Member # 63123
Easiest Way To Lift 4" ???
What is the cheapest and safest way to lift a 1985 1/2 4x4 Chevy silverado? Can I just get the new leaf springs that will raise it 4" or what all would I have to do? Can someone point me out to a kit for a 4" lift that isnt too much $??
Member # 43205
new pitment arm, and longer brakelines. drive lines should be fine
Member # 37553
Driveshafts will be good and steering should be ok. Put on the lift and take it for a test drive. If the steering is too bad put on a new arm. Remember to adjust your draglink.
You might look into swapping 52 inch springs into the front if you need flex, a decent ride, and are capable. Writeup on 52 swap on ck5.com Not being a dick, but just a warning, next time use Newbie forum. Questions like this are just asking for trouble around here.
I find that immaturity trumphs professionalism anyday |
#10 (permalink) | |
Member # 4406
![]() If you are looking for a more permanant solution, take it to 4wheel Parts, tell them you want a lift and some big new white letter tires, maybe a little chrome while you're in there, and some truck nutz. Come back later, write them a check, and drive it home. Pete ps Make sure you get the red shock boots. Only the red ones will do. And a big ass windshield banner. See you at the mall!
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride." |
Member # 37553
I should've got the red shock boots. I got the black ones and they only added 5hp. The red ones add 10
#12 (permalink) |
Member # 37519
You can get a Rough Country kit that includes everything you need for about $300 but that price is for blocks.. If you want all springs then add about $150..
Or you can go with a shackle flip in the rear and front springs but you will have to buy all the other parts separate.. That's about the cheapest route other than a 3 inch body lift..
[COLOR="Black"]..............[/COLOR]/´¯/) [COLOR="Black"]............[/COLOR],/¯../ [COLOR="Black"]...........[/COLOR]/..../ [COLOR="Black"].....[/COLOR]/´¯/'...'/´¯¯`·¸ [COLOR="Black"]..[/COLOR]/'/.../..../......./¨¯\ [COLOR="Black"].[/COLOR]('(...´...´.... ¯~/'...') [COLOR="Black"]....[/COLOR]\.................'...../ [COLOR="Black"]......[/COLOR]''...\.......... _.·´ [COLOR="Black"].......[/COLOR]\..............( [COLOR="Black"].........[/COLOR]\.............\ |
#14 (permalink) | |
Member # 40375
Forget the lift and spend your money on English classes instead, newb. Yernkie warned you. |
#15 (permalink) |
Oilfield Trash
Member # 64526
Body lifts are less than $100 for your truck. Unless your willing to do a lot of fender trimming, your gonna need more than a body lift. Probably at least a 6" lift to clear the 37's and then maybe a little trimming. Call 4wheelparts, they can hook you up with a 6" kit for about $350. If you don't want to run rear blocks I would go with springs, probably would be cheaper than the shackle flip and an add-a-leaf.
#16 (permalink) |
Member # 54711
you can run a 4 inch lift and a 3 inch body and clear bigger tires then 37s. A little trimming yes but you dont need a 6 inch and 3. A four inch lift will clear 36s at the most with some rubbing, so just run a 4 inch lift for the 35s.
#17 (permalink) |
_Differential 'Dozer
Member # 51113
I know a 4" will clear 35s fine, so I would think that a 4" susp. and a 3" BL would be more than enough for 37s (if you can stand the BL...).
I have 4" Tuff Country springs at all four corners, and I am happy with it. I got the HD springs in front and the EZ Rides in back. The fronts do ride a little rough, but they still have amazing flex for as stiff as they are. I wish that they offered HD springs for the rear though, as mine are starting to sag (it's been about 3 years I guess). I do occasionally use this truck as a work truck, and those EZ-Rides don't like hauling. The fronts haven't lost a bit as far as I can tell. Now the truck looks like it's draggin' ass... Maybe it's time for a 2.5" shackle flip. When I lifted mine, the DSs were almost at their limit, but still OK. The steering sucks stock and is a nightmare lifted 4". When you hit the brakes hard, especially with the softer springs, it will go hell-bent for the ditch. Get an arm. JMHO. EDIT: Some of you guys are spreading misinformation. While the red or black boots might might look the "baddest", it is pretty well accepted that the neon-green ones add the most suspension travel and horsepower. Anywhere 5-290 from what I've heard. Why don't you do some research before you start spouting incorrect mall-tech?
'76 K20, 400, NV4500, LoMax 205, 14b/Detroit/discs, D60, 4.56s '78 K30, 400, TH400, 203, 14b, D60, 4.10s '79 Cherokee, 360, T18, D20, W.T.D44s Last edited by positrack@earthlink.; 01-07-2006 at 10:31 PM. |
#22 (permalink) |
Member # 52028
Wait a second here.... shockboots are the answer to HP gains?!?!??!
I thought you had to paint all your suspension parts blue or red, I didn't realize it was just a simple boot change!!! Fawk. oh mighty gurus: ORD or DIY shackle flip? |
#23 (permalink) |
Member # 51113
I'm no guru but I like to build shit. I have absolutely no doubt that the ORD hardware is well built, high quality stuff, but I (and most anybody w/ a welder and a tiny bit of capability) can build custom shackle brackets. DIY.
'76 K20, 400, NV4500, LoMax 205, 14b/Detroit/discs, D60, 4.56s '78 K30, 400, TH400, 203, 14b, D60, 4.10s '79 Cherokee, 360, T18, D20, W.T.D44s |
