transfer case id - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2005, 03:00 PM   #1 (permalink)
Trail Tampon
rajincajingt's Avatar
Member # 27333
transfer case id
guys...
need some help... the drive train is out of a 83or 84 chevy blazer
305
turbo 350
and a new process transfer case with the stamping c-99404
any ideas... the search yeilded either a 203 or a 208???
if it helps it has a 10 spline front out put shaft and i need a new one. (cracked it in half on a stump!!!!)
next question is should i replace that deal, or get a outputshaft and call it good or try to find something else...
will it stand up tothe 305 and 38's???
thanks
matt
05 LJ stock
1976 C30 3+3 12V/47RH
instagram: LunchBoxFab
rajincajingt is offline   Reply With Quote Quick reply to this message
Old 11-12-2005, 03:35 PM   #2 (permalink)
metty's Avatar
Member # 34363
if you cracked it in half is probably a 208, they are aluminum and dont stand up well to being hit on stuff
'96 Tacoma 3 link SAS, coilovers, KM2s etc
metty is offline   Reply With Quote Quick reply to this message
Old 11-12-2005, 04:00 PM   #3 (permalink)
Member # 4243
10-spline doesn't jive with a 208... afaik, only the 205, and maybe the 203 have this spline front output.
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 11-12-2005, 09:09 PM   #4 (permalink)
Trail Tampon
Member # 27333
did not crack the housing in half, just the front output shaft
05 LJ stock
Old 11-13-2005, 12:30 AM   #5 (permalink)
Member # 29210
Send a message via AIM to Davethorik
203 and 205 don't jive with "83 or 84 k5," my vote is frankentruck.
got pics?
Davethorik is offline   Reply With Quote Quick reply to this message
Old 11-13-2005, 07:58 AM   #6 (permalink)
Trail Tampon
Member # 27333
Name this transfercase
Here is the carnage from the first run. This was an attempt to cross the logs.
The transfercase has a ten spline front output shaft for sure. We know that because we have parts of it that are real handy. :grin:
05 LJ stock
Old 11-13-2005, 09:15 AM   #7 (permalink)
Member # 4243
Congratulations! It's a 205
That 10-spline output is the older style...say 70-76ish Chevy.
Now would be a good time to upgrade to 30 or 32-spline.
Old 11-13-2005, 10:18 AM   #8 (permalink)
Member # 16107
Yep 205 it is i agree 100 % i also agree now is the time to go 30 or 32 spline front
its a plug and play deal you dont even need to remove the t case
and of course i have all 3 different spline counts if you need one just pm me
R
U fckrs are lost again ??? What 2 Hell
xsintrick1 is offline   Reply With Quote Quick reply to this message
Old 11-14-2005, 07:02 AM   #9 (permalink)
Trail Tampon
Member # 27333
check this out...
http://www.pirate4x4.com/forum/showt...hlight=c-99404
xsintrick1 you got a pm...
05 LJ stock
Old 11-14-2005, 07:16 AM   #10 (permalink)
Member # 3694
yep 205...I'm rebuilding one right now...mine was made in 1972 and it has the 10 spline front output. If you would have looked on the front side of the case there is a metal tag with all the info of when it was made and the model with the 1.96 gear ratio...usually blue and silver
Need Steering?
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote Quick reply to this message
Old 11-14-2005, 08:13 AM   #11 (permalink)
Trail Tampon
Member # 27333
this is what the AA site has to offer
if you find yourself drinking alone alot...
if you feel the need to drink to 'fit in'...
oops wrong site
the Advance Adapters site says this
http://www.advanceadapters.com/catalog/040.html
The easiest way to identify the NP205 transfer case is the 3 bolt cover on the idler shaft...
05 LJ stock
