Stumbling off idle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2005, 11:58 AM   #1 (permalink)
Member # 32546
Stumbling off idle
Truck Info: 1987 K5 with TBI 350...auto.
My truck has just started doing this after a trip to the Hammers. Basically, it runs ok, but when you go to accelerate, it stumbles and sputters off idle...as you slowly build speed, it then seems to clear out and runs fine at speed...all seems to be just off idle.
Now, some background - the last trip to Hammers saw my gas tank getting crushed by a large rock...I was able to drive the truck home (150 miles or so) with no issues. But next time I drove it, this all started. Now, I replaced the fuel tank this past weekend, replaced fuel filter...fuel pump seems to be fine. Maybe it is coincidental with the gas tank getting crushed, but truck was running fine before that trip??
Anyone have any ideas? I was told to check the TPS sensor on TBI, anyone know how to do this? I know it is something with checking voltage, but never done it...could it be a vacuum leak? Timing? I'm hoping to get the truck running well enough to make it to the mountains this weekend... Thanks for any help you can give me!
k5blazerkeith is offline   Reply With Quote
Old 05-25-2005, 03:13 PM   #2 (permalink)
Member # 32546
No ideas??
Old 05-25-2005, 04:49 PM   #3 (permalink)
Member # 16608
Originally Posted by k5blazerkeith
No ideas??
Before you get carried away with anything else...try unhooking the vac line to the EGR...then go test drive...see if there is a difference in the problem.
Try this first...then I'll tell you how to check the TPS.
'88 Zuk
TatorZuk is offline   Reply With Quote
Old 05-25-2005, 04:52 PM   #4 (permalink)
Member # 32546
Ok, will do...replaced the EGR a few years ago, but those things seem to go bad a lot...thanks. I'll post up my results tomorrow...I assume that this will just set a SES light, will it affect driveability in any other way??
Old 05-25-2005, 05:47 PM   #5 (permalink)
reddman's Avatar
Member # 39492
I would put $ on it being the engine coolant temp sensor. they are 10 bucks and will fix damn near any problem a tbi motor has.
reddman is offline   Reply With Quote
Old 05-25-2005, 05:55 PM   #6 (permalink)
mj
Member # 1919
throttle tip in is a Manifold Pressure change and a Throttle Position change
start there
mj is offline   Reply With Quote
Old 05-25-2005, 06:09 PM   #7 (permalink)
TNToy's Avatar
Member # 5776
A blow to the bottom of the tank could've knocked some crud loose and partially clogged the fuel filter. Just a thought.
Start with the suggestions from the guys who know bowties though. I dunno jack about TBI.
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
Old 05-25-2005, 06:42 PM   #8 (permalink)
reddman's Avatar
Member # 39492
its basically the same thing as the volume knob on your home stereo. as it rotates, the resistance goes from 0 ohms at one end, up to a set point at the other end.
stick an ohmeter on there and watch what the resistance does as you open the throttle. if it has a dirty patch on the resistor film, then it could cause an open circuit between the slider and the rest of the circuit.
when checking the resistance it will most likely be constant between the 2 outer leads on the plug, and will vary between the center lead and the 2 side leads (as its rotated) only.
Old 05-25-2005, 07:10 PM   #9 (permalink)
mj
Member # 1919
the joys of computer controlled crap
Old 05-26-2005, 11:17 AM   #10 (permalink)
Member # 32546
Well, I fooled with the EGR and TPS stuff, no difference. On a whim, I decided to check the timing...as I went to adjust it, the distributor hold down bolt was loose...checked the timing, it was about 6-7 degrees retarded! I know I have heard that these computer controlled motors are supposed to be set to "0" degrees, then plug the computer wire back in and it takes it from there.
However, the motor ran better with a bit more timing...it ended up feeling best at 5-6 degrees advanced...is this ok? I went and drove it and it was like night and day! I could almost chirp the tires from a standstill (which is a major feat in this near 7000lb K5 with 38.5s!) No more stumbling, no more hesitation...more power all around.
So, can I safely run with the 5-6 degrees advanced timing with no issues? Do I have to run Super Unleaded or anything? Thanks guys, it seems to be running great now...
