88-98 SAS Thread - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-20-2004, 02:48 PM   #1 (permalink)
American's Avatar
Member # 12257
Send a message via AIM to American
88-98 SAS Thread
OK so how about we make a compilation of information, and links (to sites and threads) on the good ole 1988-1998 (or the like) straight axle swap. If you post a link, then I will put it on this entry, and we will have a list of them. Pictures, measurements, prices, etc. Any other 88-98 "harcore" info other then SAS would be cool too.
I will start off with some...
Anymore?
PS I have learned that anything by willyswanter is "the shit"...
Last edited by American; 08-11-2012 at 08:49 AM. Reason: Adding links to the list... :D
American is offline   Reply With Quote Quick reply to this message
Old 05-20-2004, 02:52 PM   #2 (permalink)
Pdaddy's Avatar
Member # 8133
Cool fawkin post man...good info. Yea Willyswanters junk is badass! 2 weeks until I have a full 7 days to work on mine
LCQ / KOH 09 Co-Driver #62
Midwestwheeler / Hardline Custom
Pdaddy is offline   Reply With Quote Quick reply to this message
Old 05-20-2004, 03:19 PM   #3 (permalink)
American's Avatar
Member # 12257
Can't wait to see it bro.
Some info (got from zkrawler). He used 52" front springs. The front hangers from a 79 3/4T GM (front hangers from front springs). The rear hanger is from the same truck (front hangers from rear springs). The front hangers are mounted flush with the front of the frame. The rear hanger spring eye is 51" from the front of the frame, and the bottom of the hanger is flush with the bottom of the frame. This puts the hanger almost at the end of the "boxing" in the frame.
Question: Anybody know if all 88-98's have the same distance from the rear of the frame to the center of the axle? If so, I have another question to follow up.
Old 05-20-2004, 03:59 PM   #4 (permalink)
b454rat's Avatar
Member # 16536
If anybody wants to do a SAS, Im selling my HP60 and ORU stuff!!!! Check for sale section.
1999 GMC CCSB plans for 8.1 and SAS
b454rat is offline   Reply With Quote Quick reply to this message
Old 05-20-2004, 04:17 PM   #5 (permalink)
Member # 7668
Send a message via AIM to Hypoid Drive
Good post American , I am glad you did that I was trying to do the same and wasnt having a lot of luck with the new serch lately
In search of portals
Hypoid Drive is offline   Reply With Quote Quick reply to this message
Old 05-20-2004, 05:15 PM   #6 (permalink)
American's Avatar
Member # 12257
SAS doesn't show up. I searched for names I knew, and I have a lot of them on my favorites. 88-98 is a good search for it though...
Old 05-20-2004, 10:30 PM   #7 (permalink)
DarkEternal's Avatar
Member # 23853
Send a message via AIM to DarkEternal Send a message via Skype™ to DarkEternal
Not a 88-98 but close (newer). Im out of school now and diving into it all out. The truck goes under the knife aug 1st for the actual swap.
http://homepage.mac.com/darketernal/SAS.html
tell me what ya think of it so far (the article and the rebuild)
DarkEternal is offline   Reply With Quote Quick reply to this message
Old 05-21-2004, 05:43 AM   #8 (permalink)
American's Avatar
Member # 12257
Link add'd... nice rig, can't wait to see it. You're cagin it eventually right?
Old 05-21-2004, 05:55 AM   #9 (permalink)
Pdaddy's Avatar
Member # 8133
If I read this correctly (and I read it twice) He used the FRONT HANGAR FROM THR REAR SPRINGS on the backside of the front springs and put the shackle in that? I had my springs under mine last night looking at things, and the shackle has to inboard of the frame ALOT to get the 31.5 center to center. Im using 53" Ferd springs but essentially it will be like his arrangement. If I can find a set of those factory mounts (that I can use) Id really like to do it that way for simplicity though. Was there any other spacing out or adjustments or did these just simply put the shackle were it needed to be?? Thats damn sweet/lucky if it does
Old 05-21-2004, 06:02 AM   #10 (permalink)
American's Avatar
Member # 12257
Well, as I understood it, the hanger is all that is needed.... and yes you read it correctly. He put them on the inside of the frame pointing inward of course. I guess that's all he needed. I'm sure he will post up and tell us for sure though.
As you can see, he had to shave off some of the top of the hanger.
Old 05-21-2004, 07:22 AM   #11 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
YAY! I just paid off my truck. Now to find money to put a new motor in it then SFA time. Need to locate a cheap HPD44. What is everyones opion on a d44 for a semi wheeler, more dd then anything?
