K5 build up (tentative) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-28-2005, 02:42 PM   #1 (permalink)
Member # 50548
Since I wreked my toyota this past week I have decided to build a k5 to run 40in tires.
The plan:
A. 1-ton axles f+r geared to 5.13 welded in the back open in the front
B. H-D Steering
C. Sky shackle flip for the rear and 4in lift springs for the fron
D. 40in IROKS with some steel rims
E. Hack the fenders
F. Bodylift as neccesary
That is the basic foundadion for the rig and incedentalls will be taken care of.
Lemme know what you think.
1988 Toyota 4x4
-Lock-Right Locker -Delta Toolbox -fabtech spare tire mount
-Custom flatbed -3in PA Body Lift
-Bald 32x11.5 Cooper All Terrains
Cause we will put a boot in your A$$ its the American way-Toby Keith
I had the right to remain silent, but I didn't have the ability-Ron White
WHITEYFORD is offline   Reply With Quote
Old 08-28-2005, 03:04 PM   #2 (permalink)
chris408's Avatar
Member # 37354
With a rear locker, and the front open...you will just run into problems of the rear pushing/shoving the front into obstacles. This is really not good for your truck...this is what happened to mine, thanks to no front locker...(front axle snapped the center pin off the spring pack, and shoved back into the transfercase...destroying the Xfercase and tranny.)
[COLOR="Red"][B]The time is near at hand which must determine whether Americans are to be free men or slaves.[/B][/COLOR]
George Washington
[COLOR="Red"][B]Americans have the right and advantage of being armed-unlike the citizens of other countries whose governments are afraid to trust the people with arms[/B].[/COLOR]
James Madison
chris408 is offline   Reply With Quote
Old 08-28-2005, 03:14 PM   #3 (permalink)
Member # 50548
Chris, so what are you suggesting?
1988 Toyota 4x4
Old 08-28-2005, 09:07 PM   #4 (permalink)
Member # 25244
Send a message via AIM to REDNECK350
I think his tellin you that you should run a locker in front also...
"Life aint worth shit if you dont ever try something people say cant be done"
REDNECK350 is offline   Reply With Quote
Old 08-28-2005, 09:46 PM   #5 (permalink)
4NIK8R
49willys's Avatar
Member # 23515
2 quik suggestions, I run a K-5 on 42s. The lift is sufficient, but the tires wil get into your firewall on 4" springs, the front axle needs to go foreward 3 or 4 inches. use your stock 52" rear springs up front. then put some 56"s in back when you do your shackle flip. You will need cross over steering.
49willys is offline   Reply With Quote
Old 08-28-2005, 09:51 PM   #6 (permalink)
chris408's Avatar
Member # 37354
yep
George Washington
James Madison
Old 08-28-2005, 10:05 PM   #7 (permalink)
TNScrambler's Avatar
Member # 10818
Send a message via AIM to TNScrambler
I agree, but if you stay with 40s you shouldn't get into your firewall, I don't, with 4in. springs and 39.5 swampers......however, if you havn't already bought your lift and are going to be going crossover steering anyway, I'd do the 52s up front.
Oh, and no body lift neccesary for 40s with a 4in lift as long as your not afraid of the sawzall Plus I think body lifts are gay
Justin
random parts stashed in various locations that might someday become part of a Jeep ;)
TNScrambler is offline   Reply With Quote
Old 08-29-2005, 04:49 AM   #8 (permalink)
Member # 50548
What sort of work is putting the 52s up front? And would the 56in rears eliminate the need to use a zero rate to move the axle back afterwards?
1988 Toyota 4x4
Old 08-30-2005, 07:53 PM   #9 (permalink)
Plasma Addict
BozoWise's Avatar
Member # 51725
I've got 52's on the front. Check out the pics http://www.villagephotos.com/pubbrow...der_id=1423355 Oh and I have a "gay" body lift also
link for 52's http://coloradok5.com/52inchspringswap.shtml
BozoWise is offline   Reply With Quote
Old 08-31-2005, 01:53 PM   #10 (permalink)
MTMike's Avatar
Member # 42806
Use your stock 52" rear springs up front. then put some 56"s in back when you do your shackle flip. You will need cross over steering.
Here's another vote for that. It requires a little more work but is very much so worth the extra effort.
I have stock 52's up front with 7.25" shackles, relocated front hanger & shackle hanger about 3" forward for optimal axle placement & shackle angle. Ford shock towers, and stock 56's (run backwards) in the rear with a shackle flip (reversed sides) & 6" shackles. It rides like a cadillac and flexes like a trail rig should. I also have a 3" body lift and I've yet to have a tire rub.
Mike
Need to find a trail? Help contribute GPS info and pix online at www.OurTrails.net
MTMike is offline   Reply With Quote
Old 09-04-2005, 07:22 PM   #11 (permalink)
Member # 13110
Here is a pic of my K5 w/ the 52's in the front and a zero rate to move the front forward about 3.5", and the rear is a shackle flip w/ Ford 57's. Tires are 38's, but there is more room there for bigger tires. Fenders are cut all to sh!t.
... according to an old educated "Jeeper" I am just another "Toyota Faggot" ...
Poohbair is offline   Reply With Quote
