t-bar ? 95 chevy 3500 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2005, 05:31 AM   #1 (permalink)
Member # 62729
Ok, I ran in to a problem last night. I just got a set of 16x10 rims for my truck to replace the factory set on my 285 something tires(almost a 33") It was tearing up my centers in my tires. Well you probably know what i'm going to say next. Now the tires rub front and back. So I engaged brain into reverse and jacked the torsion bars all the way up. Now I think that there is absoluty no suspension movement up front.
Is it possible that I took it up so far the suspension is at full drop. (my adjuster bolt wouldn't go in all the way.) If so wouldn't this mean that I could back it off a little and I would get some of my ride back without sacraficing wheel clearence? Its only rubbing on the back of my fender at the flare now. Any input would be great before I completly destroy my ball joints. Unfortunaly I hadn't planed on lifting this for a while as it is my tow rig. Looks like I may have to locate a cheap 4 in suspension. I can't body lift it cause I have a goose neck hitch in the back.
primerk5 is offline   Reply With Quote Quick reply to this message
Old 12-03-2005, 05:58 AM   #2 (permalink)
b454rat's Avatar
Member # 16536
if you cranked it all the way, then yes, you probly are at full droop. I cranked mine a 1/4 turn, and I'm not too far away from my bumpstops. Get a hammer and tap the bottom part of the fender where it hits back some, did that to mine and it stopped from rubbing.
1999 GMC CCSB plans for 8.1 and SAS
b454rat is online now   Reply With Quote Quick reply to this message
