Member # 21282
AC to air
I want to take my stock compressor run the intake into the valve cover and the output to a tank with a square D pressure switch to control the clutch. I searched and saw a bunch o shit about oilers and oil removers. I've seen it done this way and the engine air seems to keep it oiled enough w/out contaminating the air too bad. Any opinions?
#3 (permalink) | |
Member # 15404
Life begins where the pavement ends! |
Member # 15404
I realy don't have any experience with this setup but I'll give you my opinion. If there is oil in the air in there than it will work. A compressor doesn't seem to care what oil you run thru it, it just needs some lubrication.
But my new/good engine doesn't seem to produce much blow-by and therefore there doesn't seem to be as much oil in the vapor comming out of the engine. If you have an older engine than go for it. I know mine would leave a film of oil outside the breather every time I ran it.
Member # 9357
Other people have run that setup with success. I wouldnt run that shit though. I have seen inline oilers at pepboys for as little as $10. I dont like the thought of exhaust gases and oil going in my tires.
Charlo
Scrap metal with a chevy logo in front. BB,FI,1T, |
Unicorn Hunter
Member # 12419
also get a oil/water seperator from home creephole or loses for around $20 before it goes to a tank or your tires. Inline oiler into compressor oil/water seperator on the discharge side. Monting the compressor INHO is the hard part, since thats done allready. Then just go for it!
82 toy shortbed simple build http://www.pirate4x4.com/forum/toyot...y-new-rig.html and if your stuck in Carson City and need some welding help give me a call 775-884-4947 http://www.DrSmash.com |
