Water leaking from the firewall? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-29-2003, 10:12 PM   #1 (permalink)
Member # 9357
I got a BAD water leak coming down the floorpan/firewall where it meets the kickpanel I think its called(plasic behind parking brake lever). Got any ideas where in the hell it is coming from? I looked but it comes from to high up to see. Almost under the dash.
Charlo
Scrap metal with a chevy logo in front. BB,FI,1T,
charlo is offline   Reply With Quote
Old 12-30-2003, 09:19 AM   #2 (permalink)
Member # 14169
Might be the windshield gasket.
SandmanII is offline   Reply With Quote
Old 12-30-2003, 10:28 AM   #3 (permalink)
Member # 9357
Thats the only place I can think of unless there is some pinchweld or something weird thats opening up. Anything else that could be leaking?
Thanks
Charlo
Old 01-02-2004, 09:13 AM   #4 (permalink)
Member # 3694
Winshield gasket....very rare occasion the bottom corners of the window frame will rust out....or even the "cowl" but you being in Cali. I doubt it......was it orginally a cali. truck or from up north where salt is used? Any change that your steering column seal is rotted out or cut and you had went into some water?
Need Steering? www.shakerbuilt.com
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote
Old 01-02-2004, 09:22 AM   #5 (permalink)
WILLIE's Avatar
Member # 13234
I've seen several blazers that leaked because there was a nasty pinch weld going up the cowl, just in front of the door hinges. you have to take the fender off and fill the gap with seam sealer.
WILLIE is offline   Reply With Quote
