Member # 35491
10B beef? (I know I know)
I know that those 2 words don't go together, but.......
I know that many here have built the 10 bolt as best as it can be done, so what IS the best way to beef 1 up? I know that CTM's or sim. joints would help, and alloy shafts. but what about bigger splines? can it be done? Is there a good full diff. locker for 'em, and is it needed? (I have a mini spool now) When $$ and timing permit I will get a D60, but untill then I could aford a step by step build of the 10B.
Sterilize the stupid for a brighter tomorrow!
Member # 5738
Just save up for the 60, you will spend close to the same amount of money to build the 10 bolt.
1982 Chevy K5 Blazer 6.2 Diesel\SM465\NP205 Front: Dana 60 4.88 Detroit 1410. 52" Spring swap and a 4 degree tapered Zero Rate Rear: 14 Bolt 4.88 Detroit 1410. Disk Brakes. Stock 56" springs DIY4x Shackle flip and a 1" Zero Rate 38.5x14.50-15 SX's - 15x9 bead locked wheels [URL="http://www.pirate4x4.com/forum/showthread.php?p=6018956&posted=1#post6018956"]My Build Tread[/URL] |
#3 (permalink) | |
Blingin shafts + CTMs + full locker etc isn't going to be cheap... I'd rather have a stock D60... which would cost less. j
Leftists have killed 100,000,000+ people... still think its a good idea? [url=http://community.webshots.com/user/jekbrown]my 85 K5[/url] |
Member # 55669
yeah, saving up for a d60 would be your best bet. I just finished rebuilding a dana44 and a 9", it aint cheap, escpecially if you plan on stuffing it with new gears and a detroit.
[U][COLOR="Red"]1993 GMC Sonoma w/ 4.3liter V6, nv3500 manual 5 speed bolted to an np231.[/COLOR][/U][FONT="Comic Sans MS"][/FONT] SAS'D++CLICK HERE FOR PICS[URL="http://www.s10extremist.org/forums/viewtopic.php?p=95591#95591"]http://www.s10extremist.org/forums/viewtopic.php?p=95591#95591[/URL] |
Member # 34987
Man, Dana 60's must be cheap where you all live. I can build a 10 bolt or a D44 with Chromo's, gears, diff, bearings etc. for less then a stock 60. I am not saying it is a better choice, but I am saying that it can be done for less then a what a junkyard 60 will cost.
Member # 34987
Member # 35491
Well, Iv'e got the gears I need in it allready, I don't need the full case locker, unless the carrier is a week link in the 1st place (I don't know) and a D60 will cost me $900 from the 'yards in my area. Plus the 10b will give me better clearince up front. But....... Even if I go all out with it, would it ever be comparable with a STOCK D60?
#12 (permalink) |
Member # 51243
People put too much hype into Dana 60's and don't have enough faith in 10 bolts. I run 38" on my 10 bolt and never have had any problems, my friend is running 44's on a 10 bolt front 12 bolt rear set up, wheels the ever loving piss out of it, and never has broken an axle.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
#13 (permalink) |
Member # 54106
yea but is he running lockers. put 44's on a 10b and run lockers and lock it on the street, bring a tow truck with ya too, thats the only way its gettin home. even on the trail, its gonna break.
#14 (permalink) | |
Member # 30185
![]() Ain't that the truth!! I run 39.5's on my 10bolt front with a cheap posi & haven't had any problems. The best advice anyone can give on running 10bolts is - watch your right foot!! Get some good shafts & u joints & run the piss out of it!! Last edited by chasone64; 12-19-2005 at 11:53 AM. |
#15 (permalink) |
Member # 41969
Aparently they havent tried very much or are running a 22r motor. Its hard not to break front dana 44 shafts with 36 inch tires. The main problem is the ball joints with that size of a tire.
08 LTZ Duramax Top Shop Champion Spring 2006-Team Toumbs Repair Top Shop Champion Fall 2006---Team Toumbs Repair Originally Posted by Dan Dibble "In my opinion this is a motor sport so I like to have one. Any more questions " Dan |
#17 (permalink) |
_Differential 'Dozer
Member # 51113
I broke 2 ball joints and 3 U-joints on the open D44 in my 3/4 ton Chevy with dinky 33x11.5" tires before I finally swapped it for a 60. One of the U-joint failures took the upper ball joint with it. None of these failures were under particularly "hardcore" conditions but, to be fair, the 44 was stock and I do like the throttle. I rebuilt the D60 w/ 4.56s, new non-neckdown Spicer shafts, the new Spicer joints, and even (stupidly) kept the outers 30 spline to use the Spicer lockouts I got w/ the axle. I have beat on the basically stock 60 twice as hard as I ever did the 44 and haven't had a bit of trouble. I'd definately say save up for a 60. I doubt that the 10 bolt could be built as strong as a stock 60 in good condition, regardless of the $$$ spent on it (especially the ball joints and R+P), but that's just MHO.
'76 K20, 400, NV4500, LoMax 205, 14b/Detroit/discs, D60, 4.56s '78 K30, 400, TH400, 203, 14b, D60, 4.10s '79 Cherokee, 360, T18, D20, W.T.D44s |
#18 (permalink) |
Member # 52217
lemme ::knock on wood:: before i post this...
but i blew up the spider gears and cracked the carrier in my stock 10b with the g80... replaced it with the detroit full locker and inspected shafts and ring/pinion, and seals while i was installing, everything looked good and i have had NO probs with it whatsover. afraid the next thing to break is gonna be a shaft, but so far so good. im running 35's with factory 4.10s. i think its all about how you use it. overkill is good, but not always worth it. my .02 |
