Advice for repair vs replace - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-19-2017, 09:23 AM   #1 (permalink)
Member # 678914
So my Current pickup is a fairly stock 1999 silverado 1500 regular cab long bed 4x4. It is currently in need of about $1900 repairs (shocks & springs, tie rods, ball joints, pitman arm, idler arm). I am currently trying to decide whether to repair it and drive it until it is no longer fixable, or trading it in for something about the size of a ranger or tacoma that I can trick out a little better than the silverado work truck. The silverado has about 200,000 miles on it and the drivetrain and powertrain are in good shape. Any advice? I plan on doing the shocks and springs at home, and I've heard differing opinions on the easiness of ball joints and tie rods. Any advice and suggestions is welcome.
tacticalbacon45 is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 09:59 AM   #2 (permalink)
b454rat's Avatar
Member # 16536
Do it urself n save half of that
1999 GMC CCSB plans for 8.1 and SAS
b454rat is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 11:05 AM   #3 (permalink)
Member # 113594
How is the rest of the truck? If it was from Michigan where I am it is probably very rusty and not worth fixing. My Dad just had to park his 99 because the frame broke where it rusted through. If the body is in good shape I would fix it and keep driving it.
prox621 is online now   Reply With Quote Quick reply to this message
Old 06-19-2017, 11:30 AM   #4 (permalink)
Member # 678914
body is in fairly good shape. large dent in rear driver's side of bed and bumper bent inwards from where a cement truck backed into it when the previous owner had it. some rust in the bed, but beds for it can be found fairly easy and cheap here. interior is as good as can be expected from a work truck and it has fairly new tires. I'm currently leaning more towards keeping it and then doing my upgrades (like a brush guard, some offroad lights and simple stuff like that) to it.
Old 06-19-2017, 11:34 AM   #5 (permalink)
Member # 678914
one of the main problems is that my only other vehicle is a motorcycle and weather is unpredictable down here in south Ga. So most of the repairs would have to take place within a weekend. so a shop maybe would have to be a possibility for some of the more advanced jobs
Old 06-19-2017, 11:53 AM   #6 (permalink)
Member # 34987
Save some $$$ and do the work yourself. The front end can be done in a weekend if not much less. The only thing you'll need a shop for is an alignment.
1 TON SAS'ed C1500 ECSB on 37s
axisT6 is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 12:44 PM   #7 (permalink)
Member # 678914
I think i have decided to keep and repair after hearing the advice on this thread and talking with my uncle who is a lot handier at automotive repair than I am. I guess now the question is any tips for doing this work. I dont have a lot of the specialty tools but do have an autozone near by that rents tools, and i dont have an air compressor in the garage.
Old 06-19-2017, 02:16 PM   #8 (permalink)
Member # 135683
Air tools usually just make the job easier/faster but not required. I would say grab a can or two of PB blaster and spray all the parts you plan to work on a day or two before the planned day and hit them once on the day. The pitman arm and ball joints are probably going to be the tough ones but if you can get the puller and ball joint press tool you should be ok. I like to measure the alignment before tearing truck apart and then try to put it back together close enough to drive it to shop without too much trouble.
350TacoZilla is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 02:52 PM   #9 (permalink)
Member # 198851
Suspension work on a not too rusty truck is easy if you have the tool to R&R ball joints without dicking around...
Naked frame LSR bikes, dressed in animal hides clinging to machines propelled by fire
ADChevy4x4 is online now   Reply With Quote Quick reply to this message
Old 06-19-2017, 06:13 PM   #10 (permalink)
Member # 130483
Look into loaded control arms
They are not much more then 2 bushings and a ball joint
But they save you alot of time and frustration if you dont have the right tools
Steering is easy,you will want a heavy duty puller for the pitman arm
Do not leave the steering wheel unlocked,there is a cable inside that breaks if you accidently spin the wheel to much
Dont cheap out and use new ubolts on the rear
If the front calipers use torx bolts make sure to clean the hole out with a pick,they may look clean but they are not and you will strip them
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote Quick reply to this message
Old 06-20-2017, 09:05 AM   #11 (permalink)
waynehartwig's Avatar
Member # 35700
IMO it's a $2k truck. Unless there is an attachment to it, buy another.
Hartwig Motorsports 4516, Team Yukon Gear and Axle
10% PIRATE COUPON CODE (not valid for harnesses and PCM tuning): pirate4x4
Special thanks to: My Family and Friends, Yukon Gear and Axle, DynoMAX Exhaust, AllTech Motorsports, Radflo Shocks, PAC Racing Springs, JM Rigging Supply, Reid Racing, Rugged Radios, Trail-Gear, Life-Time LED Lights, RuffStuff Specialties, Randy's Racing Transmissions, A1 Performance Converters, Maxxis Tires, Jesse Haines Fab, CBR Performance, PRP Seats, Exhaust Solutions, DiffsOnly.com, and 150Tunes.com
waynehartwig is offline   Reply With Quote Quick reply to this message
Old 06-20-2017, 09:11 AM   #12 (permalink)
Member # 198851
But once he does repairs, it may be better than another truck he can buy for the same money he's got into it...
Old 06-20-2017, 09:15 AM   #13 (permalink)
Member # 35700
Maybe... He does know THIS truck and what it needs, vs an unknown truck. That's his decision. He already wants to replace the truck. Now is a good time, IMO
He could also do a lift kit that includes most of the parts....
Old 06-20-2017, 10:53 AM   #14 (permalink)
Member # 232666
If it's that nice, he should bring it to the murder mitten and part it out to make quadruple what it's worth
Originally Posted by 03f350
... Well first off FUCK JEEPS..
sterlingfire is online now   Reply With Quote Quick reply to this message
Old 06-20-2017, 11:00 AM   #15 (permalink)
Not Ashtray's dad
Member # 200478
I commuted daily on a crotch rocket here in Washington in all weather other than snow and ice. 35 degree rain blowing sideways included. Man up, buttercup.
isbj60 is offline   Reply With Quote Quick reply to this message
