Discussion Topic - Safety Concerns for the average trail rig. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-22-2003, 01:44 PM   #1 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
Food for thought.
The more we wheel the more safety becomes a concern. What are some of the issues you have had and how did you deal with them?
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote
Old 11-22-2003, 09:33 PM   #2 (permalink)
Member # 24610
Send a message via Yahoo to mutant-jimbo
I haven't been too crazy with my ride (75 blazer), but i always winder if the factory roll bar is really worth a shit when it comes to a roll-over. i want a cage, but i want alot of things, and have to get each thing one at a time. what do you all think about the factory roll bar?
mutant-jimbo is offline   Reply With Quote
Old 11-22-2003, 09:49 PM   #3 (permalink)
Member # 9222
good topic paul !! wiring,especially on older rigs. check things out once in awhile. on a driver the fire ext. should be in reach of the driver. i almost lost my willys wagon to a fire when i first got it years ago. cruising down the road i had a spark from under the dash,by the time i got it stopped i had flames up to my chest. made it around to the back for the extinguisher and managed to save the rig.
get a good fire ext and keep it handy.don't forget the yearly check, the powder tends to get pounded into the bottom reducing their effectiveness.
larryboy is offline   Reply With Quote
Old 11-22-2003, 11:15 PM   #4 (permalink)
Poseur SUV
Member # 610
A fire extinguisher is a definate must and it must be big enough to do some good. Watching your truck burn down isn't fun.
Paul Gagnon
"No Brain, No Pain"
Old 11-23-2003, 11:45 AM   #5 (permalink)
Member # 82
IMHO, COMMON SENSE goes a long way when discussing safety.
...have the battery strapped down properly to prevent potential shorting out on the underside of the hood and causing a fire or electrical melt down...same idea with the carb and fuel lines....make sure they are secured away from the fan etc....
Steering.....is it booty fabbed?
Brakes....do all 4 of them (or at least 3 of them ) work properly?
Recovery equipment....do you have it?
Tools to fix your junk when it breaks?
geez...i sound like my Mom.....(is your jacket warm enough...you cant wear a short sleeve shirt in this weather.......don't crash )
If you're happy and you know it....shut your face.
Mr. Happy...OK? is offline   Reply With Quote
Old 11-23-2003, 06:10 PM   #6 (permalink)
bansheeboy182's Avatar
Member # 17602
wireing is a good idea. i have a 76 fj40 with a tbi 305
i don't know what is old yota motor wires and what is new tbi wires. i really need to take a day or so and figure it out but i dont have diagrams for either
i feel ya on the fire thing, i have a f250 and some brake line sensor crapped out and started on fire while i was eating lunch, it's a good thing a highway patrolman was there with an extinguisher or i would have had a show
where can i get one, what size, how much is a good extinguisher?? i really think i need one in my cruiser after my truck cought on fire, the fire was nothing serious but its enough to really make you think
also i have leather seats out of an oldsmobile with the seat belt latch hooked to the seat, but the old owner had the belt latches on the floor, i can't decide what to use?? the seat latches are only as strong as my seat bracket but the floor mount it only as strong as paper thin 30 year old metal.
also since we are talkin about saftey, i have a friend who has a lexan windshield on his cruiser, how many of you have something like this?? is this even safe?? it appears it would but i would like to hear something on it
sorry this is so long
bansheeboy182 is offline   Reply With Quote
Old 11-23-2003, 07:38 PM   #7 (permalink)
Member # 17025
Fire exstingisure was the first safety item I bought when I bought my rig. I have it mounted on the center, front of the dash. I also have two battery hold downs, the factory one and an after market one. I had my battery fall once on a run and it landed on the little fan for the allternater. Put a huge hole in it.
85 X-tra cab Toy.
krawlin K-5 is offline   Reply With Quote
Old 11-23-2003, 08:19 PM   #8 (permalink)
Member # 8211
Safety is a very important topic for me. I wheel with my 16 year old son, and 12 year old daughter.
I have 4 racing style buckets (high sides to hold you in place) mounted to the cage with full harnesses in all positions. The extinguisher is mounted where it can be reached quickly from either side. The roll cage is solid and well triangulated, forming a sort of enclosing pod which can not push through the floor or rip away. Only glass is in the windshield, and that is safety glass. All fluid vents are plugged and valved to eliminate burns and fires. All objects are firmly secured using hard mounts or 1" ratchet straps. The battery is secured safely in the rear under the floor. I kept the radiator in front specifically to avoid the potential for burns. All critical mounts are inspected, tightened, adjusted, whatever before each trip. And if there is any identifiable danger, even just a likely flop, everyone gets out except me, though I do sometimes let my son talk me into letting him ride as long as it's nothing likely worse than a flop...
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote
Old 11-24-2003, 11:22 AM   #9 (permalink)
Member # 21220
Send a message via AIM to Dayswon
wear a Freaken seatbelt. the more i see people hurt from wheeling the more i make people wear theirs. but still people dont and they deserve to be hurt!!
79 Chevy Scottsdale / 1 ton beef / 4.56 locked / 6" susp 3" body 39.5boggers.
"And there aint nothing wrong with the radio"
Dayswon is offline   Reply With Quote
Old 04-27-2004, 08:45 PM   #10 (permalink)
Member # 5472
I agree! If you look at all the deaths associated with wheeling I have noticed that all of them have this in common, "driver (or passenger) didnt appear to be wearing his/her seat belt." I am not saying you need to have a 5 point harness but at least wear your seat belt. That said I have built a family cage (hopefully it will be tied into the frame next week) and plan on full on aftermarket seats this year. I take my kids with me (6,9and 12) so safety is a top priority. I carry 2 fire extinguishers when I wheel as well and try to fasten everything down so if I do roll my High Lift doesnt kill me.
