Member # 37243
73 Chevy 3/4ton
Would a 1973 Chevy 3/4 ton have a dana 60 in the front, I know It has the Corp. 14 rear, It has the 4 spd, and not sure what t-case, Im hopping to pick it up for $1500 not to sure though... Thanks
Member # 16536
If it's a heavy 3/4, will have the bigger hubs on it, little thicker tubes, not much to brag about, but a good rig to start with. T-case will be 203 or 205. Even in a 1 ton of that year it will be a 44HD, 60s didn't come along till 77 IIRC.
#6 (permalink) | |
Member # 37519
73 - 76 had d44 fronts 77 - 78 could have a d44 or a 10 bolt 79 - 87 1/2 and 3/4 tons had a 10 bolt
[COLOR="Black"]..............[/COLOR]/´¯/) [COLOR="Black"]............[/COLOR],/¯../ [COLOR="Black"]...........[/COLOR]/..../ [COLOR="Black"].....[/COLOR]/´¯/'...'/´¯¯`·¸ [COLOR="Black"]..[/COLOR]/'/.../..../......./¨¯\ [COLOR="Black"].[/COLOR]('(...´...´.... ¯~/'...') [COLOR="Black"]....[/COLOR]\.................'...../ [COLOR="Black"]......[/COLOR]''...\.......... _.·´ [COLOR="Black"].......[/COLOR]\..............( [COLOR="Black"].........[/COLOR]\.............\ |
#7 (permalink) | |
Do they actually exist or am I on crack?
:laughing: |
Member # 38212
We have a 74' K30 4x4 crew cab dually with a big hub D44/D70hd.I know of others that bought them new in 73' or 74'.I think it was only CC dually's though because that's all I've ever seen or heard of.
My dad has a 73, 3/4 ton with the D44 up front and has ran everything from 38in ground hawgs to 33in AT's. He drives it like he stole it and i've only seen him break front axle a couple times. Just my .02
DON'T FIX IT TIL IT BREAKS |
#13 (permalink) |
Unibody Junkie
Member # 49281
Thread high jack for the same question as above.
I am looking at a 1/2 chev and the seller has 3/4 axles to go with it, he has a 14bolt rear and a Dana 44 front (open diffs). The truck is currently rolling on 10bolt axles (open diff), would it be worth it to swap in the Dana 44 for the front, the 14 bolt will definately be swapped in. If I swap in the Dana 44, will steering modifications have to be made to it or will it be the same as a 10 bolt steering setup? I am having the same debate as Twiztedmods, is the axle worth swapping in or should the 10 bolt be left in place? Currently running 35" tires.... thinking about 4.56 gearing.
Driving a 5.3L 4x4 el camino wrapped in tupperware
#14 (permalink) |
Member # 13786
A 73 3/4 will have what some people refer to as a 44hd. Has thicker than normal tubes and will have the 'bolt-on' locking hubs. Will also have flat top knuckles. that is unless a D60 was swapped in somewhere along the line. Is there ball joints or does it have the bearing trunions?
