Member # 8133
Meet Up in Disney Ok June...
All right for the record. ... who all is going to attend this one. Post a pic of your junk too so we can figure out whos going. Im tryin to plan this out ahead of time so I can make it. I need to hook up with my P town boys and get wild
![]() EDIT:: Im out... Ill be going to Greyrock the weekend before this for a Superlift ride Its cheaper and closer.
LCQ / KOH 09 Co-Driver #62 Midwestwheeler / Hardline Custom Last edited by Pdaddy; 04-24-2005 at 04:56 PM. |
Vertical Limits
Member # 26443
here is an idea to start off with....
me ![]() curt and the ZR2.5 ![]() Ben ![]() others will chime in I hope. banshee, miller, jeff, where you at?
Kelly Kaiser Vertical Limits Inc 913.731.3040 Atomic Fabworks (my new full time shop) www.atomicfabworks.com 913.839.8450 Your ORI struts, Solid and Rod End Supply dealer! team Nasty co dog. FINISHED KOH |
Vertical Limits
Member # 26443
Don't forget THIS guy
Kelly Kaiser Vertical Limits Inc 913.731.3040 Atomic Fabworks (my new full time shop) www.atomicfabworks.com 913.839.8450 Your ORI struts, Solid and Rod End Supply dealer! team Nasty co dog. FINISHED KOH Last edited by blacksheep10; 04-22-2005 at 03:32 PM. |
Vertical Limits
Member # 26443
How about wyatt (woodywag), he will be there. here is a pic of him and I have another pic of his rug, it just isn't on this computer. I believe that is what he will be rolling in all weekend. It is a big one
Vertical Limits
Member # 26443
well.........
I took the sheep out last night. climbed a hill that no one else could ben broke on it on his third try I made it on the first try So, cocky as I am, decided to unlock the rear and cut some reverse donuts, broke another factory outer. 3 wheel drive I was,.... doing 1 wheel burnouts on the roof of a car. then I decided to test my cage out. 20ish mph across the hay field, hung a left, rolled it on purpose. My cage was golden from all the other roll overs, now, not so good. crushed the A pillar way in, no glass will ever fit again, it is a 1 seater now. then, got back to camp. I just put this 400 in yesterday morning. guess what. during the roll I stayed in the throttle. Broke the fawking case in half this time at the rear when a tire hooked. tally, crushed cage, broken tranny, broken front end, my left front tire sits at a 10 degree angle now, is that bad on a 60? it was a borrowed tranny So I guess that I will be rolling with curt now unless I get the cab pulled back out. Pics to follow, but the digi is at a family gathering right now.
Member # 8133
Damn... Yours broke, Miles broke, BOnes got a DUI... .what the fawk Im glad I didnt drive up to Kansas this weekend
LCQ / KOH 09 Co-Driver #62 Midwestwheeler / Hardline Custom |
WTF!!!!!!!!!!!! I leave the country for one week, and all hell breaks loose. Must be the full moon.
Kelly 1st thanks for ragging on me, I expect it. 2nd What in Sober Jeremy where you thinking? Does this mean Blacksheep 2 is getting retired? Bring it with the pics. I'll be at work nights this week starting tomorrow, I'll give ya a shout then. Thanks for the 400 shell for the '58 mock up. EDIT: Damn Bones!!! What happened? That sucks none the less, so sorry to hear johnny law caught up to ya. Last edited by BigWoodyWag; 04-25-2005 at 10:53 AM. |
Vertical Limits
Member # 26443
okay, the roll was pretty hard, but like I said, on purpose. .120 wall hrew
anyway, on to the pics the side load on the rear end from landing cracked my link crossmember/shaft loop ![]() pushed the rear end a little sideways (spring not staight now) ![]() started roll on the right front, most grass ended up in the left rear bead ![]() WAS a new tranny ![]() drug the rear on some pretty big rocks before the flop. don't think I can shave it enough to not drag on the pinion
#12 (permalink) |
Vertical Limits
Member # 26443
more fun, cab damage
not too bad ![]() looks like glass might still fit! ![]() okay, maybe not ![]() there you go, most likely not ![]() the only bar that gave up was above the pass head. No breaks or tears, no broken welds, just a bend in the middle of the bar.
