Member # 22551
np 208 vs. np241
so i ve had my 87/88 jimmy fs for a while now. its fuel inj w/ a 700r4. i assumed it had a np 241 like my 89 had. i was workin under it today and noticed the tag on the t case said np 208.it looks like a 241. i know nothing about the 208. how does it compare? should i be saving up for a 241?
welcome to the valley!*front drivelines not required* |
241 is a slightly more updated version of a 208. 241 is a better case, and there are more aftermarket parts for it. 208 low range is 2.61 vs. 241 low range 2.72. im looking to swap a 241 in eventually and get a slip yoke eliminator.
'85 k30 with crawl ratio of 140:1 '88 k5 on 39.5 iroks muddybuddy on ck5 |
Member # 64070
I have 84 fs blazer the NP241 is new version of NP208 (NP241 2:72-1 ratio ,NP208 2:61-1 ratio) I use SM465 / NP208 . NP241 came out in 1988. I have no problem with NP208, I have not blown one yet unless you in break the transfer case i have seen front drive shaft go into the transfer case. The only problem is it is the case is weak same as NP241.
Member # 22551
thanks guys. thats too bad i was almost ready to get the slip eliminator for the 241 i thuoght i had. good thing i noticed huh?
Member # 22551
i guess that also settles my question of its a 87 or 88( the pink slip and the door sill dont agree) its a late 87
Member # 3694
I have blow apart 2 208's in my mud truck this past season....But we are going 6-8000 RPM's in 2-3 ft mud in a 5K truck locked up on boggers.....something has to go.....treat it well and You'll be ok
Member # 64410
I just recently bought a 86 GMC 1T. It has a 208, all my experience is with 205's. Is this T-case really worth messing with or should I just swap in one of my old 205's out of my old beater? You say that the case is weak, and I know the 205 case is bulletproof. The new truck is already lifted 12", 60/14ff, 5.13's, and 38 M/T. This swap would get rid of the slip yoke I know, but what would this do to the angle of the front driveshaft. Thanks.
#8 (permalink) | |
Vortec Scout II
'73 Scout II Vortec 6.0L 4L65e np241 '73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's '01 VW Beetle TDI-50mpg or better! ![]() GM Gen III/IV V8 swap info TECH: Gen III/IV "LS motor" to Early GM Auto Trans |
