skid plates for fuel tanks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2005, 06:47 PM   #1 (permalink)
Member # 51549
is there any one makeing skidplates 4 the saddle tanks (fuel tanks) for my 87 chevy?
tailboardtech is offline   Reply With Quote
Old 08-08-2005, 07:59 AM   #2 (permalink)
Member # 34327
Send a message via MSN to jackedupjimmy Send a message via Yahoo to jackedupjimmy
Skid Plate
Make Your Own
91 GMC jimmy rear SAS 9 in rear 5:13 spool, d44 hp front 5:13 locrite, 35' maxis buckshot, custom bumpers etc..... 04 gto DD
jackedupjimmy is offline   Reply With Quote
Old 08-08-2005, 08:28 AM   #3 (permalink)
Member # 26894
Send a message via ICQ to Smash-K20
Just put some plate in between the supports for your sliders.
Here comes the part were he says "What sliders?"
Dale
_____________________________________________
[QUOTE=Entropy]Please, Rip isn't big enough to make me mumble. I could sing the Star Spangled Banner without a skip sucking Rip's dick.[/QUOTE]
Smash-K20 is offline   Reply With Quote
Old 08-08-2005, 08:42 AM   #4 (permalink)
GMCTruxrule's Avatar
Member # 51243
better idea: Get rid of the saddle tanks and install a single 40 gal between-the-frame-rails tank for a 73-87 Suburban.
GMCTruxrule is offline   Reply With Quote
Old 08-08-2005, 08:25 PM   #5 (permalink)
Member # 44659
I thought about the burb tank for my truck, till I realized how much I bashed the frame rails off of rocks on my fullsize longbed!! I crushed my tanks, and decided I would put in a bed tank, but then I parted out the truck to build a blaze.
So, if you don't smack the rearend of the truck on stuff, put a burb/blaze tank in, otherwise, put the tank in the bed and wheel the pee out of it!!
lumpdog is offline   Reply With Quote
Old 08-09-2005, 03:45 PM   #6 (permalink)
Member # 39602
My '74 K20 has skidplates on the tanks. They look stock, but I'm not sure about that...
mountain4x4 is offline   Reply With Quote
Old 08-09-2005, 04:14 PM   #7 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
steel or plastic? my 87 2wd had plastic "slider/gaurds" but they didnt look like they take much beating.
use expanded steel, it wont hold water and mud and prematurely rot your steel tank.
trkklr77 is online now   Reply With Quote
Old 08-09-2005, 04:21 PM   #8 (permalink)
Member # 39602
Looks like 1/8" steel. They have "louvers" to drain them so they dont rust themselves (or the tanks) out.
Old 08-09-2005, 04:24 PM   #9 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
as much as i love chevys and mine x2 but if it has drainage built in, its probably not stock, thats thinking a little too far a head.
Old 08-09-2005, 06:37 PM   #10 (permalink)
Member # 51549
i want to keep the truck as stock as possible minus the lift kit and tires. i have whats left of the plastic things (they dont last long when living on a farm aka hay felds,oops'es etc.) i wanted to find out if anyone made them to save me time but i think i am going to make a set, and make it so it has nerf bars built in or something like that.
thanks for all your input.
jimmy
Old 08-09-2005, 06:53 PM   #11 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i would think about making it big, really really big. as in big enough to cover from the mid tranny to the rear of the t case and wing it out for the gas tanks. some trucks came with a 2nd tranny cross member bihind the tcase with a skid guard directly under the tcase fwd output.
mabey a 3rd in front of the main cross.
if you have ever seen the long arm kit for a tj, ive been thinking about something like that as a all in 1 deal 4 link/spring mount-nerfs-cross members as a whole bolt in deal.
Old 08-09-2005, 10:45 PM   #12 (permalink)
Member # 44659
My truck was factory equipped with the steel skid plates. They had supports that came down from the mounting brackets for the tank. I destroyed both of them. Plus, rocks and mud were constantly stuck in them, so I had to remove the debris all the time to keep from rusting/rubbing a hole in the tank. I would say if you want real protection, build your own, but make them unbolt easily (maybe even hinged) to clean the mud/rocks out of them.