Kelly Kaiser Vertical Limits Inc 913.731.3040 Atomic Fabworks (my new full time shop) www.atomicfabworks.com 913.839.8450 Your ORI struts, Solid and Rod End Supply dealer! team Nasty co dog. FINISHED KOH Last edited by blacksheep10; 04-25-2005 at 03:17 PM. |
#13 (permalink) | |
Vertical Limits
Member # 26443
it should have been ready to rock. new hummer tires on the back, all shiny, sexy. so anyway, he backed off the trailer and ran into his gism (geo prizm) and cut a tire in the first 100 feet. No problem, run it flat, it is a hummer wheel right! wrong. run it nowhere when the intermediate housing breaks clean in half and the transfer case falls OFF the back of your tranny. How cool is that. Looking up in there, it wouldn't have been long anyway. the splines on the back of the tranny were so worn they looked like knives. they were about to strip off. ended his night. Ben. oh man, that was too awesome. he has always known that his rear shaft is the only weak link left. 1330 at the case, 1310/1350 cross joint at the rear end. The injected engine/bulletproof350 from mud racing/203/205/60 front with 1410 shaft are all ready to rock. the pussy rear shaft hooking it all up to that 14 bolt wasn't. I made the hill look stupid with a carburator. He bouced on it a few times before I climbed up and spotted him. Had him lined up very nicely, he got his fronts up on the huge rock ledge at teh top and gassed it when the rear shaft let go. Funny thing is that since the twin stick he has a valve on the rear brake lines for front digs. He had it off with the rear wheels free. Meaning no rear brakes if he pushes them. the hill was steep enough that with teh fronts locked he took off pretty damn fast down the hill backwards screaming at everyone to get teh hell out of the way. a tree caught him by the left rear and spun him sideways. good times. Mine. I don't know whether it was a full moon or my need to show off in front of big crowds. I have a good guess as to which it was, though As far as the sheep getting retired, I think that I will cut the top of the cab off, make the A-pillar bars on both sides out of .180 wall and get a new roof to weld on. I want that truck to make it the rest of the year. Buggy this winter. If not chopping the cab, I am going to run it as a 1 seater for the summer. Bones.......Well, we went to Rounders after the party and we both got shitty. He walked back to Mile's house, I stayed and drank. Mindy called me sometime after close while we were still sitting there drinking and said she was going up to bail him out did I want to ride. I was saddened by it. He said he was going to walk to mile's and crash on the couch. I guess after he got there he felt good enough to drive. happens to the best of us I guess. Anyway, yes, all hell did break loose in P-town. 5 trucks rolled at the party. Wyatt, no problem on the 400 case. Problem is, I might need it back sometime in the next year if I keep breaking them
#14 (permalink) |
If those pics aren't an ad for why you need a cage.......
Maybe all the MiCo guys like Clunt Graham, Pete, and crew will rethink wheeling sans rollcage. Glad your ok. I was thinking about all the time my head has spent right around the vicinity of where the upper bar is right now, and its kinda unsettling. |
#15 (permalink) | |
Member # 8133
Kelly rolled his just to put on a show for all the drunken teenage girls ....and Miles...
#16 (permalink) |
Member # 3007
My head hurts, have a bruised shoulder, knee and lower back. It was a great time. Thought I was going to die in the Gism though
![]() Got a DUI, that SUCKS, but it'll be okay I guess. Not the first to get one. No Kubota buy back for me
Today is the tomorrow you worried about yesterday |
#17 (permalink) |
Member # 8133
Kelly has had one!!
![]() Miles too matter of fact.... damn im the good one outta the bunch thats odd!!
#18 (permalink) | |
Member # 3007
#19 (permalink) |
Member # 26530
Location: In the middle of bumfuck and you got a pretty mouth
Dam I'am gald that I Pussed out and went home when I did. Bones I thank that you have the biggest balls that I have ever seen. Way I say this is you willing to get in with that mad man(Blacksheep). Props for being so brave
#21 (permalink) |
Member # 8133
Is Kelly still runnin the 4 runna springs in the rear of that thing? They look HELLA short in that one pic.
Ben, keep me posted on how you do with what we discussed on the phone last night... Im interested to hear specifics on what you change and its affects.
#23 (permalink) | |
Member # 8133
#25 (permalink) |
Vertical Limits
Member # 26443
there is sooooooooooooooooooo much life left in the blacksheep
Just needs cut at the A adn B pillars and a new cab top put on. Bones, you must be friggin old. I didn't feel a thing. It could be ready for disney in a matter of a day and a half or so. Have good glass and more tube out behind the house. Don't want to retire her yet, too much sentimental value. Too many survived rolls Curts is back after I put in 2 cages for people next week. Can't wait!
