All Right Here We Go - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-20-2006, 08:41 AM   #1 (permalink)
Member # 57173
Lightbulb All Right Here We Go
Well, my search for a cheap D60 has ended in failure. So, here is what I have aquired. This will be going in my 88 Jimmy.
3/4 ton Chevy suburban with 14ff and D44. Not sure on the Tcase. It has everything except the engine and tranny. Got the whole thing for $250. So in the next couple of weeks, I will start stripping it down and making an inventory of what i have.
So, in light of this I have rethought my plans for my truck. I am now going to go with 16X35X16 boggers, instead of a larger tire I had originally wanted. I already have a 4" Rough country lift on the truck, but want to lose the blocks in place of the DIY shackle flip. In fornt I was wanting to use a longer spring and move the axle forward. Can I use the springs from the rear of the Burb for this? This will be my ongoing thread if anyone cares.
Next questions.... If I put in a 241 Tcase with a clocking ring, do I need to add a body lift or cut out the floor to make it fit??
Has anyone ever used the square driveshafts on a daily driver and had them be successful. I only drive this to work and back and to wheel on the weekends. Work is only a half mile away.
How bad will I tear up these tires if I use a full spool in the rear? If I do get a detroit for the rear do they hold up well?
I plan on losing a lot of weight on this thing (fender cutting, etc) will this aid the D44 at all?
One last thing on my mind. I originally wanted to dovetail the front and rear, but have changed my plans. Would it be possible to take off the front fenders, lower the hood down in the front for visibilty, and fab up some tube fenders. I know it is possible, but my main question is if I do tube it up in the front, I know I will have to get a smaller radiator or lower it into the frame. Do I need to attach the tubing to the body or the frame? If it is attached to the firewall, and then at the frame in the front, the body flex will start ripping stuff up will it not?
Anyhow til next progress or next question, thanks.
R.C.
OklaK5Guy is offline   Reply With Quote
Old 01-20-2006, 10:15 AM   #2 (permalink)
Stuckle's Avatar
Member # 57804
square driveshafts are allmost impossible to get ballanced...i wouldnt ever run one in the rear....front it allright cause how often are you doing 20mph+ over boulders....
as for the d44 in the front, as long as your not locked i dont think you will have too many problems running 35's. Boggers like to grab and if you have exesive wheel speed and then they catch ur gona blow...keep in open or maybe a limited slip, but thats pushin it...
are you planning on running this as your dd?
if so spool in the rear will kill your boggers...id purchase some cheep 35x12.5 mud terrains or something for on the road, and then a quick switch with the impact gun and throw on your boggers for when you hit the trail, or the mall
edit: that will probably have a 208c in it...maybe even the 241 allready...im not sure because i know in the pick-ups 88 was the first year of the 241, and the 208 was used till 87?
Stuckle is offline   Reply With Quote
Old 01-20-2006, 11:20 AM   #3 (permalink)
Member # 57173
My blazer has the 208 in it, I am not sure yet what the Burb has. What is the difference between 208 and 208c?
Old 01-20-2006, 03:22 PM   #4 (permalink)
Stuckle's Avatar
Member # 57804
nothing i dont think
Old 01-20-2006, 03:39 PM   #5 (permalink)
yernkie's Avatar
Member # 37553
Save your cash on the rear spool and just weld it. With the cash saved buy some chromo outers for the 44 and run at least Spicer 760 joints. While you have the front apart replacing the joints replace the balljoints with the best you can buy. Trust me, if the axle is used it will need it. This setup on the front holds up on my K5 with 36in TSL's fine (so far). Losing some weigh will help the 44 a little, but most of the vehicles weight is in the front (engine, etc). Burbs went to 241 tcases in 88 (so a buddy tells me). I've tried a square dshaft on the rear before and I did have a lot of vibrations, but for the front they work good.
I find that immaturity trumphs professionalism anyday
yernkie is offline   Reply With Quote
Old 01-21-2006, 02:56 PM   #6 (permalink)
Member # 65815
Send a message via AIM to slm222
im not sure about the proce but we have tons of dana 60s down here in south texas
slm222 is offline   Reply With Quote
Old 01-22-2006, 12:41 PM   #7 (permalink)
Member # 57173
Well, find me a price and lets do some dealing. We have some 60's around here, but I cant afford $800 right now.
BTW, man do I miss Texas. used to live in San Antonio and Austin
Old 01-22-2006, 04:59 PM   #8 (permalink)
Member # 54549
he's probably talkin rears
My wife still doesn't know about Pirate4x4.SHHHHH!
Sky high!
s1037s is offline   Reply With Quote
Old 01-22-2006, 07:01 PM   #9 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
Camarogenius's Avatar
Member # 49232
Send a message via Yahoo to Camarogenius
Hell, if you got a Suburban 4x4, the link in my sig is just what you need!!
SECEDE!
Truth is treason in the kingdom of lies.
Camarogenius is offline   Reply With Quote
Old 01-22-2006, 07:21 PM   #10 (permalink)
Member # 57173
Thought about that idea. The "Bummer" is cool. But this Burb has no title. Just for parts.
Anyone else have anymore input on my above mentioned questions??
Old 01-24-2006, 06:38 AM   #11 (permalink)
Member # 57173
Well, a new develpment may change my plan slightly. A guy I work with just bought 4 44" boggers, they are sitting on a pallet in his garage. He has some money problems and told me he would take $1000 for them. They havent ever been mounted. So I dont know if I can pass this up.
