Member # 9575
Hard shift into reverse turbo 400
Lately after the truck is at normal operating temperature, and after a good drive, when I put the truck in reverse it sounds like it shifts pretty hard, with a clunk and a jolt, only in reverse though, and only when the truck is warmed up, it doesnt do it when the truck is cold, anythoughts?
1981 chevy 4x4 3/4ton 350/400 Blzn74
Find'em hot, leave'm wet. |
#3 (permalink) | |
Member # 3694
Re: Hard shift into reverse turbo 400
You might wanna check to see if your rear end has "excessive slop" in the axle......Good Luck.........
Member # 1282
Check you flex plate to torque converter bolts. Alos take a look at your U joints...Whens the last time you changed your tranny fluid and filter? Is this a 2WD or 4WD truck? This could add a few more things to check........
