Member # 3483
hydro to vacuum boost
is there any info out there on switching from hydro boost brakes to vacuum boost?? i'm thinking of doing this on my '87 1 ton..
Benny 350/350/205/60/60/linked/locked/lowered |
Member # 4406
Hydro is better. Keep it.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride." |
Member # 8211
Originally, I was like you. I didn't like the idea of all those hydro lines to leak and potentially blow. However, Pete and others convinced me to keep it for a while and give it a try. Other than the problems it has caused me on my 2" Hydro assist, I have not regreted it one time. It has MUCH more power than any vac system. I'll give you the same advice I got, and I'm glad I took it. Run it for a while. If it bugs you, then swap it. At least you'll know exactly what the trade off is, and you may decide to go back to hydro!
![]() As far as swapping, it's pretty much a bolt on. Just get everything from the rod on the pedal (seems I recal that the pedal may need slight mod, or get it too) to the back of the MC. MCs are the same IIRC. Seems like there are 2 of the mounting studs that have to be removed too...
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. |
Member # 3483
main reason i want to swap it out is because i'm going full hydro w/ the factory pump..
russ, what did it do to your hydro assist that caused problems?? that's my worry..
Member # 8211
Well, I really didn't *do* anything except add a 2" ram. The stock pump just can't keep up (even with flow mods) at idle. When your nose down and way off camber at idle, you can either brake, or steer, pick *ONE*. So I have to (counter intuitively) hold the brake, hit the gas to bring 'er up to a little over 1k rpms, THEN I can steer and ease of the brake to go forward. Not much fun when that off camber has you looking over a 200' sheer drop off 10 feet from your front left tire and your trying to turn and go along the edge!
I'm currently looking for a smaller diameter pulley to increase low rpm flow (I never get over 4k anyway), or maybe I'll mount 2 remote reservoir pump housings with one reservoir to get enough flow. I'm not even considering ditching the hydro-boost if that tells you anything... I would probalby go to a smaller ram first.
Member # 3483
haha, either brake OR steer.. i'll give it a try.. but even at idle with my foot on the brake i don't *ever* wanna not be able to steer.. that's what i was worried about..
but if i do decide to switch, what booster do i need?? 1/2 ton, 3/4 ton, 1 ton?? and does anybody know about the pedal mods that might need to be done?? thanks guys..
Member # 9357
Go crazy and mout a second pump next to the first. Have one for the brakes and maybe even a hydraulic winch and one just for the ram
. Sound a little crazy but you could redneck one together for prolly $50 and a little welding rod. Charlo
Scrap metal with a chevy logo in front. BB,FI,1T, |
#9 (permalink) | |
Member # 3483
#10 (permalink) | |
Member # 8211
From my post above.
Member # 3483
russ,
definately remote reservoir would be the way to go.. and i could run just about any pump i wanted too.. i'd only tie my hydro steering pump into my cooler and reservoir because i'd like to keep these systems separate.. it's more important i keep my steering fluid for the ram as cool as possible.. i don't really care about the hydro boost temperature.. so each system independent is the way i'll go..
#13 (permalink) |
Member # 800
for mine I just bolted in the 3/4 ton stuff including the rod, everything else bolted up fine. you will need to add a connection to the manifold to hook it up to. I have never had a problem stopping with the vacum setup.
my dodge sucked, I went superduty |
