Question about chevy flat-tops - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-04-2004, 12:46 PM   #1 (permalink)
Member # 16838
Hello chevy guys, I got a question for you guys about the visual difference between chevy knuckles, here goes:
I have a guy local that has piles of old chevy axles and I want to pull a set of knuckles to do hysteer on my jeep. The only problem is that I don't know how to determine which knuckle I need. I was told that I needed knuckles from a 1/2T truck from 76 and older. The problem is that the axles are all in piles away from the trucks so I have no way of telling the years. Are there any ways to tell which years the axles are from? Are there any telltale signs of which flat-tops I need, all I know is it has to be 1/2T and 76 or earlier model years. Thanks guys, hopefully someone can help... thanks, Judd
79 cj 7, lift, 360, and 33's for now... yeah hardcore...
Judd is offline   Reply With Quote
Old 08-04-2004, 01:39 PM   #2 (permalink)
sled_dog's Avatar
Member # 22932
Send a message via AIM to sled_dog
uhh there is one big telltale sign... a flattop.... no but seriouslly thats it. Look at the passenger side knuckle(if you can't figure out which one is which leave the sport now), and if there is a big flat shoulder on it same as the driver side, that looks like you could put a steering arm there, then thats what you need. Sold all the ones I had so I can't get pictures someone will have some. The newer ones just have a little flat spot next to the balljoints and its obvious a steering arm couldn't be mounted there.
sled_dog is offline   Reply With Quote
Old 08-04-2004, 02:04 PM   #3 (permalink)
Member # 16838
Dammit, I went and looked at them and the driverside has the flat-top area with the draglink bolted to it but the pass. side doesn't have the shoulder, crap. Anyone have any pics????? thanks guys, I don't care what the ford guys say you guys are alright!!!
Old 08-04-2004, 11:47 PM   #4 (permalink)
Member # 25738
Send a message via Yahoo to big83chevy4x4
this is the pass side knuckle, the driver side is all the same. also they only came on the d44 knuckles.
big83chevy4x4 is offline   Reply With Quote
Old 08-05-2004, 04:28 AM   #5 (permalink)
Member # 16838
sweet, thanks, judd
Old 08-06-2004, 05:53 AM   #6 (permalink)
mj
Member # 1919
the top side doesnt tell you much
the under side will have bosses in the area you need to drill for studs
mj is offline   Reply With Quote
Old 08-06-2004, 10:29 AM   #7 (permalink)
Member # 16838
that definitely helps, thanks, judd
Old 08-06-2004, 09:29 PM   #8 (permalink)
Member # 16608
Originally Posted by Judd
The only problem is that I don't know how to determine which knuckle I need. Are there any ways to tell which years the axles are from? Are there any telltale signs of which flat-tops I need
Go here Flat top Knuckles, good info.
'88 Zuk
TatorZuk is offline   Reply With Quote
