***Glitterbomber***
Member # 6483
14 bolt brake line question ...
I changed out my broken 10 bolt for a 14 bolt full floater. The brake lines on the 10 bolt both go to a common pull point on the drivers side, the lines that are on this 14 are both the same length and I dont know what to do with them.
Do you know of a solution to connect the 14 bolt to the same point where the 10 bolt did ?
" Put on your seatbelt .... I want to try something " AxleSnapper Bulletin Board AxleSnapper Website |
***Glitterbomber***
Member # 6483
Oh yea ...
Its an 88 suburban ... duh
Member # 7039
_________________________________________________
Get you a "Stainless Steel Braided" extended brakeline and hook it to a differential bolt or L bracket and run new hardlines to that. That should work fine __________________________________________________ Could be wrong here, but I think he is talking about an e-brake cables. 1 Ton axles have e-brake cables that match later model Blazers and go down the drivers side. The 3/4 tons have a center attachment point. There are several solutions that can be found by doing a Search on CK5.
1 Ton Lifted and Stroked Jimmy. Last edited by Derf00; 01-25-2002 at 04:38 PM. |
#5 (permalink) | |
***Glitterbomber***
Member # 6483
The e-brake cabes are the problem. There is also a shock placement problem but I can fix that with a new mounting system. I don't get this "Search on CK5" please explain Thanks Dave
***Glitterbomber***
Member # 6483
Thanks, That should help ...
