TBI 454 cam recommendations - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-11-2004, 02:30 PM   #1 (permalink)
LilWes278's Avatar
Member # 16733
Send a message via AIM to LilWes278 Send a message via Yahoo to LilWes278
While my engine's getting rebuilt, I'm gonna take this opportunity to slap a mild (READ: smog legal) cam in it. I'd like to see what you guys suggest. It's basically a stock TBI 454 (but I'll probably put a chip in it later), anybody have any recommendations?
LilWes278 is offline   Reply With Quote
Old 12-12-2004, 10:05 AM   #2 (permalink)
b454rat's Avatar
Member # 16536
I haven't done my TBI 454 yet, but a couple years ago I built a TBI 406 and used Comp Cams Xtreme Energy 268. I didn't trip any lights, and ran like a mother fucker!! I did use a High Energy 268 in a carb'd 454 in my old truck, and than ran real good. Would easily smoke the 35s with 3.73s in it. But I couldn't tell you on the emissions, they don't have that here, yet. Sorry.
b454rat is offline   Reply With Quote
Old 12-12-2004, 11:00 AM   #3 (permalink)
Buckshot33's Avatar
Member # 31228
hydraulic flat tappet or hydraulic roller? if its TBI it should be a roller but I wanna be sure.
What year is the block?
'68 scout 800, TPI 383/700r4 D44's '66 K20 383/400/205 60/14
'62 nova 406/th350. 11.40's @ 118
Buckshot33 is offline   Reply With Quote
Old 12-12-2004, 11:10 AM   #4 (permalink)
Member # 5162
Location: If you drink enough, you will forget it is Iowa
TBI's were flat tappets. Hydro Roller's didn't start until the Vortec MPI in 96.
"26 chicks all tied in a knot. Aint all good but it's what we got"
rodzzilla is offline   Reply With Quote
Old 12-12-2004, 04:55 PM   #5 (permalink)
reddman's Avatar
Member # 39492
make sure to use a fairly mild cam, otherwise the thing wont run. tbi motors need a good vaccum signal to run, higher lift and shorter duration will net u the best results, more flow while maintaining driveabilty. my buddy put 2 hot a cam in his and the computers stock programed parrameters cant figure out why the thing wont read much of anything with the map sensor. and i know the small blocks went to roller hydraulic lifters about 1987, but im not sure when the bb's upgraded to roller.
reddman is offline   Reply With Quote
Old 12-12-2004, 05:15 PM   #6 (permalink)
Web Wheeler For Hire
Eagle-Mark's Avatar
Member # 26999
When your looking for a cam see if it has recomendations for TBI. Something like an RV cam.
Keeping the specs under 214o intake duration @ .050" and 224o exhaust duration @ .050" will still run with a TBI in most cases.
Addicted and Obsessed with Fuel Injecting Anything!
GearHead-EFI.com
Eagle-Mark is offline   Reply With Quote
Old 12-14-2004, 09:30 AM   #7 (permalink)
reddman's Avatar
Member # 39492
this man speaks the truth. if u want more power beyond that get rocker arms with a higher ratio, that will net u lift (read: flow) while maintaining vaccuum (read: it will still run). tbi 454s have terrible compression, like 7.5:1, have a machine shop face some off your heads to bump that up, it will help tons!
