Should I swap or wait? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2005, 08:59 PM   #1 (permalink)
dott's Avatar
Member # 31603
Subject vehicle:
78 GMC 4x4 longbed 1/2 ton 4x4, installed 5.7L TBI Dec 04, currently running 32" BFG on stock axles (d44 front and 12bolt rear with 3.07). Rear shackle flip w/56" springs, front 52" springs.
Usage: Some DD, lots of off-road, mild rock crawling.
Goal: bigger tires (probably 35"), lower gears and more clearance (longbed).
I have a lead on a set of axles. 10b front 3.73 8 lug and 14 bolt SF rear 3.73 for $250.
I think the 14bolt SF is an upgrade over the 12bolt.
Definitely like the 3.73's.
How does the 10bolt compare to the D44?
Overall, is it worth the time/money/benefit?
[url=http://www.texas4x4.org/gallery/dotts-stuff]'78 GMC @ Texas4x4.org[/url]
dott is offline   Reply With Quote
Old 01-27-2005, 10:13 PM   #2 (permalink)
Member # 36385
of course it is since im the one that got the axles your wanting LOL
Big4x4Rides is offline   Reply With Quote
Old 01-27-2005, 11:21 PM   #3 (permalink)
Member # 35269
d44 is about the same as a 10b
14bsf will be stronger than 12b
but you may want to look at deeper gears, 4.10s would be better, but since you this would be a offroad heavy truck, i would say go as deep as you can
of course you can just plan to do a gear change too...
Mechted is offline   Reply With Quote
Old 01-28-2005, 03:34 AM   #4 (permalink)
dott's Avatar
Member # 31603
I forgot to mention. The "wait" part. The plan is to eventually go to Rockwells. I can't do that swap right now because the truck is still used as a DD. This seems like a good intermediate step until then. If I do this I'll have to get different wheels and, of course, bigger tires. Will the Ujoints fit?
Old 01-28-2005, 07:54 AM   #5 (permalink)
Member # 35269
no. but there are conversion ujoints for that... well until you blow up your driveshafts anyway, then you can up grade the whole driveshaft
Old 01-28-2005, 10:01 AM   #6 (permalink)
Member # 19358
I say go for it, they are basically a bolt on other than some conversion u-joints. It will be worth the time just to have the fourteen bolt in the rear. The money is minimal, because you should be able to turn around and sell the axles and get your money back for them. As for benefit, the lower gears and the 14 bolt is a huge good upgrade for the day it will take you to do the swap.
just my .02.
'76 Scout II Buggy. 4 link rear, leaf springs in the front,dana 70HD rear, dana 60 front w/ 7.17 gears. Tom woods custom drive shafts front and rear,full hydro steering(rockstomper),chevy 350, 700r4, 203/205 doubler(northwest fab). Lots of other goodies.
Jeeps are for girls!!!!!!
ParaP14 is offline   Reply With Quote
Old 01-28-2005, 10:10 AM   #7 (permalink)
packnrat's Avatar
Member # 31529
gears
the 14 bolt is a very good axle, use the D44 or the 10bolt as they are sameo sameo.
as to doing the dd thing go very low gears (5. somthing) and a over drive or get a under drive and get 4.10 - 4.56 gears. the 4.10 for general runing, the 4.56 for playing in the rocks.
packnrat is offline   Reply With Quote
Old 01-28-2005, 04:42 PM   #8 (permalink)
dott's Avatar
Member # 31603
I'm trying to get the most bang for the buck here. I don't want to swap gears or anything until I'm ready to go heavy duty (Rocks). I think for the amount of driving this truck will see, 3.73 gears with 35 tires will work pretty good. Besides the details, I'll have to scrounge up some 8 lug wheels.
