Dana 60 "Death Wobble!" HELP - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2005, 10:51 AM   #1 (permalink)
cpydrman's Avatar
Member # 21913
Huge death wobble problems. Not the common bump-steer, but that all out, mean-ass whoopin', teeth chattering, wobble that makes it feel like the front end is breaking. What the hell is up with all the Dana 60 equiped vehicles my buddies and I own?? Why does it only happen at 35-55 mph?
I have a 1980 Chevy Crewcab dually 4x4 with 235/85R-16's, 2" suspension lift, a NEW complete King Pin repair kit done on it within 3 mo's, new tie rod & ends, new balanced tires/wheels, hubs, bearings, shocks.
His: 1986 Chevy Suburban 4x4 1 ton w/ 8inch springs, 37's, and a
Dana 60.
And several projects
I know what's wrong with his, but my dually has brand new everything in the front $1000 worth and at 35mph it scares the crap outta me everytime it's driven.
I have Dana 60's on all my project vehicles, and I'm wondering if I want to revert back to a 44 just for drivability sake?? From this site previously, I was told NOT to shim a Dana 60, well then, how do you put a big lift on, and keep the pinion outta the dirt?? Do I have to cut the ends and reweld them on?
Please Help.
(and no I won't sell my pile of dana 60's for $500)(yes, I said pile>)
cpydrman is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 11:15 AM   #2 (permalink)
[Memphis]'s Avatar
Member # 49281
What do ya mean the axles "shoots out"? How do the springs look (even though they are brand new)? Perhaps pictures would help as well, as pictures can tell a thousand words vs. trying to understand what someone types.
[Memphis] is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 01:15 PM   #3 (permalink)
Member # 37519
Well you can keep your pile but I will take one for $50 (Yes I said $50)
[COLOR="Black"]..............[/COLOR]//)
[COLOR="Black"]............[/COLOR],/../
[COLOR="Black"]...........[/COLOR]/..../
[COLOR="Black"].....[/COLOR]//'...'/`
[COLOR="Black"]..[/COLOR]/'/.../..../......./\
[COLOR="Black"].[/COLOR]('(.......... ~/'...')
[COLOR="Black"]....[/COLOR]\.................'...../
[COLOR="Black"]......[/COLOR]''...\.......... _.
[COLOR="Black"].......[/COLOR]\..............(
[COLOR="Black"].........[/COLOR]\.............\
mudslinger99 is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 02:07 PM   #4 (permalink)
Member # 13110
For starters, begin by playing with your toe in / out on your alignment... Just keep changing it and eventually, you will find a place where the wobble is almst gone.
If that doesn't work, then just add a hydro assist ram and it will all dissapear for about $250 bucks from Rocklogic or Rockstomper...(or cheaper if you wanna do a home brew setup)
... according to an old educated "Jeeper" I am just another "Toyota Faggot" ...
Poohbair is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 02:10 PM   #5 (permalink)
roy jones's Avatar
Member # 50585
Dana 60.
Please Help.
hello i had to put 2 steering dampers on mine iwas told it was do to pinon angle. i have 12in springs in front plus big tires.crossover steering and all new parts in the d60
roy jones is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 03:49 PM   #6 (permalink)
Member # 27762
Tires, I know you said they were balanced, but try somebody elses that you know doesn't have a problem, I've been there, my Dodge did the same thing and I replaced all the draglinks and put dual stab , but you can still feel it try to start shaking so the problem is still there I just covered it up. Just swap the front tires and wheels with somebodys to see if it changes.
millerxc is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 03:55 PM   #7 (permalink)
AtTiLiA's Avatar
Member # 27465
Send a message via AIM to AtTiLiA Send a message via MSN to AtTiLiA
swap the front to rear tires. also i have found on smaller vehicles that shock placement is a big factor in death wobble.
and maybe you have a pile of d60's because they are all death traps LOL j/k man
but on a serious note. what rebuild kit did you buy and was it a complete kit.
and maybe you do need to cut and turn your knuckles if this is the case.
____________________________________________
91 Toy Ex Cab SAS
d60/14b
92 gmc
AtTiLiA is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 04:52 PM   #8 (permalink)
4544x4's Avatar
Member # 34587
Send a message via AIM to 4544x4 Send a message via Yahoo to 4544x4
Mine does the same thing(90 GMC v3500 Crewcab 12 in lift 35125016 bfg mudktms)was told it was the kig pins worn out.
Chupa la verga
4544x4 is offline   Reply With Quote Quick reply to this message
Old 10-15-2005, 07:17 PM   #9 (permalink)
FRIZZLEFRY's Avatar
Member # 5691
...then just add a hydro assist ram and it will all dissapear...
Hydro assist is not the cure all the time.I have it and it does nothing for it.I either go under the speed that it happens,or haul ass to get above where its gonna happen.What I have heard working for alot of people besides playing with caster and toe is new kingpin preload springs.Or new springs and a couple fender washers on top of the springs to raise the preload a bit.
