really want a 700R4/Dana300 combo and keep my front axle. I'm a Chevy fan If I go with this route R4/300 what exactly do I have to change? I heard the output shaft of the R4 has to be changed to a 27 spline I beleive. correct me if I'm wrong. Another option is to clock my NP203, I'm still not sure at how to do this. Do I need a clocking ring? Will I have to drill and tap new holes? I've read up about it but I would feel more comfortable with some actual pics and directions.
Anyhow I'm rambling on again, thanx for the reply's and I hope to figure this out soon enough
Old 05-08-2003, 05:24 AM   #7 (permalink)
Member # 3694
Re: GM axle questions...
Thanx in Advance
Get either a Ford HP44 front out of a 77-79 F-250 or get a HP60 out of 77-79 F-350. They will have everything you need. to have a d-side diff. Good Luck
Need Steering? www.shakerbuilt.com
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote
Old 05-08-2003, 07:37 AM   #8 (permalink)
Member # 4406
So, if I understand correctly, instead of using a Ford D44 with real wheel bearings, full floating hubs, lockouts, etc, that could even be had with a high pinion and the correct width spring perches to fit his Jeep, you're recommending he use a POS semi-floater CAD unit bearing crap monger axle thats setup for coil springs and links? Fawking NEWBIE moron.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote
Old 05-08-2003, 08:10 AM   #9 (permalink)
b454rat's Avatar
Member # 16536
Other than the Ford D44 or 60, there isn't any really good axles. Why not just swap out the transfer case to a 205? Think it costs like $200, if that. That way you can run the axles you got now, or upgrade to the 60 later. BTW, there are no 12 bolt fronts, either 10, D44 or D60. Inless it is custom made.
b454rat is offline   Reply With Quote
Old 05-08-2003, 08:14 AM   #10 (permalink)
Banned
Member # 11585
MOJOMAN... I'm sorry, but you are WRONG . There is no such thing as a 12 bolt front. That's sad. I know more about your truck than you do. And I'm not the sharpest tool in the shed.
Edit: I don't know more about your truck, but I do about your front axle.
Old 05-08-2003, 08:43 AM   #11 (permalink)
Member # 19437
Yeah you guys are right its a 10 bolt. I never paid much attention to it. Man I feel like an ASS
I think I might pick up that NP205, I heard good things about them. Is there more than 1 type by GM--1 ton-3/4 ton etc. Whats a good donor vehicle for one? Thanx again
Old 05-08-2003, 10:39 AM   #12 (permalink)
Member # 479
If you wanted to keep the pass. drop, you could look for the 89-91 700R4/241 combo with pass drop.
Also, you don't have 12 bolts front and rear, honest
Kyle Pope
POPE is offline   Reply With Quote
Old 05-08-2003, 10:50 AM   #13 (permalink)
Member # 19437
Hey Pope what truck does that combo come out of? And yes I know its a 10 bolt. I'm an ass I know. I never heard of them, whats the info on one of them 241's?
Thanx
Old 05-08-2003, 10:59 AM   #14 (permalink)
Member # 479
Thanx
241's came in 89-91 Blazer's and Subs. They also came in the pass drp dodges of the same general era, although mating one to a 700 is a little tricky. The 89 model used a mech speed while the later two years used an elec.
Comparing to a 231,
Max capacity tourque (lb-ft)
231: 1885
241: 5555
Weight
231: 65 Lbs
241: 80 Lbs (I put mine in with one hand, started bolts with the other)
Capacity:
231: 2.5
241: 5
GVW Lbs
231: 5920
241: 8800
The 241 has available for it a SYE kit as well. The lowrange is 2.72:1. It's a plenty stout case, althugh the drop is a little low. I've been working for a while on figureing out a way to clock one, just don't have the $$$$$ to do it.
The HD version of this case was used in the larger Dodges equiped with the Cummins so it can't be all that week
Enjoy, and no, you're not an ass, just a little mis-informed. It happens to the best of us...
Kyle Pope
Old 05-08-2003, 11:07 AM   #15 (permalink)
Member # 19437
Thanx Buddy!! Thats' the info I was looking for. I'll call my buddy at the wreckers and see if he has that combo and I'll take a look.
Thanx again
WICKD WHEELN
Old 05-08-2003, 11:52 AM   #16 (permalink)
El Jefe's Avatar
Member # 14072
The 241 can also be found in some 88's (a buddy has an 88 K5 with the original 241), which will have the mechanical speedo as well.
Thus far you have been adrift in the sheltered harbor of my patience.
El Jefe is offline   Reply With Quote
Old 05-08-2003, 12:25 PM   #17 (permalink)
Member # 19437
Thanx. On another note and a little of topic, What year did the short stainless headers come off of? I heard that they were on the HD2500 series pick-ups in the late 80'S. These are a perfect fit for YJ's with the 350 conversion
Old 05-08-2003, 01:32 PM   #18 (permalink)
Member # 4406
Yeah, I was gonna mention the 208/241 also. The 205 is certainly stronger, but the low range sucks (1.96:1), and to mate one to a 700 is a bit pricey; you either have to swap the output shaft (~$150-200 for the shaft, plus completly dismantle the tranny) and use a factory TH-350 version 205 and adapter (figure a few hundred, and some looking); or I've heard you can use a spacer instead of the new shorter output shaft (still have to use the rare factory 205 stuff). The advantages to the 208/241 is that they are cheap, will bolt up to a 700, and have a better low range. They both have slip yokes, there is a SYE kit for the 241, but not the 208. Some have converted them using the rear half of the Dodge 208 case; I looked at doing it and it seemed fairly simple, but I traded my 208 for a 241 and sold off the Dodge 208 parts I had.
Pete
Old 05-11-2003, 11:09 PM   #19 (permalink)
Member # 19206
pcorssmit, i apologize for my lack of knowledge in the front axle catagory. When i need help with that, i go to my friend who is more knowledgeable and let him help me. He prolly knows a lot more than you though. As for newbie, i dont know everything, but i do know enough not to be called a newbie. Just cause my post count isnt that high i am not a newb. Thanks for your help though.
Sawzall = Fun!
