327 or 350??????????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-18-2002, 12:30 PM   #1 (permalink)
Member # 5393
I need some help figuring out which engine i have. The casting number on the block is 3970010 which indicates it's a 68 327 or a 69-79 350...
So how do i tell the difference between a 327 and a 350 w/o pulling the thing apart and measuring the stroke?
TIA
Jonathan
Jonathan M is offline   Reply With Quote
Old 01-18-2002, 01:37 PM   #2 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
You can't. Maybe if it has the original heads and/or manifold, you might be able to tell from those casting numbers, but there is no guarantee that they are original.
Chances are the engine is a 350.
If you can get me the casting number off the heads (it's under the valve covers) I'll see if I can tell anything else about it.
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote
Old 01-18-2002, 02:28 PM   #3 (permalink)
Hillbilly's Avatar
Member # 857
I'm pretty sure that it is a 350. With the last 3 digits 010. I got two 350 blocks that have that as the last 3 digits. I got an article somewhere that tells more about the casting numbers. I'll see if I can find it.
Hillbilly is offline   Reply With Quote
Old 01-19-2002, 08:21 AM   #4 (permalink)
Member # 8647
Cool
You could always pull the oil pan off and get the casting #'s off the crank, that'll tell you what you have.
Chevy powered Jeeps, what more can one ask for!
CHVYPWR is offline   Reply With Quote
Old 01-19-2002, 02:46 PM   #5 (permalink)
Member # 4826
You can measure the stroke with a dial indicator through the spark plug hole.
Dan
Dan Gleason is offline   Reply With Quote
Old 01-21-2002, 10:39 PM   #6 (permalink)
Member # 2416
GO TO WWW.MORTEC.COM FOR INFO AND TO CHECK CASTING #'S
atroader is offline   Reply With Quote
Old 01-24-2002, 01:18 AM   #7 (permalink)
Member # 8886
Wink casting numbers
I have been adding casting numbers to my site, slowly but surely.
a sure fire way to tell what you have without taking anything apart is the suffix codes.
there are some numbers and letters right behind your alternator, on a stamp pad that sticks out from the block.
i know by experience that if the stamp pad is long and thin, its a 350, a short stubby pad is a 350 or 327.
but get the numbers off of that "pad" right on the block where the heads meet the block, in the front, on the passenger side, right below/behind the alternator.
the suffix codes i have at my site are at
http://trak.to/chwk4x4
click on : chevy small block casting numbers
good luck
chwkblazer is offline   Reply With Quote
Old 01-24-2002, 01:21 AM   #8 (permalink)
Member # 8886
1 more thing
if you go to amazon.com you can search for chevy #'s books, they have everything. if you want a book of your own.
i plan to add everything to my site someday
Old 01-24-2002, 04:16 AM   #9 (permalink)
Member # 5393
Thanks everyone. I measured the stroke and it turns out it is a 350 afterall. Now for the rebuild.......