The Woohoodilly- 69 FJ55
Bertha-79 Diesel K10 Stepside- Stock height,35s,LS powered & spring under
FRIZZLEFRY is offline   Reply With Quote Quick reply to this message
Old 10-16-2005, 04:35 PM   #10 (permalink)
Member # 51786
If you just did your kingpins I assume that isn't the problem. If you took the axle out and reinstalled it or swapped it in to begin with what is your caster like?
caster is only adjustable by putting in the proper shims. You should play with your alignment try different caster/pinion angles and mess with your toe. After we 4 linked my buddies front he had the same problem and it was a caster problem.
bogginburb is offline   Reply With Quote Quick reply to this message
Old 10-16-2005, 04:37 PM   #11 (permalink)
Member # 51786
and as far as tires go. If it is tire related you usually can't drive though the wobble like your describing. A tire vibration would only get worse with speed.
Old 10-16-2005, 09:05 PM   #12 (permalink)
MADE IN USA
ChassisUltd's Avatar
Member # 24529
im running 39's, had death wobble at about 25-30, put a steering stablizer on it, no more problems, exept when aired down to like 8 psi, i get that starting to wobble feeling but it hasnt gone into death wobble since.
Pirate Discount Code "PIRATE4X4" To Save 10% OFF On All Chassis Unlimited Made Products
***Dont forget***
Free Ground Shipping on orders over $499
Low Prices, Hundred's of Parts & Unlimited Tech Support
Like Us on Facebook @
ChassisUltd is offline   Reply With Quote Quick reply to this message
Old 10-17-2005, 02:15 PM   #13 (permalink)
Member # 49663
Send a message via AIM to 87GMCsierra
^^ same as above. im running 39.5's and i had death wobble put a steering stabilizer on and i also found a couple loose bolts in the shackles that might have just added to the problem
87 GMC 350tbi 465/twin sticked 205 H.A.D. front shaft one tons locked stock 52's and 56's 39.5 tsls
87GMCsierra is offline   Reply With Quote Quick reply to this message
Old 10-17-2005, 03:16 PM   #14 (permalink)
cpydrman's Avatar
Member # 21913
Thanks for the advice. I still need to know if 60's can be shimmed?? Will put all your suggestions to the test this weekend. Any other info would be greatly appreciated.
Old 10-17-2005, 03:37 PM   #15 (permalink)
Member # 40239
I know someone that cured their wobble by shimming the kingpin springs with a flat washer. Not enough spring pressure.
Cry HAVOC! And Let Slip The Dogs Of War.
swampthang is offline   Reply With Quote Quick reply to this message
Old 10-17-2005, 09:58 PM   #16 (permalink)
Member # 51786
I don't know if you were planning on going to crossover but that might be an easy way to eliminate kingpin spring deflection. I've heard of alot of guys that run big tires with small amounts of backspacing on their wheels having problems with spring deflection. It just provides too much give. Check out this site http://www.wickedfabrication.com/ima...ydoublearm.jpg these guys are wicked fabrication and their dana 60 high steer arms eliminate the spring with shims pretty sweet.
Old 10-17-2005, 10:15 PM   #17 (permalink)
Member # 29210
Send a message via AIM to Davethorik
As an expensive last resort, there is someone on here who sells custom made knuckles that run roller bearings top & bottom to eliminate the bushing & spring altogether.
Davethorik is offline   Reply With Quote Quick reply to this message
Old 10-18-2005, 08:59 PM   #18 (permalink)
tennessee rockhumper's Avatar
Member # 52201
nothing sucks like a nasty deathwobble. i watched my brothers truck from my rearview mirror have one on the freeway years ago. he crossed three lanes of traffic and finally stopped it in the grass. i could actually see the tierod bowing up and down like it was a wet noodle. scared the hell out of me. not to mention him.
a pic would be nice. so would some more info.
-how much pinion angle are you running? consider rotating them.
-do you have a stablizer on it? how many , how old?
-are you running stock steering components?
i got pissed a while back with a friends. we rebuilt the kingpins, cut and rotated the knuckles, then went full hydro. with a 1 1/2 inch solid steel tierod on 3/4 inch heims. that cured the shit out of it.
tennessee rockhumper is offline   Reply With Quote Quick reply to this message
Old 10-19-2005, 08:12 AM   #19 (permalink)
bigfoot's Avatar
Member # 10545
I tried all the tricks with mine, playing with the toe in or out, extra washers on the springs, tightining the piss out of every bolt on the front end and none of it made much difference until i put the ram assist on. It cured all of my problems.
[SIZE="6"][COLOR="Red"]JACKASS WHEELERS
[SIZE="4"][COLOR="Red"]ECV 7-11[/COLOR][/SIZE][/COLOR][/SIZE]
bigfoot is offline   Reply With Quote Quick reply to this message
Old 10-19-2005, 01:22 PM   #20 (permalink)
BAD4WD's Avatar
Member # 12794
Couple of years ago i replaced the frt. stock steering stablizer on my v-30
because i was buying new shocks for the truck & decided to get a new matching stab. A week later the frt. end started to have a mean DW. I put the stock one back on & fix the problem The pro comp brand stab. was defected I return it & they replaced it with a new one. They told me they have had some problems. Laters
BAD4WD is offline   Reply With Quote Quick reply to this message
