PLEASE HELP!!!!!!! Hydroboost Problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-18-2005, 10:47 PM   #1 (permalink)
72Chev4X4's Avatar
Member # 42714
I just finished installing my hydroboost and after properly priming it(I disconnected the coil wire primed it/ filled it,
turned the wheels chock to chock 3 times filled it,
primed it again, filled it,
re-attached the coil wire,
started it the steering was easy, turned it 2 times,
checked the fluid, topped it off,
let it sit, started it, tried to turn it and the steering got hard,
turned it off,
checked the fluid, it was full,
started it back up, pressed the brake pedal and instantly heard whining so I turned it off,
checked the fluid level, filled it,
NOW my steering is hard, brakes are nill, and the pump was getting so hot it was smoking!!!!!!
PLEASE HELP!!!!! Thanks, ahead of time!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
72Chev4X4 is offline   Reply With Quote
Old 12-19-2005, 05:29 AM   #2 (permalink)
mouse's Avatar
Member # 53906
It will probably foam between fills. Give it time to settle down, and fill it up again. A little patience will help get it done right. There is a lot of little air bubbles to get out, so keep filling until there is no foaming.
mouse is offline   Reply With Quote
Old 12-19-2005, 09:05 AM   #3 (permalink)
Member # 32054
Send a message via AIM to VancoPBS
Sounds like the hydraulic lines are reveresed. Give me a call and we'll go over the installation.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
VancoPBS is offline   Reply With Quote
Old 12-20-2005, 02:45 PM   #4 (permalink)
72Chev4X4's Avatar
Member # 42714
Thanks for the reply's. I appreciate everyone's help.
Old 12-20-2005, 07:09 PM   #5 (permalink)
Tinker's Avatar
Member # 44736
any updates on your system?
Tinker is offline   Reply With Quote
Old 01-13-2006, 04:54 PM   #6 (permalink)
72Chev4X4's Avatar
Member # 42714
ALL problems solved... except for a leak in the fitting at the back of the PS pump!!!!!!!!!!!! Thanks to all those who helped!!!!!!!!!!!!!!!!!!!!!!!!!
