1990 TBI 350 won't start when hot - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2004, 04:57 AM   #1 (permalink)
Member # 25210
OK, be gentle....chevy newbie
I tried a search, but no luck.
A buddy of mine has a 1990 GMC that will start and run fine when cold, but not when hot. When the truck warms up, it idles poorly, then will not restart.
He's getting diag. code 15 for coolant temp sensor. I understand that the coolant temp sensor would affect the idle, but will it cause the truck not to start at all.
He's checked fuel tank vent lines for blockage and he can see fuel spray from the injectors.
any help appreciated.
Zukyota is offline   Reply With Quote
Old 02-24-2004, 05:27 PM   #2 (permalink)
Member # 21452
after its hot and cools does it start fine again ??? if the TB squirting gas once its hot .....i had a TB motor just a few months ago run great till it was hot ,then it wouldnt start till it cooled off ..it didnt thow a code either ...totally strange .it turned out to be a bad fuel pump relay
440ex is offline   Reply With Quote
Old 02-24-2004, 06:12 PM   #3 (permalink)
Rastus's Avatar
Member # 18861
Send a message via AIM to Rastus Send a message via Yahoo to Rastus
yes, the coolant sensor will in fact cause the issue you are having.
[URL="http://www.facebook.com/pages/Texas4x4org-Forum/215823041443"]Texas4x4 on Facebook[/URL]
[url="http://www.texas4x4.org"]Texas4x4[/url]
Rastus is offline   Reply With Quote
Old 02-25-2004, 08:34 AM   #4 (permalink)
Member # 24513
Send a message via AIM to zkrawler_04 Send a message via Yahoo to zkrawler_04
could it possibly have the timing set too far advanced?....did that on my 90 TBI chevy and caused the same problem when i did my headgaskets
2 megacab diesel's and 2 competition diesel's
zkrawler_04 is offline   Reply With Quote
Old 02-25-2004, 08:44 AM   #5 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
possibly a starter? I had issues with my 94 not starting, changed out the starter and it has been good ever since. well except for that time that I lost a starter bolt.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and fox coilovers, 8.1 liter 496 bbc/4l80e/BWtcase. DD/towrig
jays68yak is offline   Reply With Quote
Old 02-25-2004, 06:12 PM   #6 (permalink)
Member # 16608
Re: 1990 TBI 350 won't start when hot
Code 15 is low temp indicated, sensor tells ECM it's -35*, ECM adds fuel, probably enough when warm to flood engine.
Disconnect sensor, jumper the harness connectors together. This will trick the ECM into thinking it's +260*, go test drive. I bet it will run way better when warm.
'88 Zuk
TatorZuk is offline   Reply With Quote
