Member # 21889
k10 10bolt front question
i hope this hasnt been covered. i got a 10bolt front from a late 70s k10 blazer that i mistakenly thought was a d44 to swap into a jeep. unfortunately, i took it apart before i measured it. i think the wms should be 67.5 from what ive bben able to find. and the same carrier for the 3.07 in it will work for 4.56s? does that sound right? im trying to decide if i wanna go ahead with it or dump it and find a 44 instead. not many jeep guys seem to use 10bolts, so i was wanting to verify my info first. thanks.
better to be dead and cool...than alive and uncool Last edited by cwend; 02-08-2005 at 05:55 PM. |
the wms on the 10 bolt is the same as the chevy 44, everything from the knuckles out is interchangeable, as for the carrier split, im not 100% on this, but i think its around 3.73. the carrier from the 3.07 should be different... as ai said, im not certain, i dont do much with the small rears
Member # 25796
Go here....
http://www.ringpinion.com/content/te...lt.asp?pid=129 As far as 10b vs. 44 I would think you would have to narrow it no matter what so you may as well stick with what you got.... |
#6 (permalink) | |
Member # 21889
i think i may end up staying with the 10bolt i have then. the shaft sizes are about the same as a 44. 28 vs 30 spline. i run 36s and will be putting a lockright in, but i dont wheel real hard. the benefit to cutting a 44 down 4" on the long side was to be able to use junkyard waggy shafts(they are 4" shorter than a chev) but i can always find a couple 10bolt shafts and have em cut for spares. its not that expensive i suppose. but then again, cant go lower than 5.13 with 10bolt.
better to be dead and cool...than alive and uncool |
Member # 42018
I put a D44 upfront of my 4runner. I had custom chromoly shafts made for it b/c the "goose neck" defect of stock axle shafts scared me. I currently run 35" MTR's and wanna upgrade to a 36"-38" Super swamper tire. If you're using a 10 bolt in the rear, get a "FULL FLOAT" kit for it. some shop in MA makes them. $800.
#10 (permalink) | |
#13 (permalink) |
not to stir any shit, but wouldnt a 10 bolt front be technically full floating anyways? haha sorry just had to say it, so like above said, get a ff 14 bolt and disc it, i did mine, works great. alot cheaper and stronger then a ff 10 bolt, and i believe you can do 6 lug if that was an issue.
97 Cherokee 2 door 5 speed 6 cylinder. 02 F250 PSD 265k detroit locker and go fast parts |
#14 (permalink) |
Member # 41764
Think before you type. A 10 bolt is a semi floating axle, done.
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5 Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between No one is ever gone if they are always remembered. JasonPayneMemorial |
#15 (permalink) | |
Member # 21408
#16 (permalink) |
No He Said Front Read The Title Of The Post
-------------------------------------------------------------------------------- i hope this hasnt been covered. i got a 10bolt front from a late 70s k10 blazer that i mistakenly thought was a d44 to swap into a jeep. Um he said a REAR 10 bolt
91 GMC jimmy rear SAS 9 in rear 5:13 spool, d44 hp front 5:13 locrite, 35' maxis buckshot, custom bumpers etc..... 04 gto DD |
#17 (permalink) | |
Member # 41764
