NP203 vs. NP208 ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2004, 07:36 AM   #1 (permalink)
Member # 27766
Send a message via ICQ to dieselpower1980 Send a message via AIM to dieselpower1980 Send a message via Yahoo to dieselpower1980
Question NP203 vs. NP208 ?
Hi there fellow 4wheelers. I come to you with a question I've been trying to find some help on answering. I have a '82 Silverado with the NP208 transfer case. I have had no problems with it, yet. I have to replace the transmission this weekend. Here's the problem. The truck originally had a 700/208 combo. Now it has a 350/208 combo. The 350 has the 2wd output shaft and an aluminum adapter to keep the original length correct so the driveshaft will fit still. I have another combo I just got yesterday out of my parts Blazer. It is a 350/203 combo. The 203 has a part-time conversion inside, although I am not sure which kit it is. Instead of tearing the trans down <which I'm perfectly capable of> and changing the output shaft, I could slide the 350/203 combo in and just change my rear driveshaft. I ask you guys which you would do in my case. And please, no 205 comments as I've been trying to find one but nobody has one cheap around here, so I'm stuck with the 208 or 203..I don't do alot of hardcore wheeling. Every now and then I do hit the mud and sandpits and do occasionally pull soneone out or down the road. I guess I could be classified as a Weekend Wheeler..Any ideas or suggestions are greatly appreciated! Have a good day!
Chuck
1982 Silverado 6.2L/TH350/NP208/10b,12b 3.42/35" RVT's
dieselpower1980 is offline   Reply With Quote Quick reply to this message
Old 05-26-2004, 08:43 AM   #2 (permalink)
Member # 26436
203
Go with the 203 and you will already be set to do a doubler down the line, the 203 is much stronger, I have gone through 3 208 until I switched to the 203 and now I am waiting for the funds to do a doubler
55chilly's is offline   Reply With Quote Quick reply to this message
Old 05-26-2004, 09:01 AM   #3 (permalink)
Member # 27766
Talking Cool
Cool beans, I thank you 55. I do still have to find a driveshaft still; I actually have one but it's a bit longer and I may have to shorten it, but I'll ride on the front end for a few days since I won't be going but a few miles a day. Will the front driveshaft bolt up like normal? I do have the one from the 203 anyways, so I guess it don't matter. Finding driveshafts around here sucks too; actually there are ppl but they won't come off them haha.
Chuck
Old 05-26-2004, 09:13 AM   #4 (permalink)
scout_on_38s's Avatar
Member # 28684
So does this mean you have a 208 you may be getting rid of? I'm swapping chevy goods into a scout and want to keep drive angles low, so the smaller 208 is what I prefer. Shoot me a good deal... and I'll take care of shipping.
scout_on_38s is offline   Reply With Quote Quick reply to this message
Old 05-26-2004, 10:19 AM   #5 (permalink)
Member # 17568
Chuck
Well here's another thought.
Here every one will steer you in the extreme way, if you noticed they suggested the doubler down the road.
The 208 is a strong unit and for what you want, it's more than enough.
If you don't need to change driveshafts with the 208 I would go with it.
IceMan
imiceman44 is offline   Reply With Quote Quick reply to this message
Old 05-26-2004, 10:29 AM   #6 (permalink)
Member # 27766
Talking Ok guys..
First off, Iceman, thanks for the suggestion. I definitely wanted to keep the 208 for the low gearing, but I just don't want to have to tear into the tranny to change the output shaft. Although I can do it, just figured to save time AND have a stronger case..Humm, hoping I will have this all figured out by Friday b/c that's when I'd like to start on it.
Scout_on_38s : I will definitely shoot you a good deal, either that or just make a decent offer; however, everything depends on what I finally do on Friday, but if I go with the 203 I will get back with you most definitely!
Chuck
Old 05-27-2004, 11:13 AM   #7 (permalink)
Member # 28684
Sounds great, just let me know.
Old 05-27-2004, 11:20 AM   #8 (permalink)
Member # 7406
Send a message via AIM to Jeff_Super_S
I'd stay with the 208 also. I have run one in my truck for a couple years now, and I run the shit out of it. Its in a light vehicle, but it hasn't missed a beat yet. The low range is great in it too compared to the 203, and with the gears and tires your running that low range will really help you.
s-15 with oversized tires, and mods....
Jeff_Super_S is offline   Reply With Quote Quick reply to this message
Old 05-27-2004, 12:09 PM   #9 (permalink)
Member # 27766
Talking Thanks ya'll
I guess I'm going to go ahead with the 208 since I won't need to change my driveshafts. Although I didn't wanna go into the transmission, I guess I can check the condition of the clutches while I'm in there. I reckon I'll just keep the 203 as a backup just incase. It's funny how much trash I hear being talked about the NP208, however, even though it's behind a diesel engine, it has held up very well. Even after pulling a partially loaded dumptruck out of the sand hill near here. I reckon the worse thing for a 208 is either mis-matched gears and hitting the case on something, either of which can result in a cracked case. Since I don't live near rocks I ain't worried too much. I thank you all for the replies and any more that may come after this!
Chuck
Old 05-27-2004, 03:52 PM   #10 (permalink)
ken
Member # 9
Consider this...the new Dodge and Ford diesel trucks use aluminum chain driven transfer cases like your 208 (241s?)...and those cases last behind the 600 ft. lb. Coomins motors....
ken
CJ5, CJ8
K30 Suburban +8", 37s
V30 dually crew +12", 42s
1960 GMC Suburban 4x4
1964 GMC Suburban 4x4
ken is offline   Reply With Quote Quick reply to this message
Old 05-27-2004, 04:49 PM   #11 (permalink)
Member # 27766
Talking yes
Yes, this is true. I should have thought of that, would have been a sense of comfort The 241's are "supposedly" stronger than the 208's, but like I had said before, it's working fine in mine, so.....Thanks
Chuck
Old 05-27-2004, 08:04 PM   #12 (permalink)
Member # 10807
i hate 208's, it's embarrassing on what i broke my tcase on...i split in completely around the hole case and it was spewing everywhere, just from holding the gas pedal to the floor over some tires.
snoop dogg is offline   Reply With Quote Quick reply to this message
Old 05-27-2004, 11:12 PM   #13 (permalink)
Member # 27766
Lightbulb ok
Well for now at least I reckon I'll stick with Mr 208. I did some figuring on crawl ratios and with my 3.42 gears I know I'll be better off right now. I'm gonna use the 203 as a spare, and maybe one day as a donor for a doubler setup if I can find the adapter set cheap enough.
Chuck
Old 05-28-2004, 09:07 AM   #14 (permalink)
Member # 7406
When you look to doing a doubler down the road check out Staz Works. He is in the vendor forum. I just got mine from him and its quality stuff and it only cost $450. He even makes them for the more common 27spline 205's, so you don't have to spend another $200 for a 32 spine input and machine the case, if the 27spline is all you can find or have.
Old 05-28-2004, 12:28 PM   #15 (permalink)
Member # 27766
Cool
Jeff, thanks. I will definitely make sure I check into that when I go that route. B/c I did see the doubler adapter for $700!! Anyways, thanks!
Chuck
