Axle brace/stiffeners? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-13-2002, 11:32 AM   #1 (permalink)
Member # 9357
Any point to these? I have bent the housing on both my front and rear 10bolt now. Upgradeing to 1ton axles would be nice but I have no power and less money, what if I just put those stiffeners on? Should I buy them or make my own if i do? Do they just snap the the shafts or nuckles off instead?
Charlo
p.s. Anybody got a cheap 10bolt housing or complete axle in the sothern Cali area?
Scrap metal with a chevy logo in front. BB,FI,1T,
charlo is offline   Reply With Quote Quick reply to this message
Old 03-13-2002, 02:16 PM   #2 (permalink)
Member # 2039
Re: Axle brace/stiffeners?
Charlo
Try this guy............Steve Frisbie http://mo-offroad.com/ - he makes ABOVE the axle trusses...............
Anything below it will take away ground clearance and be a catch point for anything and everything.
14BFF are about $100 - the issue is new wheels.
You should be able to find 10 bolt axles by the dozens..........literally...............for cheap. Real cheap.
Go to www.coloradok5.com - sign up and post a 'Part Wanted' ad...........
Blazzin no more..........convert to the Cummins Club.
2001 2500QCSB, Bombed 47RE, BHAF, EZ, Revtek leveling kit
BlazzinOR is offline   Reply With Quote Quick reply to this message
Old 03-13-2002, 09:39 PM   #3 (permalink)
Member # 9357
Ground clearence is not as big an issue since I run mud only. I dont know how much strength those braces would add either. I think that by the time the housing bent far enough to get good resistance from the truss it would be too late.
Charlo
Old 03-13-2002, 09:51 PM   #4 (permalink)
Member # 5436
I agree with BlazzinOR, I had a ten bolt with a Con Ferr under axle axle truss and it was a waste of money, it caught on everything on the trail and drags in the mud. Swap to a 14 bolt, if you can find one with the same gear ratio it'll probably be cheaper than buying the truss and you'll never bend it, and you'll have a hard time breakin it.
YOU are paranoid.
monzter is offline   Reply With Quote Quick reply to this message
Old 03-14-2002, 11:26 AM   #5 (permalink)
Grim Reaper's Avatar
Member # 6726
Charlo
You would be surprised at how much that add's. The rock ring suports the center with the pinion snout clamp. Then the out rigers tie in right at the spring purch. My guess is that truss will strenghten up the housing by 75%. The rest of them crappy truss's...maybe 20% gain till you whack them on the first rock.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR]
"He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill
Grim Reaper is offline   Reply With Quote Quick reply to this message
Old 03-15-2002, 04:21 PM   #6 (permalink)
Member # 9357
I was thinking of cutting a "T" beam to the shape of the diff/axle housing and welding it on top of the housing. I would make the beam out of 3/8ths plate metal I can get a hold of. I have the use of a plasma cutter for the cut-out. I would add aditional supports/surface area and height near the spring perches which would replace the 6inch blocks I have there now. This would cost me nothing, but is it a bad idea? What effect would welding have on the axle housing? It would probably ruin the axle by warping the diff housing or axle tube near the bearings, right?
Old 03-16-2002, 05:45 PM   #7 (permalink)
Member # 9357
Maybe I am just too eagre to melt shit with my new welding capabilities, yeah thats got to be it.
