chevy 3/4 ton 4x4 axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-09-2005, 05:11 AM   #1 (permalink)
Member # 33569
Will the front and rear axles out of a 71 bolt right in a 78 chevy 1/2 ton? Thanks butch.
butch32 is offline   Reply With Quote
Old 06-09-2005, 08:46 AM   #2 (permalink)
panty dropper's Avatar
Member # 23462
Send a message via MSN to panty dropper
I dont think so, and even if they did I wouldnt do it. 67-72 chevy parts cost about twice as much as 73-91 parts and are a lot harder to find and order, so I would say just wait and find the right axles.
89 yota/3.4 swap/auto/33 stt's
87 runner/3.4 swap/33 toyos
78 chev k30/400/th400/44 swampers
77 chev k20/400/th350/36's, no lift, lincoln locked front and rear
79 blazer-getting piratized as we speak
84 runner/9 inches taller,3.4/auto/crawler etc soon
[url]http://www.myspace.com/slater442w30[/url]
panty dropper is offline   Reply With Quote
Old 06-09-2005, 11:17 AM   #3 (permalink)
Member # 21461
Send a message via AIM to thundr undrgrond
the front will and the back just needs the springpads moved. in 71 u should have the open knucle disc brake 44 and a 60 in the back, good combo, but id look for a 14 bolt, 60s arent that strong
thundr undrgrond is offline   Reply With Quote
Old 06-09-2005, 11:25 AM   #4 (permalink)
Member # 38212
No it shouldn't be a D60,{only if it was a GMC would it be}it sould be an Eaton.There weren't very many D60's in Chevys.Much stronger than a D60.The pad width's are different but it would be a very good rear end.I have 4 or 5 of them.Thats what I run and will run in all my wheeling trucks.
1967K10 is offline   Reply With Quote
Old 06-09-2005, 09:53 PM   #5 (permalink)
Member # 21461
i kinda thought it might be an eaton, but i wasnt sure if they were still using them in 71, or if they had gone to just the 60 then, cause i know the 14 bolt wasnt used until 73s. the reason i thought id be a 60 is my neighbor has a factory 3/4 ton 72, and that has a 60 in the rear
Old 06-10-2005, 11:41 AM   #6 (permalink)
Member # 38212
I've just parted a 72 K20 that had an Eaton.There were a few that got D60's but not very many.
Old 10-20-2010, 09:17 PM   #7 (permalink)
Member # 171838
Axles
Will the newer front 44 and 12bolt rear from a mid 73 and newer. Work in my 67. Or do I have to find 67-72 4x4 parts
67 swb is offline   Reply With Quote
Old 10-20-2010, 09:20 PM   #8 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
did you not read the first responce?
you will have to move the rear pearchs. the front will bolt in.
Old 10-20-2010, 09:26 PM   #9 (permalink)
Member # 171838
Where do they need to move to. I want to keep the springs I have. I'm new to this so don't know all the ins and outs like other people.
Old 10-20-2010, 09:29 PM   #10 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
measure the pads on the axle.
if they dont match the spread of the springs cut them off the axle and reweld to match the springs.
Old 10-28-2010, 08:42 PM   #11 (permalink)
Member # 171838
I mearured my old rearend and the new one. Both measure out at about 42". From what I can see it doesn't appear that I need to move anyhthing. Am I missing something. Old rearend is from a 72 new rearend is from a 78 jimmy.
Old 10-28-2010, 09:12 PM   #12 (permalink)
just4cuz's Avatar
Member # 98655
If they measure the same it will bolt in. Might need different u bolts and spring plates if axle diameters are different.
just4cuz is offline   Reply With Quote
