Chevy Guys Help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-03-2006, 10:45 AM   #1 (permalink)
Member # 64579
Chevy Guys Help
Ok so heres the situation...me and my buddy are lifting my 81 chevy to fit my 44's. it used to be a half ton but we switch that crap out for a dana 60 up front and a corprate 14 bolt in the rear. we now have both diffs under the truck and bolted in. my pinoin angle is straight and what i need to know is if i can do a c/v joint out of my 208c im sure that i can but i just wanna see if you guys have done one before and have any advice you can give me. im going to get a 205 down the road but for now im just gonna settle with the 208. if you can give me any advice from expieriance of what you think youd do anything would be greatly appreciated.
[SIZE="5"][CENTER][FONT="Arial Black"]1981 Chevy,1 ton,44's,big block[/FONT][/CENTER][/SIZE]
bbchevy44 is offline   Reply With Quote
Old 01-03-2006, 04:09 PM   #2 (permalink)
GMCTruxrule's Avatar
Member # 51243
Depending on how much lift your truck has, and with 44"s, probably alot, you need to make sure that your axle are shimmed to the appropriate degrees necessary for the amount of lift you have, and although I can't give you numbers off the top of my head for what you are running, a driveline shop should be able to give you a good reference.
CV joint front drivelines are what GM used in a lot of 4x4s and it keeps the extreme angle of a driveshaft, especially on a lifted truck within workability.
High Angle Driveline has some good products that you should check out.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 01-05-2006, 01:26 AM   #3 (permalink)
Member # 64579
i got the angle right where i need it at the moment. i just read up on cv's and i they said point it 2 degrees below center of the t case. this is where i got it but i just need to know if i can run a cv out of the back of my 208c. im sure i can but has it been done...i know i should be runnin a 205 but money tight and i wanna hear my 208 go boom.
Old 01-05-2006, 10:00 AM   #4 (permalink)
Member # 3694
I just got a 42 degree C/V from jesse at "High angle driveline" for my 208 in the mud truck with 11in. of lift works great. You will have to "notch" the x-member for the C/V to clear ( not much at all )....Good Luck
Need Steering? www.shakerbuilt.com
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote
Old 01-05-2006, 12:43 PM   #5 (permalink)
PR
Member # 63526
You might consider finding a 205 to put in before you spend the money on CV stuff for the 208. I dont know if the cv stuff would match right up to both, but if not, you could prolly find a 205 cheap enough to be comparable to the cv parts for a 208. Just my $.02
Bizeeb65 is offline   Reply With Quote
Old 01-05-2006, 12:56 PM   #6 (permalink)
tie6044's Avatar
Member # 38560
I agree with Biz, get a 205 now, why spend all that time and money just to change it again. Your going to have to have 2 driveshafts made and they might be different when you put the 205 in so you might have to have new ones made or alter the old ones. Just do it the way you want the first time. You'll be glad you did in the end.
ROAD RAGE: S-10 on Rockwells, Kings and Profab, 725 HP BBC, 57" Rice & Canes
'07 Chevy 2500 HD Duramax 8" Fabtech, 37" Procomp Xtremes, 20" Ultras, Edge w/ attitude, Magnaflow 4" exhaust
[COLOR="Yellow"][U][url]www.ouversonengineering.com[/url][/U][/COLOR]
tie6044 is offline   Reply With Quote
Old 01-05-2006, 02:18 PM   #7 (permalink)
Member # 3694
Trust me I'm a 205 NUT if I could run the 42 degree C/V I would have one but the C/V "Bell" won't clear the 400 or 350 tranny pan with a 205 mounted on it ( I tried it on both )! You can try but in my best ghost voice....I Told you soooooo
Old 01-05-2006, 04:04 PM   #8 (permalink)
Stuckle's Avatar
Member # 57804
you can run a high angle shaft on the rear on a 205 when its on a 400...just not the front right? I think hes talkin rear shafts right now
not a big deal...fronts geting cut and turned before we run a front anyways...just cut it so we dont need a high angle cv...
Stuckle is offline   Reply With Quote
Old 01-05-2006, 04:34 PM   #9 (permalink)
Member # 3694
Yes the rear is no problems...front isn't gonna happen...If you do rotate the front that's cool but you still have the "angle" at the case...
Old 01-05-2006, 04:49 PM   #10 (permalink)
Member # 64579
yeah what im asking is if anyone has run a cv out of the rear of their 208c cause i was thinkin of doin it...
i am also now looking for a 205 and if i can find one cheap enough i will jsut do the 205 and a cv outta that.
i just wanna know what it would cost to get a cv outta my 208 so if you know throw a number at me thanks
Old 01-06-2006, 07:27 AM   #11 (permalink)
Member # 3694
208 with a rear C/V is no problem it's gonna run you about $450.00 depending on the specs/upgrades you want. I have a 1350 C/V High Angle Driveline on the back of the mud truck.
Old 01-06-2006, 07:33 AM   #12 (permalink)
PsychoticDeadGuy's Avatar
Member # 54093
the CV can be done, I would reccomend that you wait though. I go a SM465 and NP205 for $140. alot cheaper than the CV 208, I also think the CV for a 205 would be less.
'91 Cherokee Sportsman/4600
Thanks to:
SinisterDiesel.com
RuffStuffSpecialties.com
HorsepowerJuice.com
RDMOffroad.com
PsychoticDeadGuy is offline   Reply With Quote
Old 01-06-2006, 07:47 AM   #13 (permalink)
Member # 3694
The price for the 205 C/V would be about the same because instead of having a slip yoke you gotta convert the rear yoke to the C/V flange...
Old 01-06-2006, 03:12 PM   #14 (permalink)
Member # 64579
alright guys thanks...
it definatly seems like ima go with the 205 cause i dont wanna throw 500 bucks into somthing that is just gonna blow up as soon as i hammer down in 4 wheel...
thanks again