Current build-2002 Chevy truck buggy, 06 front clip tube-coilovers,bypasses-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
2006 dodge 3500 dually tow rig
1967 chevy K10, d60 14bff detroit, 37 mtrs, lq4, sm465, np205
jays68yak is offline   Reply With Quote Quick reply to this message
Old 05-21-2004, 10:16 AM   #12 (permalink)
American's Avatar
Member # 12257
What size tire and what kind of wheeling?
Old 05-21-2004, 10:40 AM   #13 (permalink)
Member # 30048
Here Is a Guy Doing a SAS: http://www.pavementsucks.com/forums/...43990&forum=16
It's not a pipe dream, it's a 4130 chromoly tubing dream.
Team L.C.O. is offline   Reply With Quote Quick reply to this message
Old 05-21-2004, 10:56 AM   #14 (permalink)
jays68yak's Avatar
Member # 19015
nothing over a 38 most likly. I have 33s now, sitting next to my roommates on 36s i think i might want a bit bigger if im going through all the trouble. IF anything its mud, rocks scare me cuz i dont have a cage and this is more of a 'nicer' ride then a crawler.
Old 05-21-2004, 03:39 PM   #15 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
the only consideration with doing it with the rear spring perches from the rear of a donor truck is that they take a rear shackle. this is a problem with the use of stock chevy front springs. If you go the 52 inch rear springs, you already have 9/16" steel bushing and no width problems. Just pointing this out. Some might try to go stock length fronts from a 73 to 87 chevyand run into hole size and spacing problems with the perches from the front of a rear spring
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Your ORI strut dealer along with about anyting else you need!
team Nasty co dog
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 05-21-2004, 10:53 PM   #16 (permalink)
American's Avatar
Member # 12257
That is a very good point to make. That will only work with Chevy rears as previously stated, as the front chevy springs have a smaller bolt out back.
Old 05-22-2004, 08:26 AM   #17 (permalink)
Member # 26545
Send a message via AIM to Beater_K20 Send a message via Yahoo to Beater_K20
i noticed a couple people mention using the stock front hangers front the front springs in their "stock" location on an 88-98 conversion. how does this work with the 52" springs up front?
77 K20 350/350/203 - 90 K3500 454/80e/4401 - 94 K1500 350/60e/241
Beater_K20 is offline   Reply With Quote Quick reply to this message
Old 05-22-2004, 02:47 PM   #18 (permalink)
American's Avatar
Member # 12257
do what? We use hangers off of 73-87 4wd trucks, and put them on the 88-98 frames... stock location? I don't get what you are saying. There are no spring hangers on a 88-98 front, when it's stock.
Old 05-22-2004, 03:41 PM   #19 (permalink)
Member # 26545
"stock" location, meaning where it was originally designed to go on a vehicle. ie front spring front hanger goes all the way out front, rear spring rear hanger goes all the way at the other end.
Old 05-23-2004, 11:50 AM   #20 (permalink)
Member # 23853
Yes im going to put a full exo on it when money allows it to happen.
Old 05-23-2004, 04:06 PM   #21 (permalink)
American's Avatar
Member # 12257
oh ok. so you are asking how the front spring hangers off of the front of another truck will work on the front of an 88-98? Hmm... seems like we answered that question already? I don't know, maybe it's just me though, but I could have sworn we already said that zkrawler is using them just like that....
Old 05-23-2004, 05:58 PM   #22 (permalink)
Member # 26545
oops, must've missed that one...
Old 05-23-2004, 07:16 PM   #23 (permalink)
American's Avatar
Member # 12257
happens to the best of us
Old 05-23-2004, 10:03 PM   #24 (permalink)
Member # 24513
Send a message via AIM to zkrawler_04 Send a message via Yahoo to zkrawler_04
ok, figured it was time for me to post up since my rig has brought up a few questions....as yall seen in the pic that american posted up of it the front rear spring hanger dost give you the 31.5" center to center measurement, but yes i takes a rear shackle, therefore rear springs, unles you fab your own shackles then you can solve that problem and run front springs if you want to, but with how great it works out usin the 52"s i would advise anybody to go that route.....as far as the front hangers i did use the ones off of the 79 and i mounted them flush with the end of the frame which put the eye about 1.5" from the end of the frame but i dont know the exact measurement because i havnt put a tape on it, and i mounted them flush with the outside of the frame as well wich keeps the 31.5" center to center measurements to match the chevy spring pads.....here's the pic of the front hangers btw i had to use shims because the front springs are wider then the rears so the front hangers were a little too wide
2 megacab diesel's and 2 competition diesel's
zkrawler_04 is offline   Reply With Quote Quick reply to this message
Old 07-23-2004, 12:19 AM   #25 (permalink)
American's Avatar
Member # 12257
Added a link... anybody got anything?
