Dana 60s.. Dodge and Chevy... help with the truth - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2001, 08:25 AM   #1 (permalink)
Member # 1724
I have an 86 K5 Blazer.
I have been told several stories here...
Will a Dodge Dana 60 bolt right in?
I have been told that it will sit 3 inches to the passenger side.
I have told it has differant width spring pads.
I have been told the brake lines are differant.
Whats the truth?
Thanks
Ken H.
four_by_ken is offline   Reply With Quote
Old 12-10-2001, 10:16 AM   #2 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Can't answer any of those, but I can raise another question. I've heard that the Dodge versions were made of an inferior metalurgy that makes them more prone to bend and break.
J. J.
www.PATPARTS.com
Like Patooyee's Parts on Facebook!
https://www.facebook.com/Patooyee
patooyee is online now   Reply With Quote
Old 12-10-2001, 10:21 AM   #3 (permalink)
Member # 1724
Isnt that just the new ones, like 88+... the older are fine I think.
Ken H.
Old 12-10-2001, 01:53 PM   #4 (permalink)
Member # 1909
The newer dodge d-60's and also the ford d-60's have ball joints in their front knuckles instead of the kingpin style, supposedly somewhat weaker. The biggest weakness of the "new" dodge D-60's is the two piece longside shaft that has a sleeve that is vacuum actuated. The sleeve is very weak. As far as how far apart the spring perches are on the dodge I don't know, go find an older dodge and measure the width of the perches, probably the same on the d-44 model dodges.
Michael Lockwood
Reedley, Ca. after 7 yrs in Sacto.
82 Toy with marlin and welded rear, locked front, 35's, 38's, 36's, depending on month/mood. SOLD IT!
79 K5, 14FF Detroit, D60 Lockright, Rockstomper Crossover Steering, 4.56's, 4L60E. 39.5 TSL's, Doubler.
82TOYLB is offline   Reply With Quote
Old 12-10-2001, 02:04 PM   #5 (permalink)
Member # 382
dodge 32 3/4 center of spring to center of spring. chevy 32
dodge approx 2 inches narrower over all wms to wms. dodge 60s dont have as much castor. dodge has two different style hubs external and internal.chevy internal only
72 SUBURBAN, 72 blazer, straight axled 02 duramax crewcab and 90 shortwide
bigblaze is offline   Reply With Quote
Old 12-10-2001, 04:29 PM   #6 (permalink)
Member # 2790
The spring pads on a chevy are a little closer together(less than 1/2 inch) however they bolt in from one to the other(I used a chevy axle in a 76 Dodge I has to get rid of the fulltime stuff). The brake lines are different> the Dodge has the brake line running along the top of the axle to each wheel. The Chevy runs along the frame with a rubber line from the frame to each wheel however they both use the same fitting on the caliper so if you use a dodge axle in your chevy you can unbolt your brake line from the caliper and bolt it to the Dodge.. As far as metalurgy I believe the axles are all made at the Dana factory to the specifications of the truck manufacturer. I will put my 93 DODGE Dana 60 up against anybodys Dana 60
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote
