14 bolt disc conversion questions... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-04-2005, 04:34 PM   #1 (permalink)
Member # 62817
New guy to this board I have some questions. I have a 76 K20 that's my winter daily driver up here in the NM mountians. Just did the front end, brakes, ball joints and tie rods. Now I will have to do the rear brakes. I don't ever remember being in there in the 10+ years I've had this truck. It's going to need (I'd bet) shoes, drums and hardware all replaced.
Came across the disc brakes conversion several places, eg:
http://www.shakerbuilt.com/14_Bolt.html
and
http://cgi.ebay.com/ebaymotors/14-BO...QQcmdZViewItem
At first thought this sounds like a good way to go. Better brakes, lighter (dump those big heavy drums), cheaper, easy enough to do. At second thought no one mentions if a master cylinder change is necessary, most times a disc/disc conversion from a disc/drum requires a disc/disc master cylinder. No one mentions a proportioning valve changeout. AND, though I can think of no reason I can't live without a dust cover/guard I sure would think I'd like to still have my emergency brake. I use it often during times like hooking up trailers and just about every day when parking and leaving the heater running while I check my mailbox.
If any of you guys have done this swap out I'd sure like your comments.
MMinNM is offline   Reply With Quote
Old 12-04-2005, 05:07 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
search, its been fully covered.
and dont use any make of brackets that has loose spacers or only 3 bolt holes, they fail often.
Old 12-05-2005, 10:48 AM   #3 (permalink)
surpip's Avatar
Member # 22748
a search will answer most of your questions, pretty easy swap, my kit has the loose spacers, 5,000 miles on it no problems. Caddy calipers will give you a e-brake, but it dosent work well, and most times it is a PITA to hook up. better to go with a driveline e brake
R.I.P. DOZER
R.I.P. Jason
GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS
-ALBERT EINSTEIN-
#472tellico rally
xtrm-s10 is a bad hauler dont let him haul your stuff
Buy my mega cab
KJ6IYH
surpip is offline   Reply With Quote
