Member # 46072
I need vacuum the easiest way possible. I have a chevy 383 and its only pulling 13 inches at 1000rpm. Here are a few details you might want to know.
The cam I have - 112 center line 498 - 510 lift corrected 1.6 ratio = 530/542 lift. 228/230 dur @ 050 The intake I have - Edlebrock RPM The carb - 770 Holley truck avenger The heads - Dart severe duty 2.02/1.60 valves ... 1.25 springs 7 degree super locks comp cam parts.3/8studs guide plates.gasket match p.c seals.chrome moly retainers Keith black hyperutectic.S.I. pistons 9.8 to 1 piston set I need 15 inches of vacuum at 1000rpm, what is going to be my easiest way to get it? Ive played with timing and gotten nowhere so far. Any ideas???? |
#4 (permalink) | |
Member # 9991
Roller cam: With the motor you've explained. Why not run a roller valve train. Drop down to a Comp Cams extreme 4x4 with 218 degrees of intake duration at .050. This will give you the streetability your looking for, but allow you to still have some upper rpms. Keep the 1.6:1 rockers as these only make a slight difference.
[url]www.scotthansen.net[/url] |
#5 (permalink) | |
Member # 46072
My goal is not really to make it streetworthy at all, I want it as hot as possible, I am being disqualified from mud drag racing for not pulling enough vacuum. As far as power building, Ive got pleanty as it is and dont really want to lose any trying to get my vacuum back up to meet regulations. I do already have roller rockers if thats what you mean, I thought a roller cam might be the next step in the equation. |
#6 (permalink) | |
Member # 9991
Just remember the closer the LSA the more power you'll get, but with a shorter powerband. I guess I'm wondering if you shouldn't be down towards a 110, or even 108 LSA. Does your sport use tight LSA's with less duration, or is 112 ok with more. I run 113 LSA with 210 @ .050 with .317 lobe lift for .507 total, but I had them grind it at 112 intake centerline to keep my upper RPM's. call comp in any event, it can't hurt.
#7 (permalink) | |
Member # 603
TEX
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
#8 (permalink) | |
Member # 46072
I talked to them and they said that the cam I have SHOULD be able to pull 15 inches at 1000rpms and that I likely have a vacuum leak elsewhere. My problem is I have no idea where? I took either and propane and went around the carb and everywhere on the intake I could think of to try and find a leak and came up with nothing. Not sure what to do now.
#9 (permalink) | |
Member # 46072
I talked to them, they told me it should be fine. I do not understand, I thought they would at least try to sell me something. |
skullfuckery
Member # 29016
hey leslie, you should not be in the stock class. stock is the only class that does a vacume test.
you should be in at least ssv8 or unlimited. even then that setup is pushing it in ssv8. you can try a vacume pump or a vacume canister.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#12 (permalink) | |||
Member # 603
TEX
#13 (permalink) |
Member # 603
BTW, one could certainly argue that Leslie & those quicker trucks don't belong in the lowest class. Most of the Illinois events run a class even lower than that with even stricter engine swap & vacuum rules. But, I've found the better rigs in that class to be very competitive in Street Stock anyway. So, I just went with the one class.
TEX
#14 (permalink) |
Member # 46072
I do not want to jump up a class, heck I only got 3rd in the stock class. But the guys that beat me probably shouldnt have been in stock class either
I called crane, they didnt help much. I will call them or summit racing again and hopefully get a different technician this time. Im pretty sure I need a new cam, if a roller makes the difference, I will definately take that route. |
#15 (permalink) |
skullfuckery
Member # 29016
i got put in the ssv8 class and tagged third place and i am no where near this setup. i think one of 2 things happend, no one hot showed up except one, he won it, or the classes were way off from what you guys call ssv8.
#17 (permalink) |
Member # 5110
Get a set of quick bleed lifters like Rhodes. They will bleed off some of the duration at lower RPM and might give you that extra vacuum you need. They would also be the quickest solution.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893 |
#18 (permalink) | |
Member # 46072
Ive heard this mentioned and it does sound like a decent solution to try. |
#19 (permalink) | |
Member # 4830
I agree. I ran them on my last 350 with about the same cam you have. It idled real nice. I used Crane fast bleed lifter, I had read somewhere they didn't bleed off as much as Rhodes. Hot rod magasine just did a piece on Rhodes roller lifters you should read, same pricipal. Blake |
#20 (permalink) | |
Member # 603
TEX
#21 (permalink) | |
Member # 46072
Bogs are scary! I am going to one on saturday. Which tires would you suggest? The 34x9.50 TSL's I just bought or keeping the 33x15.50 SX's on?
#22 (permalink) | |
Member # 46072
It sounds plausable, but if there is a problem with cam lobe timing to where both valves are open together for a period of time like Mr Willy's suggests, I do not see how bleeding off the lifters will make any difference. But I may not be thinking clearly yet.
#23 (permalink) | |
Member # 603
TEX
