manifold question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-15-2005, 10:42 PM   #1 (permalink)
Member # 48409
manifold question
will a 89 tbi 350 mainfold fit on a 78 stock 350 engine?
jonsroom is offline   Reply With Quote
Old 09-15-2005, 11:34 PM   #2 (permalink)
Krazy Krakker's Avatar
Member # 52488
Yes it will.
87 YJ, 4:56s 1tons, 383/350, 205 T-case. "If you don't want it broke it, DON'T Let me drive it"!!!
Krazy Krakker is offline   Reply With Quote
Old 09-16-2005, 12:39 AM   #3 (permalink)
k5krushert1's Avatar
Member # 44208
wait i thought intakes changed patterns in 87? tell me if im wrong if thats the case it wont work
k5krushert1 is offline   Reply With Quote
Old 09-16-2005, 04:22 AM   #4 (permalink)
Member # 4140
The center two bolts on each side of the intake go in straight down on the TBI manifold instead of on an angle like the older manifolds. The TBI intake can be modified to fit, although I have never done it personally.
Tim
There is no accounting for taste
1936, 1937, 1943, 1950, 1952, 1954, 1955, 1997, 1998, 2002, [B][COLOR="Red"]2008[/COLOR][/B].
Black Dog is offline   Reply With Quote
Old 09-16-2005, 07:04 AM   #5 (permalink)
Member # 44659
If you are talking about exhaust manifolds, then yes.
Intake manifold will fit with minor grinding. The center two holes on each side need to be ground on top so they are parallel with the gasket mount surface. Then custom grind a fender washer to fit the bolt hole areas, and use four header bolts in there (because they usually have a 3/8" head).
Hopefully that makes sense.
lumpdog is offline   Reply With Quote
