Can you bore a 400 SBC .060? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-11-2005, 04:17 PM   #1 (permalink)
Member # 14455
I have been looking for a 400 for a while now and have been burned on 2 so far (1 cracked block/1 guy trying to tell me a 305 has the same casting number as a 400). I have found another one that has been rebuilt in the last 4 years and the reciepts are there and the crank is still good but it was bored over .030 already and now I am hoping that it can safely be bored out another .030 (.060 total). I know that this would turn from the current 406 to 412 if it is possible.
Jay
Sapper is offline   Reply With Quote Quick reply to this message
Old 04-11-2005, 10:48 PM   #2 (permalink)
Buckshot33's Avatar
Member # 31228
yes its possible. no its not advisable. I wont bore a 400 over .040 total for a street engine. race engines sure, just run it till it cracks but not a street engine.
'68 scout 800, TPI 383/700r4 D44's '66 K20 383/400/205 60/14
'62 nova 406/th350. 11.40's @ 118
Buckshot33 is offline   Reply With Quote Quick reply to this message
Old 04-12-2005, 06:44 AM   #3 (permalink)
TEX
Member # 603
Is it really in need of an overbore or just rehoning? Mine is .040 over & I don't have any issues with that, but I don't think I'd wanna go .060 if I could avoid it.
TEX
Thanks to:
Extreme Performance
Bear Creek Auto Recyclers
TEX is offline   Reply With Quote Quick reply to this message
Old 04-12-2005, 07:26 AM   #4 (permalink)
Member # 4243
I'm told bore deflection becomes an issue beyond .030". The shop I worked at wouldn't even consider building one if the block didn't clean up at .030".
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 04-12-2005, 12:05 PM   #5 (permalink)
Buckshot33's Avatar
Member # 31228
This might be true but most 400's i've seen that could go .040 made it ok. We have had some trouble with cracking the blocks when we bore them though. we've also had blocks crack between the head bolt holes and steam holes.
Old 04-12-2005, 05:54 PM   #6 (permalink)
Member # 18610
Send a message via AIM to Budru
What about just sleaving the block back to factory specs? Any drawbacks to sleaving a 400?
0]====={__}=====[0
Budru is offline   Reply With Quote Quick reply to this message
Old 04-12-2005, 06:39 PM   #7 (permalink)
Buckshot33's Avatar
Member # 31228
sure you can sleeve a 400. where abouts are you located, I know a shop in redding that just finished sleeving a 400 for a buddy of mine. came out bitchin.
Old 04-12-2005, 07:03 PM   #8 (permalink)
Member # 14455
Thanks guys. I guess I will see if they can sleeve the block around here and how much it costs. I may have found a source for a couple of other blocks that if they are untouched I will go for first. These 400s seem to be quite a challenge to locate around here.
Jay
Thanks again
Old 04-12-2005, 07:18 PM   #9 (permalink)
Member # 33591
I dont get it, i know the cylinders are siamesed on a 400 but how the hell do they get small block 454's and bigger from a 350? is it all stroke? and you just bore to the very maximum and then just stroke it from there? not much of a small block guy i guess, and if you sleeve one you would have to bore it to the maximum then push the sleeve in and you are right back to stock bore, what good did that do?
Pablo88401 is offline   Reply With Quote Quick reply to this message
Old 04-12-2005, 07:49 PM   #10 (permalink)
Member # 4243
I'd like to hear the answer on sleeving a siamese-bore block.
I don't think its possible. I thought you had to grossly overbore first, sleeve it, and then bore the sleeve to the desired size.
Another trick to stroking is offset grind the rod journals for a rod with a smaller big end. IIRC, early SBC rods get you .010" more stroke this way... I think its a certain Mopar rod that have an even smaller journal. GMPP has SBC blocks with a raised cam so you can swing a bigger, custom crank in there.
Old 04-12-2005, 11:22 PM   #11 (permalink)
Buckshot33's Avatar
Member # 31228
I've seen SBC's up to 482 inches. its scary.. its done with custom tall deck blocks from people like dart (the little M tall deck) These blocks come with a 4.125 (stock) bore. if you take them to 4.185 (.060 over) and put a 4.125 crank in them you get 453.9" They also make SBC blocks that can safely be bored to 4.25 (stock 454 bore) then you put a 4" crank in them (stock 454) and you basically have a small block 454 with the same bore/stroke as a big block 454.
as for siamese bores being sleeved, any aftermarket alluminum block you buy, (like a donavan big block chevy) is siameesed bores and they all use ductile iron sleeves. when the sleeves are wasted you just re-sleeve and start over. as long as the cylinder case is true you just keep re-sleeving. you do the same with a 400 block. you bore the piss out of it and install new sleeves. My buddy has a fully sleeved 400 in his race car right now. good to go. I can call my buddy and get the 400 sleeve part numbers if you want.
Old 04-12-2005, 11:36 PM   #12 (permalink)
Buckshot33's Avatar
Member # 31228
http://www.hotrod.com/techarticles/e...113_0309_test/
There is a quick article on a 454 sbc of the 4.25 bore 4" stroke flavor.
