Bombing 6.5 Diesel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2004, 10:56 AM   #1 (permalink)
Member # 22955
Building 6.5 Diesel
I know there have been plenty of posts on this subject, can someone please point me in the right direction. The search button ain't working for me for one reason or another, me and computers don't work well together. I would like a little info on the potential of these engines before I go ahead and buy this truck, I already know about the problems they have. Thanks in advance.
FordCarnage is offline   Reply With Quote Quick reply to this message
Old 11-12-2004, 11:18 AM   #2 (permalink)
Juice's Avatar
Member # 24306
Send a message via AIM to Juice
hey man, ur topic has nothing to do with what you just wrote? wtf mate? a little more info would help...
82 K5, 6.5L diesel, 35's, welded rear.. work in progress
Juice is offline   Reply With Quote Quick reply to this message
Old 11-12-2004, 11:36 AM   #3 (permalink)
Member # 22955
Sorry, I need some threads on what to do for performance on a 6.5 diesel. I shouldn't have wrote "bombing" but I wanna try to make around 400/650 or so. Before anyone says buy a mechanical Cummins it's the price that is talking to me on the Chevy. Turbo and fuel system upgrades, and who makes the kits. That's all.
p.s. please don't refer to me as mate.
Old 11-12-2004, 12:02 PM   #4 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
Sorry, I don't know who to talk to on the turbo terd performance. That was just too funny for me though
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Your ORI strut dealer along with about anyting else you need!
team Nasty co dog
blacksheep10 is offline   Reply With Quote Quick reply to this message
Old 11-12-2004, 12:49 PM   #5 (permalink)
Member # 22955
Yeah so anyway I will add some more info. Truck is a 93 3500 SRW reg cab 4x4 with a 5 spd. It just turned 130k and has already had the injector pump replaced (guess he didn't know he could just change the pcm for it). For $4,000 I think the thing is a steal.
Old 11-12-2004, 02:50 PM   #6 (permalink)
Juice's Avatar
Member # 24306
that sounds like a good deal.. get a banks turbo, the computer chip, an exhaust, maybe some internals and you'll be good ... mate! haha, sorry its an inside joke.
Old 11-12-2004, 03:10 PM   #7 (permalink)
ddestruel's Avatar
Member # 20999
I thought 93 was mechanical injection.
Get a Girdle for the bottom of the crank, ive head re-aligning the bores of the block helps too.
Port the shit out of the heads and O-ring the heads too that will help with preventing popped head gaskets then stud the head vs the bolts. When you go to a Turbo, the Bnks is a good place to start but i seem to recall that the guys who were really playing with these were putting a different intake fan on and larger exhaust housing or doing some combination of parts to up the potential of the forced induction system.
Forged Rods and Marine pistons if you really want to push some ponies but otherwise keep the boost below 20-25 psi and i think you'll be fine, turn the injection pump up, then adjust timing i think you loosen it and crank it toward the passenger side to increase timing. There are also some extrude honed injectors out there also.
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET
But i Vote
GO UM Montana Griz
"Jeep Lurker"
KEEP REMEMBERING 9/11
Jeep with Rambler motor, SUA,
and some
I miss my
Support Frank the Tank
ddestruel is offline   Reply With Quote Quick reply to this message
Old 11-12-2004, 03:41 PM   #8 (permalink)
justscoutin's Avatar
Member # 32053
if you increase the timing on it, you'll blow the head gaskets off for sure(thats what i've been told). put a cummins holset turbo on it, 4" exhaust, and a large intercooler. kennedydiesel sells piston kits to lower the compression so you can push alot more boost on it.
88 chevy crewcab 6bt nv4500
72 scout 4bt on tons
justscoutin is offline   Reply With Quote Quick reply to this message
Old 11-12-2004, 08:28 PM   #9 (permalink)
jac6695's Avatar
Member # 24174
You aren't going to get that power out of a 6.5. Google search for Heath Diesel and Kennedy Diesel. Call either of them. You can maybe get 300/500, but it will cost a lot. BTW, I have a 97, ATS 3" exhaust, intercooler, K&N, and Heath programming and it does well towing my Blazer, but isn't a D-Max or Cummins.
James 86 S10 Blazer LT1/4L60E/203/205 Doubler/D60/14B
11 Chev Silverado Dmax, 97 GMC 2500HD 6.5
jac6695 is offline   Reply With Quote Quick reply to this message
Old 11-14-2004, 05:13 AM   #10 (permalink)
Member # 613
so what do you guys think would be a reliable power output for one of these engines that will see some daily driver duties plus alot of hauling? I have the lower half of two 6.5's that supposibly need reboring. I haven't gotten around to actually measuring them myself or not. Also have a good set of 96-97 6.5 heads ready to go. Is any year head any better than the other years? Where is a good place to look into the marine type pistons? I have checked the local auto parts store and have came away with not many answers for these engines or prices that I think I could buy a running engine for.
odee is offline   Reply With Quote Quick reply to this message
