14 bolt locker with 4 posts and a spring? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2005, 07:37 PM   #1 (permalink)
I'm on Team People
bgreen's Avatar
Member # 9801
Question 14 bolt locker with 4 posts and a spring?
I pulled the diff cover off my 1991 chevy 1 ton 3x3 Crew Cab 6.2 diesel and found something interesting to me. There is some sort of locker inside the 4 pin carrier that uses what appears to be a very large diameter external spring on both halves of the locker. This is not a gov lock. It is a 4 post/pin carrier just like you would find on an open diff. If you put the truck up on jack stands with the tranny in neutral you can spin one tire and watch the sides half of the diff ratchet, and as soon as your try to reverse rotation you can see the half pop into place and lock.
Turning out of my driveway you can feel the thing positively lock, but it doesnt chirp the tires (that could be because of the crappy worn out tires on the back of the truck). Power braking always spins both tires.
I've never seen or heard of a 14 bolt locker that uses an external spring that you can see through the "windows" on the carrier. Any idea what it is? Is it a factor option, or just an aftermarket locker? Is it any good/reliable?
Sorry for the somewhat newbie post, but I've pulled apart a dozen 14 bolts and never have come across this kind of diff.
Project Freak - Resurrection
bgreen is offline   Reply With Quote
Old 06-20-2005, 08:02 PM   #2 (permalink)
Smores!
Scott@Rockstomper's Avatar
Member # 1889
Sure sounds like a Detroit to me, other than the "not chirping tires" thing.
That's the only 14b diff I've ever seen that you can see the springs on it. Maybe can you take a picture of it?
Scott@Rockstomper is offline   Reply With Quote
Old 06-20-2005, 09:14 PM   #3 (permalink)
I'm on Team People
bgreen's Avatar
Member # 9801
So the detroit uses a single spring that goes around the outside of the diff, just inside the carrier? I've only installed semifloat detroits, so Im pretty clueless on this one. I'd take a pic, but those windows are pretty damn small and hard to see through even in person, and I have to button the thing up tonight so I can drive it to Anchorage tomorrow.
Old 06-20-2005, 09:24 PM   #4 (permalink)
I'm on Team People
bgreen's Avatar
Member # 9801
Never mind I finally found a picture of the 14 bolt Detroit, and from what I can see in there, that is most likely what I have. Sweet!
Now If I can just find a way to change the gears into a 41:10 instead of the damn 41:11
Thanks for the quick assistance scott.
Old 06-21-2005, 01:16 PM   #5 (permalink)
Member # 29210
Send a message via AIM to Davethorik
A while ago, I asked on CK5 how to tell a Gov-Lock apart from an open (DL) carrier, and everyone there insisted that if it had a detroit there would be the springs you are talking about.
However, neither the 14 bolt, nor the Eaton H052 that are in my possession, have the spring. Both have DL's and both are identical except spline count.
:laughing:
Davethorik is offline   Reply With Quote
Old 06-21-2005, 09:05 PM   #6 (permalink)
85mudblazin's Avatar
Member # 42745
Send a message via AIM to 85mudblazin
you can see the spring where you used to be able to see the spiders
512 Motorsports #4419
-Chris
85mudblazin is offline   Reply With Quote
Old 06-22-2005, 12:43 PM   #7 (permalink)
Member # 29210
What was that? You are a fucktard? Yeah, I thought so.
#1 is the 14 bolt- Sure don't see a spring, fella.
click
#2 is the Eaton- again, it must be another of those "invisible" springs.
click
:laughing:
Old 06-22-2005, 01:24 PM   #8 (permalink)
Member # 42745
14bff??
I must be seeing things or something cause this sure as hell looks like a spring to me...
Clicky
-Chris
Old 06-22-2005, 04:21 PM   #9 (permalink)
Member # 20909
Send a message via AIM to K5MONSTERCHEV
Thats right you can. Heres mine, on the left side you can see the spring, sort of a bad pic.
Memories of my Blazer:[URL=http://community.webshots.com/user/k5monsterchev] K5[/URL] 2001 Dodge Cummins HO
K5MONSTERCHEV is offline   Reply With Quote
Old 06-22-2005, 06:37 PM   #10 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
whether you were right or not, no reason to be a douche with the rolleyes
I didn't see a spring in dave's pics, I didn't see one when I bought my last detroit equipped vehicle, but I didnt' look that close.
if you can hear the ratchet and chirp on corners, almost no need to crack the cover
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Atomic Fabworks (my new full time shop) www.atomicfabworks.com
913.839.8450
Your ORI struts, Solid and Rod End Supply dealer!
team Nasty co dog. FINISHED KOH
blacksheep10 is online now   Reply With Quote
Old 06-22-2005, 09:35 PM   #11 (permalink)
Member # 42745
He was making reference that the people on CK5 were wrong and that he was right cause he didnt see any springs.
Ill take back my roll eyes
-Chris