Did you ever notice: When you put the 2 words "The" and "IRS" together it spells "Theirs?"
spoolnaround is offline   Reply With Quote
Old 04-27-2004, 10:13 PM   #11 (permalink)
Member # 18806
Send a message via ICQ to KaceCoyote Send a message via AIM to KaceCoyote
TIE SHIT DOWN.
If its in the rig, it needs to be STRAPPED FIRMLY TO THE FUCKIN FLOOR.
I've seen more billy bob rednecks hurt by just flying misc shit than I care to recount. In rollovers, in almost rollovers, in hitting bumps, in emergency stops, in steep descents or off camber bits. Its not always just the dumbasses its easy to forget to strap that 15lbs crowbar back in place You sure wont be real smart after it gouges out grey matter in a nasty rollover.
"All that is complicated is worthless, all that is simple is useful." -Kalashnikov, creator of the AK-47/74/101/102/103/Saiga ect ect
KaceCoyote is offline   Reply With Quote
Old 04-27-2004, 11:10 PM   #12 (permalink)
Member # 19297
Send a message via Yahoo to leadfoot067
great topic....i used to think i over packed stuff in my rig..till me and 3 others were all stuck in the snow,we wer there all night....i had my kids with me they were 5 and 8 at the time...i alwaya carry 2 heavy blankets..lukily for my kids they stayed warm in the rig all night...i also had alot of extra food that i shared with everyone,i had 4 pairs of gloves in the truck that all got used,2 rain slicker things that will fit in your pocket...one kept me dry in the snow all night,i also have a small hand warmer thingy that was a favorite that evening...ALWAYS GO PREPARED!!! i pack even more stuff with me ever since...coulda used another blanket for myself and a dry pair of shoes and socks...thats my .02cents worth
73 blazer,EFI350,465,ORD doubler,60,14ff,caged,locked,hydro'd,disked,52s,56s,42 IROKS
leadfoot067 is offline   Reply With Quote
Old 04-28-2004, 06:17 AM   #13 (permalink)
Member # 26894
Send a message via ICQ to Smash-K20
Not as funny as it sounds, 4 years ago during our spring mud run a young fellow wandered off from the main group and went up a side trail where he got stuck. He left his rig and tryed to take a shortcut through the woods to return to the main group on foot for help. He got lost in the woods and was found the next morning frozen to death 300 yards from the main trail.
For automotive fire extinguishers I highly recommend this stuff....
http://www.firefreeze.com/site/page13.cfm
I'v seen it work and it's far more affective than an ordanary extinguisher. It's what I keep in my rig and shop.
Dale
_____________________________________________
[QUOTE=Entropy]Please, Rip isn't big enough to make me mumble. I could sing the Star Spangled Banner without a skip sucking Rip's dick.[/QUOTE]
Smash-K20 is offline   Reply With Quote
Old 05-11-2004, 08:09 PM   #14 (permalink)
Member # 13290
Excellent topic, so I'll add my reiterating $.02
Fire extinguisher, or two, in the cab where you can get them quick. Flashlight, that works. Wear your seatbelt. Don't be an idiot.
Tie or lock down everything. I run my craptacular factory battery hold down, with a ratchet strap to back it up. I keep the heavy crap in my crossbox (not a lot of crossboxes on full trail rigs, but ammo cans, coolers, something bolted down & securable helps.) I have padlocks holding the crossbox lid shut, and eyebolts with padlocks to hang onto the highlift. They rattle, so what? They hold very nicely.
Keep things tight - check steering, brakes, wheel lugs, u joints, brake lines, oil lines, shady wiring, etc etc etc more often than you want to in order to prevent bad things from starting. Picture mom saying "an ounce of prevention is worth a pound of cure."
I also pack extra fluids, extra accessory belt, a pair of Carharts, gloves, hat, and a good map... in every vehicle I drive aside from my bike.
-Nate
My $.02 on Lexan - I use the impact & scratch resistant stuff to replace my Grandpa's tractor windows. You don't get the glass flavored explosion of safety glass, or the shards stuck in your arms & face, but if something does come right through it, it'll be pushing a plastic dagger at you very quickly. With glass, it'd be a glass covered stick or rock, so I'd run either. It takes a bigger whack to break lexan, from what I've seen.
something clever here
n8damack is offline   Reply With Quote
Old 06-07-2004, 12:02 PM   #15 (permalink)
Member # 1999
Send a message via ICQ to jeeplvr
Where can I find a fire ext with a roll bar mount/clamp for my buggy?
{Gramma from Squidbillies} Lets put coughdrops in our buttholes and play viddy games!
jeeplvr is offline   Reply With Quote
Old 06-07-2004, 12:53 PM   #16 (permalink)
Member # 8211
I used the wall mount secured to the cage with hose clamps. It has yet to pop loose a single time.
Russ
Old 06-07-2004, 03:14 PM   #17 (permalink)
Member # 1999
I guess I should clarify that I am looking for an extinguisher with a billet mount. I have found some but the cheapest mount I have found is over 100.00
http://www.livermoreperformance.com/...l#Anchor-10035
