Member # 48957
steering arm removal- how to?
how the hell is the steering arm removed? i am having the hardest time, anyone have any tips for me??!!
1990 GMC Suburban. 3/4 ton. 4" lift. 35" BFG Mud Terrains on 16.5 Mickey Thompsons |
Member # 48957
i know theres a lot of people who have had to do this, and im in the process of lifting my truck right now, so i need to know asap!
Member # 21630
Once you have the three nuts off, beat down on it with a BFH. Then beat up on it. Repeat until thethree cone washers that start to come out. Get some channel locks, and work the cone washers all the way out, then the arm will come off. Oh yeah, for GM/Suburban 4X4 tech, CK5(.com) can't be beat.
John
yeah right |
The last two I did, I removed all the cone washers and nuts, and heated it with a torch and broke my all steel sledge hammer and still never got it off. I ended up getting it loose then torching off the studs and grinding them flat and putting crossover steering on the trucks instead of trying to fix that horrible gm shit steering. I just bought another truck, not lifted and I am still gonna do crossover as the gm stuff is shit. Dont get me wrong Gm is good, just not all the time. If you are serious about the truck, just pony up the dough and get the crossover steering done before you drive it, you wont be sorry.
89 yota/3.4 swap/auto/33 stt's 87 runner/3.4 swap/33 toyos 78 chev k30/400/th400/44 swampers 77 chev k20/400/th350/36's, no lift, lincoln locked front and rear 79 blazer-getting piratized as we speak 84 runner/9 inches taller,3.4/auto/crawler etc soon [url]http://www.myspace.com/slater442w30[/url] |
Member # 47287
I cut through them horizontally with a torch which frees them up and usually takes less than 10 minutes (I always try to heat them with torch and try to pop it off with air hammer first) but the cutting method is guaranteed, just be careful
[email]joe@generalspringkc.com[/email] [url]http://www.generalspringkc.com[/url] |
Member # 37519
This is what you need to do the job
![]() You need to beat down on it hard until you free up the cone washers.. Once you get the cone washers out that thing will come right off.. It is a pain in the ass no matter how many times you have done it but it will come off.. |
#13 (permalink) |
Member # 15404
Never had one I coulden't get off with a BFH...
When you put them back together use some antisieze....it will make future work much easier...
Life begins where the pavement ends! |
#14 (permalink) |
Member # 42806
I couldn't get mine off either and my buddy helped by using his air hammer with punch bit on the side of the arm to help loosen the cone washers. That mixed with both of us taking turns with a BFH for 20-30 minutes finally broke it loose.
Mike
Need to find a trail? Help contribute GPS info and pix online at www.OurTrails.net |
#15 (permalink) | |
Member # 33482
Ford tool- BFG or big fing hammer.
blah blah blah...... |
#16 (permalink) |
Member # 21249
I poured used motor oil over mine and let it sit overnight then went at it with a BFH. I agree with the other guys though, get crossover steering, as my steering really sucks right now. Full hydraulic is next for me when I get the money saved up.
Patrick 1972 GMC Jimmy 350/350/205, 44 front, 12 bolt rear welded w/redneck shackle flip, 4 in spings front, 35 in MTRs. [B]Sold it![/B] |
#17 (permalink) |
I Like the idea of welding the nuts to the cones.. i wish i thought of that....
When these guys are saying get after it with a hammer, they mean it. I have removed 2 in my day and each one was a bitch, heat or no heat.. it took me a good 3 hours or whalling on it with sledge we used to pound tent stakes into asfault... dont give up beat that thing for all your worth...
lame 88 2door xj. |
#18 (permalink) |
Member # 37553
I have removed 2 in the last six months. 1 was off an 85 and the other was off a 76. Neither had ever been removed. I found that soaking them in PB (favorite penetrating oil) for a day or so really helps. Spray the piss out of them every hour and give it 10-20 good whacks with a big hammer, then let it sit. This also helped on the last one, place a pipe over one stud and beat down on it with a BFH, but don't mess up the threads. This helped break the last one loose.
Don't despair. It will come off, it just talks time and elbow grease.
I find that immaturity trumphs professionalism anyday |
#19 (permalink) |
_Differential 'Dozer
Member # 51113
I had to remove the arm on my '76 before I knew anything about this being a PITA, and it ruined my whole night!!! That puppy has got to be whacked! I ended up soaking it in Rust Eater (PB is excellent too), heating up the nuts/cones/studs with a torch, whacking the crap out of the arm with a small sledge, and quenching the cones with more penetrating oil. It smoked like burning tires, and may not be the safest idea (I keep a good extinguisher on hand at all times!) but it did the trick. The last one was particularly stubborn, and I did the same procedure, but took my air hammer and buzzed on the side of the cone to rotate it free. It worked pretty good. I wish I had thought of that in the first place. It did kind of bugger up the cone, but it was still usable with a little cleanup. Try not to screw up the studs because if they're anything like mine, they'll be tough enough to unscrew. The rust belt SUCKS!!! Really the best idea though is to forget the friggin' arm and go with crossover steering. You'll be happy you did.
'76 K20, 400, NV4500, LoMax 205, 14b/Detroit/discs, D60, 4.56s '78 K30, 400, TH400, 203, 14b, D60, 4.10s '79 Cherokee, 360, T18, D20, W.T.D44s |
#21 (permalink) |
Member # 183962
you have to heat the cones that are on top of the steering are heat the until there red hot take all three of them out and the steering are will com off if you dont get the cones off you wont get the steering arm off
#22 (permalink) |
Mr Mom
Member # 94897
this gets better and better. You just took the cake on answering the oldest dead thread. 6 years old. If he doesn't have the arm off, something is majorly wrong.
89 jimmy D60/ff14bolt/400/203/205. Detroit rear, open front for now. |
#24 (permalink) | |
Member # 51243
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#25 (permalink) | |
Member # 183529
