dana 60 kingpins - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2005, 08:07 PM   #1 (permalink)
Member # 39210
dana 60 kingpins
Have the front axle apart and the kingpins look good(no rust,pits,scratches).Do they wear out or just the bushing and bearings.The axles were out when I got them .
Thanks for any help.
72jimmy4x4 is offline   Reply With Quote
Old 12-13-2005, 09:39 PM   #2 (permalink)
Member # 56574
kingpins
If have your front axle torn apart that far, I would just change em. Buy a complete rebuild kit for the kingpins from a 4x shop or vendor. This is an example of a kit from parts Mike, check the tech section...have fun...
http://www.pirate4x4.com/tech/billav...pin/index.html
63 Scout 80, 350 sm465 klune 205, 1 tons, 40" Mtr's
scout254 is offline   Reply With Quote
Old 12-14-2005, 12:10 PM   #3 (permalink)
orangefj45's Avatar
Member # 6816
i would definetly NOT replace the king pins, especially if they're in good shape. the plastic cups and springs, seals,......should be replaced but the king pins are a major biatch. first off, you have to buy the special 7/8" (i think) allenwrench for $25 which you will never use again. then, if by some odd chance you actually get one of the king pins to come loose, chances are it will crack at the top and split wide open. ask me how i know. those fawkers are in there!
just clean up the pin with some scotch brite, lubricate properly and run it.
Maybe you outta stick to legos!
orangefj45 is offline   Reply With Quote
Old 12-14-2005, 12:24 PM   #4 (permalink)
Member # 13786
Wimp--takes me 2 minutes with my 3/4 impact and a little heat for the real stuck ones.
KWTMECH is offline   Reply With Quote
Old 12-14-2005, 01:30 PM   #5 (permalink)
Member # 25643
Use a wheel lug nut and socket and a little heat to get out the king pins - would not replace them though if they look OK.
Magnum_Willys is offline   Reply With Quote
Old 12-15-2005, 10:20 AM   #6 (permalink)
orangefj45's Avatar
Member # 6816
i guess you're the "right tool" for the job!
Old 12-15-2005, 10:36 AM   #7 (permalink)
rls270's Avatar
Member # 15400
I would replace them if you drive it on street but if its a trail rig i wouldn't bother.
I also got mine out in about 2 minutes......applied heat to the knuckle and 3/4 impact.
92 YJ, 383TPI,700r4,60's
rls270 is offline   Reply With Quote
Old 12-15-2005, 10:33 PM   #8 (permalink)
Member # 39210
Thanks for all the input.Thinking I will replace them.