So answer me this. Will the 3/4 ton D44 hold up to the 44's just for driving to work and back (no wheeling), until I can find a D60?
I have goosebumps on my arm just thinking of having 44's.
Old 01-24-2006, 07:18 AM   #12 (permalink)
Member # 1597
Send a message via Yahoo to BigRob
44" boggers with that t-case and front end.. good luck man you will need it!! Not to mention I did clear 42" tsl's on my 1991 blazer with trimming and 4" rough country's but those 44" boggers man those are just crazy BIG! Cool though....any how!
Rock Zombies
WE Like To pArTy!!!
www.rockzombies4x4.com
www.cal4wheel.com
www.norcalrockracing.com
Don't miss the NOR CAL ROCK RACING round 2 on August 4th @ Prairie City Svra
Help Keep Public Lands Open To The Public!
BigRob is offline   Reply With Quote
Old 01-24-2006, 10:17 AM   #13 (permalink)
Member # 57173
cool, like i said... Dont plan on doing much wheeling til I find a 60. But still got to make it to work and back. I am fabricating up a homemade body lift at work out of aircraft aluminum. My 4" Rough Coundtry plus 2 1/2" body lift, plus lots of fender hacking, should make a need looking truck with the 44's.
Will the 241 T case be ok with the 44's?
Old 01-24-2006, 10:23 AM   #14 (permalink)
Member # 15049
As long as it's just street driven with the skinny pedal, you'll be fine. The 241 will be fine as well, until you can get a real case in there (205 )
1986 K30
sw99 is offline   Reply With Quote
Old 01-24-2006, 06:24 PM   #15 (permalink)
Member # 57173
This Burb is a 78 3/4 ton..............what Tcase is it??? he said it is gear drive cast iron..........
I pick it up Sat
Old 01-24-2006, 07:12 PM   #16 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
Member # 49232
NP 205. pretty good T-case, but I prefer 203's. I'm sure I'll catch some flames for that.
SECEDE!
Old 01-24-2006, 10:11 PM   #17 (permalink)
_Differential 'Dozer
positrack@earthlink.'s Avatar
Member # 51113
You like 203s? Well hell, I guess I'd be willing to help you out and trade you mine for a 205! And how 'bout it, you're even in IL. If you ever get to Tonica, stop by Ace Auto Salvage. The guy's got 203s by the truckload! You'll likely never find a serviceable 205 or anything else of much 4WD value but you can't help but stumble over the scores of 203s laying all over the yard. If you want one, the guy that runs the place would probably give you one (or many) for about $85/ton. Of course, with the 203, tons add up pretty fast...
Not flaming you but honestly curious: how can you possibly prefer the 203 to the 205? Do you like the AWD? That's the only possible "advantage" I can see. Well, that and the 203's Hurst shifter... although they probably decided not to put their name on it for a reason...
'76 K20, 400, NV4500, LoMax 205, 14b/Detroit/discs, D60, 4.56s
'78 K30, 400, TH400, 203, 14b, D60, 4.10s
'79 Cherokee, 360, T18, D20, W.T.D44s
positrack@earthlink. is offline   Reply With Quote
Old 01-25-2006, 09:01 AM   #18 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
Member # 49232
Yes, I do prefer fulltime 4x4. and the next time you're out there, look around for me a couple divorced Pass side drop 203's
Thanks.
SECEDE!
Old 01-25-2006, 10:55 AM   #19 (permalink)
Member # 29210
Send a message via AIM to Davethorik
Thanks.
joking right? Ford was the only mfg. to use a divorced 203 (and they're hard to find).
not to say that you can't make one, but they aren't factory for sure.
:laughing:
Davethorik is offline   Reply With Quote
Old 01-25-2006, 11:14 AM   #20 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
Member # 49232
Actually, Dodge used them as well. I bought one off of Ebay that's from a Fullsized Jeep of some sort.
SECEDE!
Old 01-25-2006, 11:25 AM   #21 (permalink)
Member # 49411
I am pretty sure that with 4" suspension and 2.5" of body you will probably still have to move your front axle foward to clear the firewall for 44" boggers.
Or beat the firewall back with a sledge.
jtl_77 is offline   Reply With Quote
Old 01-25-2006, 12:03 PM   #22 (permalink)
mj
Member # 1919
how is it you can't buy an $800 d60f but you have a $1000 for 44" boggers?
mj is offline   Reply With Quote
Old 01-25-2006, 12:09 PM   #23 (permalink)
Member # 57173
Good question..... I guess I just cant seem to pass up the deal on new 44 boggers for that price. Plus, I had budgeted about 1300 for wheels and tires.
I do plan on moving the axle as far forward as possible. 56" springs, and some zero rates? maybe? What ya think??
Old 01-25-2006, 09:19 PM   #24 (permalink)
Banned
Member # 24706
O no the boggers won't work
so tell me where thay are at so I can help the guy out
all joking aside if you don't get them let me know
bansheeman1 is offline   Reply With Quote
Old 01-26-2006, 09:43 AM   #25 (permalink)
Member # 57173
I would do that, but it just wouldnt be right. I couldnt look at myself in the mirror.
Think I may have him talked down to $900.
The guy with the suburban told me he yanked out the Tcase too. Damn that sucks. He said it was a 205. So I guess I will have to find a 241 or a 205 somewhere else.
