Member # 38212
67-72 tire fitment
What size of tires are you 67-72 guys running?, with how much lift? Will 38"x14.50"s fit with a 6" lift or is 8" needed? I would kinda like to see some pic's if anyone has any.
Newbie
Member # 37888
6" will be fine, I run 6" with 39.5" IROKS. Just bust out the sawzall and start making them fit. I don't have pics right now but I am someone else will. 8" is way too big
1970 GMC, d60, 14bff, Trail ready's, 39.5" IROKS, sm465, Doubler, TBI, PRP seats |
Member # 38212
I don't intend on using a sawzall.It is almost totally rebuilt. I want to start with a nice truck and have no problem wheeling it hard but I don't want to cut up new sheetmetal. I was just curious how far I could go without a saw and 5 1/2"-6" of lift. I am just thinking that 35"s are a little small.
Banned
Member # 29016
i have some of my buddies with 6-7 lift and 35" procomps. he can stuff the tire and there is not much room. give me some place to email them to and youll see how tight a fit they are.
Newbie
Member # 37888
when my truck had a 4" with 35's i thought it looked too small and they stuffed fine. if you want 38's do the 8"
Beaver Pleaser
Member # 13645
6" will get you on 38's but you'll chew up the tires when turning over rough stuff or flexing. To get the best fit you'll want to relocate the axles to the center of the wheelwells. Front needs to go forward 1-2" and the rear needs to go back about the same amount. Also you will have to radius the front of the rear wheel opening..
1972 GMC Submarine 383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez Inclined to brute force attack a 70* incline with a Quadrajet 1997 GMC K3500 Suburban TC76 L33 / 4L80E / HP60 SAS / PROJECT TOWHOE |
I know its prolly too big for your tastes, but heres mine on 38s, with 14" in the front, 12" in the back, ill level it one of these days, lol.
Memories of my Blazer:[URL=http://community.webshots.com/user/k5monsterchev] K5[/URL] 2001 Dodge Cummins HO |
Member # 38212
So some 37"x12.50" should work well with 6". I'd like to go bigger but I haven't gotten around to getting a nv4500/205 yet,kinda $$$.I currently have a 420/Rockwell.Very short front shaft. Don't want to build 2 sets of shafts.
Member # 25665
I had a 72 K20 with an 8" skyjacker lift on it, and ran 38.5x16x16.5 TSL's and the only thing I had to do was roll the point under on the front fenders about 1/2", that was the only place it would rub when I turned sharp both ways. I never had a problem with the truck even out 4 wheelin.
1972 Chevy K20 pickup 14" All Susp. and 44's 1988 Chevy V30 Crewcab longbed 10" and 38's |
Member # 34756
With33up tires, the most often hit spot on the front is the lower front fender foward of the wheel, usually in a stuffed turn. IOW, the cup at the bottom. One can take the curve out of the inside of that inner cup plate (that completes the cup) to gain some clearance without altering the outer body lines. Trimming the very bottom point helps even more. I think extended bump stops can prevent much rubbing, as well, but that goes against the go-along-to-get-along-so-I-don't-get-flamed opinions of most Pirate members. I'd extend the bump stops about 1" for every 3" of lift, though suspension cycling should drive the amount they're extended.
<>< Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing. |
#12 (permalink) |
Moving your front axle an inch or two forward will allow you to clear some bigger meats and give you a better front drive shaft angle. 9" of lift and my front axle moved 2" forward and I can clear 39.5"s at full stuff with no rubbing or fender trimming.
Dale _____________________________________________ [QUOTE=Entropy]Please, Rip isn't big enough to make me mumble. I could sing the Star Spangled Banner without a skip sucking Rip's dick.[/QUOTE] Last edited by Smash-K20; 02-24-2005 at 08:52 AM. |
#13 (permalink) |
Member # 15502
I've got a '72 K5, 6" and 38"x14.5" Gumbo Monsters (
, they came on the truck ) and trimmed about 3/4" from the front bottom of the front fenders. To make it all look normal, before I cut, I drilled out the plug welds and removed the bolts so I could pull the inner fender away, then made my cuts with the sawzall, touched it up with the grinder, then took a BFH and bent the inner fender back to where it met up with the outer fender/wheelwell. It looks stock, but to clean it up even more it wouldn't be hard to weld the inner fender to the outer one along that seam, then grind the welds down flush and repaint it. The rear tires rub a little bit at full stuff, but I think the BFH and a little bit of massaging with a grinder/sawzall will give me the extra ~1/2" I need in the rear. If you're set on running 38"s, you could always get a 6" lift, then use ORD's Zero-Rates to both move the axles to the middle of the wheel wells, and to get another inch of height. |
#14 (permalink) |
Member # 38212
No one has pic's of one with 37"s,huh? Would like to see how much room they have before I order them. If they don't have adequate room with 6" I will jus get 35"s. 35" seem small though.
