U joint angle? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2003, 09:54 AM   #1 (permalink)
Member # 22337
U joint angle?
What is the max angle that a 1310 ujoint can run at? 1350?
I have a 86 k-5 and my u-joint angles will be 16-17 degrees on both the transfer case and axle. THe axle is pointed up at 7 degrees, the transfer case is pointed down at 6.5 degrees and the driveline has a 23 degree slope.
How long do you think the stock 10 bolt u joint and napa conversion #447 u-joint will last like this?
btolenti is offline   Reply With Quote
Old 10-16-2003, 01:58 AM   #2 (permalink)
Banned
Wideopen's Avatar
Member # 22380
I would think that it should holdup fairly well???
Seems about the same as alot of em'..
You should try to do a search or something next time though...
Wideopen is offline   Reply With Quote
Old 10-16-2003, 07:36 AM   #3 (permalink)
Member # 22337
Well I did that and could not find anything remotely similar to my question....
Well, scratch that, I did find some things, just not the max angle a U-joint should be run at...and if a 1350 will last longer at the same angle as a 1330...
Old 10-17-2003, 01:46 AM   #4 (permalink)
Banned
Wideopen's Avatar
Member # 22380
Highangledriveline.com
Old 10-17-2003, 09:54 AM   #5 (permalink)
Member # 22337
and that tells me what exactly????? I know Jess makes 1350 CV drive shafts..... I just don't want to spend 430 dollars on a driveshaft if my existing shaft will work okay....
Old 10-17-2003, 10:00 AM   #6 (permalink)
Member # 4001
here:
Dysfunctional Rockcrawlers
Scout Dude is offline   Reply With Quote
Old 10-19-2003, 05:05 PM   #7 (permalink)
Member # 6807
What's this minimum angle noise?
[url]www.weusecoins.com/[/url]
Eric D is offline   Reply With Quote
Old 10-20-2003, 07:27 AM   #8 (permalink)
Member # 22337
I was wondering the same thing!
Old 10-21-2003, 01:09 AM   #9 (permalink)
Member # 4001
Minimum angle has to do with making sure the needle bearings inside get full rotation so they don't wear grooves (That's what I've been told)
Old 10-21-2003, 09:57 AM   #10 (permalink)
Member # 22337
I was told not to run a u-joint at greater than 15 degrees from Tom Woods site.... THat list says to run it at least 15 degrees!
Old 10-23-2003, 12:44 PM   #11 (permalink)
onetoncv's Avatar
Member # 2160
15 degree's hehe- Jess
http://highangledriveline.com
Bringing Innovation to the market !
http://highangledriveline.com/HAD1.gif
530-877-2875
onetoncv is offline   Reply With Quote
Old 10-23-2003, 01:18 PM   #12 (permalink)
Member # 22337
so this should be the max angle, Jess?
Old 10-24-2003, 03:18 PM   #13 (permalink)
onetoncv's Avatar
Member # 2160
max angle is a whole another thing then that item posted- the 1310 is good to 26 degree's - 1410 is aprox. 28 degree's - 1350 non c/v max 20 degree's - c/v's are a whole other thing- if you have any questions on this or other give me a ring - no strings- Jess
530-877-2875
Old 10-25-2003, 11:28 PM   #14 (permalink)
Member # 4001
So my pic is wrong?
