Cried, then laughed, then grabbed the grinder - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2005, 07:48 AM   #1 (permalink)
Member # 48446
OK Ive been working on cars and trucks for quite awhile now. This was a stupid mistake. I had put 2 new tires on my Blazer then a month later it took a big dump on me. So then I got a 73 K20. It came with 16.5 inch rims. My Blazer had 15 inch. I bought 4, 8 lug 15x10 wheels and 2 more tires. Took it all to the shop. Later on I get a call. Guy from shop tells me... "good news is your tires are mounted, bad news is they dont fit!!" The front wheels are hitting the caliper. Well Im thinking I just wasted money on wheels and tires, so I take it home and try to put 'em on. Almost on. So I spend the rest of the evening grinding caliper and mount and got the wheel on. Tonight I'll do the other side and will be good to go. I guess the worst part is I tested a wheel on the rear before I took 'em to the shop, but for some reason didnt think of trying the front. I know this!!!! :doah:
Trailblazr81 is offline   Reply With Quote
Old 07-20-2005, 09:48 AM   #2 (permalink)
Hanr3's Avatar
Member # 33482
You almost had it right.
Every once in a while we all need to make dumb mistakes to keep us in check.
Just yesterday I couldn't figure out why the courtesy lights wouldn't go out. I started testing all the switches only to discover the rear hatch dome light has a switch and it was on. DOH!!!!
blah blah blah......
Hanr3 is offline   Reply With Quote
Old 07-20-2005, 10:48 AM   #3 (permalink)
American's Avatar
Member # 12257
Send a message via AIM to American
if your truck is a K20 and not a K30, then you shouldn't have had any problems fitting 15x10's
EB Truggy on 39.5's - FOR SALE $6,000 obo
TopOffroaders buggy by CBfabwerks: in the works
5.3, th400, np205, hp60, 10.5", 18" CO's, 43's, H1's
American is offline   Reply With Quote
Old 07-20-2005, 10:51 AM   #4 (permalink)
Member # 27040
Send a message via AIM to HickTrucksRus Send a message via MSN to HickTrucksRus
American Not true 3/4 calipers/hubs do not alow 15x10s to fit
lame 88 2door xj.
HickTrucksRus is offline   Reply With Quote
Old 07-20-2005, 10:51 AM   #5 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
you sure about that american?
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Atomic Fabworks (my new full time shop) www.atomicfabworks.com
913.839.8450
Your ORI struts, Solid and Rod End Supply dealer!
team Nasty co dog. FINISHED KOH
blacksheep10 is offline   Reply With Quote
Old 07-20-2005, 04:53 PM   #6 (permalink)
Member # 9191
I have put 15 inch wheels on 4 different 3/4 ton front axles and had to grind the calipers on all of them some more than others. On a side note I tried to put some 15 in wheels on a 8 lug 9.5 semi floating 14 bolt with the bigger brakes and the wheel would not fit they hit the drums.
overkill48 is offline   Reply With Quote
Old 07-20-2005, 11:02 PM   #7 (permalink)
Member # 45052
You will need grinding. This is on a '95 Bronco that I just put a ford D44 HP solid in, with chevy 8 lug outers and 15x8 wheels (4.25" BS). Had to grind the caliper and bracket. Not a bunch, I have no worry about safety. But no way it would fit without grinding. Same brakes on D60 rear, so same grinding of calipers at all corners.
TheJuice is offline   Reply With Quote
Old 07-20-2005, 11:38 PM   #8 (permalink)
boxxerace's Avatar
Member # 35359
I have put on 15 x 10s on a 3/4 dana 44 and they fit. The same rims also fit on a 14 bolt ff. Noticed some minor scraping in the high points in the paiint... so yah.. its really close on the front end!
[COLOR=RoyalBlue][FONT=Georgia][SIZE=1]Bob the Builders got nothin on me[/SIZE][/FONT][/COLOR]
boxxerace is offline   Reply With Quote
Old 07-21-2005, 07:49 AM   #9 (permalink)
Member # 48446
Well after spending a couple evenings after work grinding, I got the wheels on. Backs were no problem. It wasnt fun tho. I can definately feel it in my hands, I dunno how people can do this all day every day.
Old 07-21-2005, 09:16 AM   #10 (permalink)
Member # 23853
Send a message via AIM to DarkEternal Send a message via Skype™ to DarkEternal
I do it every day - trick is to have a good grinder that doesnt vibrate. If I use a cheapo one at work I will feel it, if I use my craftsman 7" then not a problem - just soar forearms because its not light.
DarkEternal is offline   Reply With Quote
Old 07-21-2005, 09:25 AM   #11 (permalink)
Member # 48446
Well Im using a Craftsman thats pretty old. Got it from my grandfather. Use 4"-5" discs. I should probly get a new one. Only $$$$ Right!!!
