6.2L/SM465 ... possible? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-15-2004, 09:41 AM   #1 (permalink)
Member # 29957
Any suggestion on how to put a mid 80's 4spd behind a 83' 6.2l diesel. All I can find is autos behind that engine.
Will a 6.5l flywhell work or am I SOL. The truck currently has a blown 350TBI with SM465 and I don't really want to convert to a auto.
[COLOR=Blue][SIZE=5]Extreme[/SIZE] ... Life's to Short Not Too Be[/COLOR]
02' Tundra Limited Access Cab - 2.5" fabtech dirt logics, 3" body lift, 285/75R16's, Heated Seat
dkirkup is offline   Reply With Quote Quick reply to this message
Old 11-15-2004, 10:15 AM   #2 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
I don't know about the 6.5 flywheel interchange but I have seen a factory 6.2/4spd 4wd before.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
happy..happy..happy....
nvrenuf is online now   Reply With Quote Quick reply to this message
Old 11-15-2004, 10:18 AM   #3 (permalink)
Member # 29957
oh really ... my search for parts conitues than ... maybe I need to us a better beer filter to find the right info
Old 11-15-2004, 12:44 PM   #4 (permalink)
Member # 32948
I had an '84 K20 with that combo - very nice..I think they went to hydruolic linkage in '85, 84 was mechanical.
PartTimeAdult is offline   Reply With Quote Quick reply to this message
Old 11-15-2004, 01:23 PM   #5 (permalink)
Member # 35037
For the flywheel, try www.peninsulardiesel.com ! This is where I got mine from. I have a 6.2/sm420/3speedcase in my FJ40. These guys are great to deal with. Just a satisfied customer-blah, blah, blah.....good luck.
Diesel40 is offline   Reply With Quote Quick reply to this message
Old 11-15-2004, 08:41 PM   #6 (permalink)
Member # 4243
Stick/diesel never came in the Suburban or Blazer.... its a pickup exclusive.
I got my 6.2L flywheel at an autowrecker. Try www.car-part.com
You can also get new from Napa, Lordco, or whatever the parts stores are called in your area.
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 11-15-2004, 10:31 PM   #7 (permalink)
Member # 29957
That's correct ... I have a 4spd/205 from an 83' 1ton that I am going to be using
Do you know if I can use a "J" type flywheel on a "C" type engine. There is a flywheel from a J engine back east but nothing in canada for a C type. Trying to stay away from cross boarder rip offs
Old 11-17-2004, 07:01 AM   #8 (permalink)
Member # 18610
Send a message via AIM to Budru
I am currently putting a 6.2 in my sm465 equipped Blazer. The bellhousing and motor mounts are all the same, the only swap specific items I think I will be buying are the flywheel and the clutch. There were two different single mass flywheels made, the lighter one is 49 pounds and im not sure how much the heavier one weighs. I think the same clutch can be used with either. Avoid the dual mass flywheel which I believe came out in 95. Other than that Im pretty sure the 6.2 and the 6.5 flywheel is the same. I got my flywheel from Partsamerica.com They sell reground flywheels for a decent price and I didn't have time to go scrounging.
let us know your findings
Good luck mang
Budru is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 08:44 AM   #9 (permalink)
justscoutin's Avatar
Member # 32053
my stuff came that way factory. works great. only custom thing you'll need will be the flywheel and clutch. everything else works. i've seen flywheels on ebay also. just gotta be patient or do the car-part.com thing. only difference in J code and c code is the emissions and intake.
88 chevy crewcab 6bt nv4500
72 scout 4bt on tons
justscoutin is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 11:02 AM   #10 (permalink)
Member # 29957
I can get a 88' 6.2'L flywheel/clutch/presure plate from an 88' 1ton 5 speed I think "J" ... will that work on my 83' 6.2L "C"? I am thinking so
Also, I should be able to take the EGR S$%T off the engine for some more ponies. Any other suggestions, loose the intake resinator, 3" free flow exhaust (maybe dual)
Old 11-17-2004, 12:16 PM   #11 (permalink)
TNScrambler's Avatar
Member # 10818
Send a message via AIM to TNScrambler
Yes, the "J" code refers to HD or Non-emissions, the "C" code is light duty and has a big fat EGR right in the center of the intake. That is the only difference in these motors just the intake....some earlier versions had different valves, but a flywheel will interchange for both. Most Suburbans and Blazers will have "c" codes as they are light duty, where as most 3/4 or 1 tons where "J" code as they were 8600 GVW and over.
Justin
random parts stashed in various locations that might someday become part of a Jeep ;)
TNScrambler is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 02:37 PM   #12 (permalink)
Member # 29957
Alrighty then ... just placed the order of a flywheel. I found out that clutch, pressure plate and through-out bearing are the same as the gasser. So my current bellhousing clutch assembly will work. I am all ready to convert my 2wd 350 crew cab into a 4x4 6.2 diesel. Should a couple of weeks to complete the swap. I think that I am going to swap in the Jimmy harness until I can find a diesel burb harness
Old 11-17-2004, 07:40 PM   #13 (permalink)
Member # 20564
How did this project turn out?
86 Topless Turbo Diesel Trooper SAS SOA Custom Alum Dash, Cage, Dana 44 front, Detroit ezlocker, Zoo 12 bolt rear Lincoln Locker, cherokee springs, Alum radiator, 36" Super swampers, Stack & Snorkle, VDO gauges
2001 Dodge Ram 2500 4x4 Cummins Superchips, K&N, TST j-hook, transgo VDO gauges
AirTrooper is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 07:57 PM   #14 (permalink)
Member # 18610
Are you sure the gasser clutch will work? I was thinking that I was going to have to buy a diesel clutch for some reason
Old 11-17-2004, 08:52 PM   #15 (permalink)
Member # 4243
The disc and pressure plate are the same part numbers wether its for a 350, 6.2L diesel, or 454. I've also laid my 350 clutch ontop of the 6.2L flywheel and the holes line up.
Old 11-18-2004, 06:40 AM   #16 (permalink)
Member # 29957
u2slow is correct ... I got this information from NAPA they list the same part number for a 350 and 6.2 clutch pack.
Old 11-18-2004, 06:41 AM   #17 (permalink)
Member # 29957
Still in the gathering parts phase ... actually, once I get the flywheel in my hands I will have everything I need.
