front driveshaft - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-06-2005, 04:14 AM   #1 (permalink)
Member # 45935
front driveshaft
I just resently lifted my truck 4" and after getting everything tourqed and back in place it was time to put in my front drive shaft. I bolted it to the T-case first and then was going to bolt it to the yoke and to my suprise it was about 3" from even touching it. The driveshaft has the slip yoke on it and it was fully extended. Is this common, because 4 wheel parts said I shouldnt have to replace the driveshaft. So what options do I have, the truck is a 85 chevy with 33's and 10 bolts. This is my daily driver that will see light offroad duty because I dont want to tear it up. Im thinking of making this my toy and getting something else for the daily driveing. So in the future I might beat it harder than I will now, and have thought about doing an axel swap. Thanks for any help
85 Chevy K10 4x4 350 crate, accel distrib, street avenger carb, rebuilt 700r4, Pro Comp 4" lift, Pro Comp Shocks and braided brake lines, 33" Super Swamper TSL
berserk is offline   Reply With Quote Quick reply to this message
Old 08-06-2005, 04:22 AM   #2 (permalink)
Member # 32948
New springs backwards?
PartTimeAdult is offline   Reply With Quote Quick reply to this message
Old 08-06-2005, 04:35 AM   #3 (permalink)
Member # 45935
I have been running them like this for 2 weeks now with out a problem. It wasnt listed on the spring which way is front so I compared the two. The old ones had one leaf that wraped around the front of the spring were it bolts to the truck. And so do the new ones so thats which way I put them. Any other way to tell if there on backwards? I have been doing my own mechanic work for 7 or 8 years. And would hate to have made a mistake like that.
Old 08-06-2005, 04:51 AM   #4 (permalink)
LiftedAWDAstro's Avatar
Member # 40116
Send a message via AIM to LiftedAWDAstro
Measure the distance between the center bolt and the eyes. See if there is an offset or if they are even.
LiftedAWDAstro is offline   Reply With Quote Quick reply to this message
Old 08-06-2005, 07:07 AM   #5 (permalink)
Member # 38880
If the springs were backward I would think youd have a problem with steering linkage. I would almost think the slip yoke isnt extending all the way. My ,02$
3/4ton62gmc is offline   Reply With Quote Quick reply to this message
Old 08-06-2005, 08:29 AM   #6 (permalink)
Member # 49460
Send a message via AIM to k5freak
i have NEVER heard of a 4in lift causing driveline issues with a older chevy 4x4.
if the shaft is dry, give it some grease, its probably just stuck at the stock length.
k5freak is offline   Reply With Quote Quick reply to this message
Old 08-06-2005, 08:42 PM   #7 (permalink)
Member # 45935
I know for a fact now that they are not on backwards so thats not it. So I think you may be correct about the slip yoke not extending all the way. It was real dry when I first tryed to install it but I greased it. So is there any way to take it apart and see if the splines are all gummed up? Or should I take it to a driveline shop.
Old 08-07-2005, 12:16 AM   #8 (permalink)
85mudblazin's Avatar
Member # 42745
Send a message via AIM to 85mudblazin
If you cant see the splines they it is fine length wise.
512 Motorsports #4419
-Chris
85mudblazin is offline   Reply With Quote Quick reply to this message
Old 08-07-2005, 09:47 AM   #9 (permalink)
Member # 25230
what he said
I refuse to let ignorant, emotional "thinking" create public policy that infringes upon my constitutional rights, especially when such policy has already failed and caused the very incident thy compels the ignorant to cry for more of the same.
southern k5 is offline   Reply With Quote Quick reply to this message
Old 08-08-2005, 05:07 PM   #10 (permalink)
k5krushert1's Avatar
Member # 44208
i left my driveshafts connected when i did a 4 inch lift. my front shaft was fine on my k5 i got the 700r4 208 combo. some combos of trannys wont work with stock driveshafts sometimes. im sure it will extend to 4 inches unless you have a really odd ball driveshaft. grease it and it should extend or put liquid wrench to free it up
k5krushert1 is offline   Reply With Quote Quick reply to this message
Old 08-09-2005, 02:58 PM   #11 (permalink)
Member # 51628
Send a message via AIM to Chevy_Gal4x4 Send a message via MSN to Chevy_Gal4x4 Send a message via Yahoo to Chevy_Gal4x4
Need help!
i have just purchused a 1990 silverado 1500,it has a 454 big block,38" swampers,and my front driveshaft is out,how can i fix it or can i still drive my truck??
Chevy_Gal4x4 is offline   Reply With Quote Quick reply to this message
Old 08-09-2005, 03:27 PM   #12 (permalink)
Member # 41764
Yes you can drive with no front driveshaft
Tow Rig: 2006 Dodge 2500 610CTD/G56/NP271/AAM9.25/AAM11.5
Trail Rig: 1997 K1500 LQ9/4l80e/NP241/D60/14FF and some stuff in between
No one is ever gone if they are always remembered.
bggrnchvy is offline   Reply With Quote Quick reply to this message
